[Rom][KitKat] Android 4.4 / CM11 by ssrij
  • 28 Antworten
starbase64
starbase64
Ikone
6.515
statt zusammenzuarbeiten machen viele Dev´s ihr eigenes Ding mit CM11,
dieser hier scheint mit ganz vorn dabei zu sein was Funktionalität usw. angeht.
DevThread: [4.4] [ROM] [14/11] CM11 Beta for HTC One | ART and IR works | Gapps, SU, Busybox - xda-developers
GApps braucht ihr nicht suchen, sind integriert.
Download: m7ul_signed_112213_211453.zip (414,29 MB) - uploaded.net (22 Nov. 2013)
Files for HTC One: HTC One
Changelog
Code:
22/11 - BETA #9
- Merged latest CM/CAF commits
- Updated Superuser to latest version
- Quick Settings management enabled
- Added Google Dialer (tried and tested, works fine)
- Changed button mappings a bit
21/11 - BETA #8
-> Tap and Pay now works (it now shows up in Settings!)
-> Merged latest commits from Cyanogenmod
-> Fixed few FCs
-> Updated few gApps to latest version
-> Removed few useless stock apps
-> Enabled Quick Settings toggles
-> Updated kernel
17/11 - BETA #7
-> Fixed Exchange Service FC permanently
-> Fixed Dialer app, it's working fine now
-> Updated IR module
-> Added/Updated libs related to image editing (from Nexus 5)
-> Added some build.prop tweaks for performance/smoothness
-> Updated Google Search app to 3.1.8 so no more FC
-> Merged latest CM commits
16/11 - BETA #6
-> Fixed Google Chrome crash
-> Removed some duplicate apps
-> Switched to Superuser from SuperSU
-> Possible LTE fix (updated radio libs)
-> Possible Tap and Pay/Google Wallet fix (Google Wallet apk from Nexus 5 pre-installed)
-> Enabled overflow menu button
-> Miscellaneous optimizations/fixes
15/11 - BETA #5 (UPLOADING)
-> Fixed Audio over Bluetooth
-> Fixed WiFi not connecting bug
-> Fixed key mappings
-> Fixed updater-script bug (causing aborts for some users)
-> Fixed graphical glitches in notification area
-> Fixed Bluetooth Share FC
-> Fixed some bugs here and there
-> Updated Google Apps to latest version
14/11 - BETA #4
-> ART works (quite unstable)
-> Fixed ROM flashing error in recovery that was occurring with beta 2 and 3 builds
-> Updated SuperSU to latest version from Play Store
-> Minor fixes here and there
13/11 - BETA #3
-> Fixed IR, it's working now
-> Fixed AOSP calender crash by replacing it with Google Calender
13/11 - BETA #2
-> Updated Superuser to latest version
-> Updated busybox
-> Removed some AOSP apps (Dialer, Email, Music etc) and replaced them with Google apps (from Nexus 5)
-> Removed CM launcher and replaced it with Google Home
-> Replaced stock browser with Chrome
-> Updated some gapps
-> Emoji's fixed
-> Updated kernel to use tbalden's (sweep2wake works!)
-> Some other small fixes/optimizations here and there
12/11 - BETA #1
-> Initial build
MfG
starbase64
Reaktionen: shamanous, B3nder und mj084
Sieht gut aus, und flashbar mit TWRP :)
Bloß net fette Zip :D
Liegt an den GApps, die nehmen schon 100MB in Anspruch.
Jo schon gelesen, und auch gefragt ob der ne Version ohne anbieten könnte;)
Aber selbst ohne hätte der Build noch über 300MB, was da so groß?
Hast den bei dir schon drauf?
16/11 - BETA #6
Bekommen beim installieren immer (Status 7).
Weiß jemand, was das bedeutet?
Du musst twrp 2.6.3.3 oder cwm 6.0.4.5 haben, dann klappts.
Reaktionen: Guenni1977
Danke. Hast du nen Link dazu?
Reaktionen: shamanous und Guenni1977
Doofe Frage, Recovery aus deinem Ordner einfach flashen?
Ja, einfach flashen und los geht es.
Habe noch twrp-2.6.3.0 droben und die Installation scheitert, wahrscheinlich weil sie nicht aktuell ist...
kann ich nun die neue zip einfach drüber flashen udn dann die Rom?
ja einfach das neue TWRP drüber flashen.
MfG
starbase64
Mit diesem ROM geht es auch, weil der Erbauer das UpdaterScript angepasst hat...
Welches TWRP habt ihr denn als Recovery drauf, 2.6.3.0 geht nicht? Hat jemand ggf. einen Link zum TWRP.
Habt ihr mit der ROM auch andauernd Reboots? Außerdem stürzen bei mir sämtliche Apps immer wieder ab... So macht das mit KitKat im Moment noch keinen Spaß. Andere Kernel außer dem integrierten gibts ja auch noch nicht oder?
ich nutze es jetzt seit Tagen ohne Probleme.
MfG
starbase64
Liegt das am S-Off? Ich hab S-On und generell Probleme mit Reboots bei AOSP-Roms...
Blaze1984
Blaze1984
Blaze1984
  • raoul110
Roughneck_sp
Roughneck_sp
G00fY
HTC-Padex
