[ROM]-[M7] bareBones - stable - minimal - epic battery
  • 20 Antworten
Scum
Scum
Moderator
Teammitglied
10.283
~{ROM}~{KK 4.4.2}~{M7}~ bareBones ~ stable ~ minimal ~ epic battery ~ 02-24-2014 - xda-developers
Hier mal was wirklich extrem "schlankes"!!
Nach dem flash habt ihr gerade mal 12 Apps :thumbup:
Ich persönlich finde diese super schlanken Roms sehr fein ...
Stripped down AOKP 4.4.2 base, trying to make it as lightweight as possible. ~ 156 Mb zip
The goal is to provide an efficeint, minimal groundwork for users to customize the way they like it.
Amazing battery life.
Base install has only eleven apps in the drawer! (see Screenshots section above)
- Rooted
- ROM Control
- Working ART
- Removed -
.. Google Analytics via noAnalytics Remix
.. Stock Apps (Gallery, Browser, see Changelog below for complete list)
.. Live Wallpapers
.. Bootanimations
.. Stock ringtones/alarms/notifications
.. Bloat
- Core gapps available - only the Play Store. Download link below, thanks BaNkS!
- build.prop tweaks
- Silent camera
Other optimizations coming!
bareBones download link hosted by XDA Dev-DB (at the top of the thread)
oder hier:
aokp_m7_kitkat_unofficial_2014-03-04.zip
Minimal GAPPS
Core Google Apps (only the Play Store) via BaNkS
Installation Instructions
Make sure you are on the latest CWM Recovery!
1) Nandroid Backup
2) Wipe Data & Cache/Factory Reset (if you experience issues, it's probably due to a dirty flash over an old version)
3) Flash ROM
4) Flash GAPPS (optional)
5) Reboot
6) Enjoy!
Please Click the Thanks Button If You Like My Work!
Changelog:
03-04-2014
.. Repo sync
.. Fixed missing alarm
02-28-2014
.. Repo sync
.. Download hosted on XDA
02-26-2014
.. Added screenshots to thread (thanks Matija Gubec!)
02-24-2014
.. Point release v1.1
.. Updated some stuff real quick
.. Is better 02-23-2014
.. First release for HTC One m7
Removed:
- Launcher (replaced with Nova)
- Google Analytics Statistic Reporting (Integrated noAnalytics Remix)
- Browser
- Gallery
- Movie Editor
- Calculator
- Calendar
- Alternate Bootanimations
- Live Wallpapers
- Stock Media (except one notification/ring/alarm each)
- mGerrit
XDA:DevDB Information
bareBones (m7 edition), a ROM for the HTC One
Contributors
sylentprofet
ROM OS Version: 4.4.x KitKat
Based On: AOKP
Version Information
Status: Stable
Current Stable Version: 1.11
Stable Release Date: 2014-02-28
Created 2014-02-23
Last Updated 2014-02-28
Liest sich ja nicht schlecht, schon wer getestet?
Ja ansonsten hätte ich ja schlecht die Screenshots machen können. Absolut minimalistisch...
Muss zugeben das ich aber nicht zu sehr damit herumgespielt habe da ich die letzte AICP noch testen wollte ...
Muss aber sagen das soweit alles funktioniert hat was ich in den 1-2 Std. gesehen habe!
Hatte auch noch die gaaps geflasht und mit titanium alles apps usw. wiederhergestellt gehabt!
Reaktionen: 2WF
Danke für die Antwort, ich werde es am we mal flashen.
Für mich wirklich perfekt da der "ganze müll" den man eigentlich nicht braucht oder separat nachflashen/installieren nicht dabei ist ... :thumbsup:
Update ... :thumbsup:
02-28-2014
.. Repo sync
02-26-2014
erstmal muss ich sagen Hammer Rom... :thumbsup:
Genau sowas hab ich lange gesucht.
Nur leider habe ich mit der Rom ein paar Probleme:
- hoher Batterie Verbrauch (nach 3 Stunden im standby 86%)
- Gerät startet bei ein- und ausgehenden anrufen teilweise neu
- beim entsperren dauert es sehr lange bis der Bildschirm reagiert
- Kamera ist auch sehr träge was das starten der APP angeht
Habt ihr die Probleme auch?
Kann es daran liegen dass ich mit trwp geflasht habe?
Freue mich auf Antworten :biggrin:
LG Carassi
Hatte die erste Version nur kurze Zeit getestet gehabt jedoch ist mir nix von deinen Problemen aufgefallen. Werde heute mal die neue Version flashen und übers WE testen...
So hier ein paar screenshots!
Ich habe weder reebots noch irgendwelche andere Probleme mit der rom!
Hat du Full Wipe gemacht? hast du Titanium Backup genutzt wenn ja was hast du wiederhergestellt?
Hi Scum,
also Full Wipe habe ich gemacht.
Backups hab ich keine gemacht.
Mhh also ich werde das mit den Reboots nochmal testen.
Gestern hatte ich keine.
Villt finde ich noch raus woran es liegt.
Mir ist allerdings aufgefallen, dass die Kamera in den Einstellungen "APP-VORGÄNGEN" immer Aktiv ist.
Ist das normal?
Gerade nachgesehen ist bei mir auch so ...
OK dann danke ich erstmal und werde die Rom nächste Woche noch testen und dann mal weiterschauen.
Währe schade die Rom wechseln zu müssen:ohmy:
Hier nochmal Akku Screenshot ...
Display war wie lange an?
Die zwei Bilder kannst du sehen:winki:
Ich habe die Version seit paar tagen schon nicht mehr drauf...
Lesen kannst du:winki:
Aus den Bildern geht nämlich nicht hervor, wie lange das Display nun an war:sleep:
Und die kleinen Balken sind nicht wirklich aussagekräftig...
Da ich mein One nicht mehr habe wäre es gut wen jemand anders das hier weiter "pflegen" würde!
Wenn einer Interesse hat soll er sich bei mir oder einen der Mods/Admins melden.
Also bei 27 % Display Aktivität bei einer Handylaufzeit von mindestens 27 Stunden, macht das Pie x Daumen
27,5 h * 60 Minuten die Stunde = 1650 Minuten / 100 * 27 % = 445.5 / 60 Minuten =
7.425 Stunden Displayaktivität. Hoffe ich hab mich nicht gerade zum Affen in Sachen Mathematik gemacht und richtig gerechnet :-D
  • henschw73
ThoSta
  • raoul110
Roughneck_sp
Roughneck_sp
Blaze1984
Blaze1984
Blaze1984
