[ROM][AOSP][4.4.2][5.1.2014] SlimKat m7ul [Beta 2.1(Weekly)]
  • 43 Antworten
Dare
Dare
Stamm-User
215
Warnung: Weder das SlimRoms Team noch ich bin für eventuelle Schäden an euerm Gerät verantwortlich!
Laut SlimRom Developers Beta-Status solange nicht alle SlimRom Features integriert sind
Original Slim Features:
The Real Dark Slim
Notification Drawer Shortcuts
Vollständige Hardware Tasten einbindung!
Keyboard rotation
SlimCenter​
Vollständige Features findest du hier
Kompletten Changelog findest du hier
Changelog Beta 2.3 Weekly
  • Vendor slim: relabel dalvik-cache and wpa_supplicant correctly
    Vendor slim: get rid of compcache and zram
    Vendor slim: push up xxhdpi dpi to 370
    Vendor slim: Reorder FarEast APN
    Vendor slim: Fix internet APN for Life:) provider.
    Vendor slim: Fix Dialog Mobile Broadband MMS APN
    Vendor slim: Fixed mmsproxy for Mobinil MMS
    Vendor slim: Added APN entry for Etisalat Egypt
    Vendor slim: Fix TIM Brasil APN
    Vendor slim: Fix Giffgaff APN
    Vendor slim: Add OVIVO APNs
    Vendor slim: Fix Telenor DK MMS APN
    Vendor slim: Add b-mobile APN
    Dialer: Consistent white dialer
    Dialer: trds: dialer update
    In-Call: UI from blue to white
    Mms: improved mms bubbles
    Native: Update HWUI config for xxhdpi/2GB devices
    Settings: recover last location state during on/off switch
    Settings: Apn settings fixes / code maintainence (1/2)
    Settings: Fix FC when trying to adjust radio band via *#*#4636#*#* dialer code.
    Settings: Always show band 0
    Settings: fix exception in BatterySipper.getQuickNameIconForUid
    Settings: Dont show "Erase SD Card" when there is none
    Settings: Address adb backup/restore denials.
    Settings: Fix elapsed time formatting.
    Settings: reorder app security to top
    Settings: Bluetooth: Set alias name only through Rename option
    Settings: Bluetooth: Don't set a null alias before unpairing
    Settings: Fix null pointer exceptions in NetworkPolicyEditor
    Nfc: Fix NPE in RegisteredAidCache
    Camera2: notify the gallery that camera storage path was changed
    Camera2: add ability to call needAutoFocusCall when using continuous picture
    Camera2: fix power key shutter default behaviour
    Camera2: move back out as privileged app
    Gallery2: Storage configuration options gallery side (2/2)
    Gallery2: Fix invalid private access.
    Gallery2: jni: fix C99 inline linking
    Art: Fix NewLocalRef, NewGlobalRef to handle cleared weak globals.
    DownloadProvider: DownloadProvider: don't allow backups.
    DashClock: Fix plurals on gmail and calendar selection
    Browser: Remove Incognito mode from quick controls since it no longer exists in the ...
    Bluetooth: Fix bluetooth phonebook sync problems on some car kits
    DeskClock: Provide compatibility to existing AlarmClock shortcuts.
    DeskClock: trds: fixed bottom bar color
    Torch: move back out as privileged app
    System core: healtd: Send messages to Android log, not the kernel log
    Frameworks: services: don't clear wallpaper when SystemUI disconnects.
    Frameworks: fix remaining blue dialog dividers
    Frameworks: Sleep Screen Shortcut
    Frameworks: QS: let's welcome LocationTile to 4.4
    Frameworks: SystemUI: Add LongClick SwitchButton (1/2)
    Frameworks: trds: consistent glow for menu dropdown and popup
    Frameworks: privacyguard: Share privacy package name between activity stacks
    Frameworks: Check for homeAsUp status when collapse actionbar widget
    Frameworks: fix possible NPE on power key handling
    Frameworks: Revert "Fix a bootloop problem when /data/system/usagestats/usage-history.xml...
    Frameworks: Fix broken XML parsing idiom.
    Frameworks: XmlUtils#readThisMapXml should handle null keys.
    Frameworks: Fix appwidgets not updating
    Frameworks: Fix blacklist support
    Frameworks: Prevent nullPointerException by updateBondedBluetoothDevices
    Frameworks: NPE in SearchManager.triggerSearch
    Frameworks: Swap volume buttons when the screen is rotated by 90 or 180 degrees
    Frameworks: Show confirmation for deleted screenshot.
    Frameworks: Add same named operator configuration for some operators
    Frameworks: Fix a variety of small publicly-reported bugs.
    Frameworks: Prevent MediaScanner infinite loop with invalid path
    Frameworks: Memory leak: parseObbFile.footer
    Frameworks: fix possible buffer overrun and memory leak
    Frameworks: CompoundButton: Let text can be changed by config
    Frameworks: Re-initialize error after attach
    Frameworks: WifiState: Don't aquire transitionwakelock in airplane mode
    Frameworks: Revert "Fix for Concurrency issue reported in 525529"
    Frameworks: Use highp precision for scaled coordination
    Frameworks: NetworkPolicy: Validate policy templates before updating
    Frameworks: Clear the scan list when an empty list is received
    Frameworks: wlan: Error handling on PNO failure due to active P2P session.
    Frameworks: Close sockets on wpa_supplicant termination.
    Frameworks: add app launch timeline instrumentation
    Frameworks: wlan: Fix for delay in PNO scan trigger after p2p disconnect.
    Frameworks: get proper obb mountpoint based on user handle
    Frameworks: Framework: Minimum Vibration Duration (1/2)
    Frameworks: StatusBarWindow: Fix collapse using Back button
    Frameworks: Keyguard: smooth background change derp fixes
    Frameworks: Revert "SystemUI: update internal state right after hiding transient bars."
    Frameworks: PhoneStatusBar: fix massive surface redraws due to animation race
    Frameworks: UsbDebuggingManager: Fix multiple NPEs toggling USB debugging
    Frameworks: Don't rely on gcc extensions
    Frameworks: Fix memory leak in PatchCache
    Frameworks: Add explicit close of Scanner input
    Frameworks: fix multiuser bug in vibrator service
    Frameworks: add config.xml option to permanently force permanent menu key
    Frameworks: SystemUI: add permission.CHANGE_NETWORK_STATE.
    Frameworks: Add Long-Click to Preference Tile
    Frameworks: Custom Tiles
    Frameworks: QS: no need to rebuild the complete QS on orientation change
    Frameworks: SystemUI: Always show translucent decor on recents panel
    Frameworks: make QS again rtl aware
    Frameworks: QS: fix wrong measurement on 4 or 5 tiles per row on settings panelview
    Frameworks: Fix fatal exception due to missing looper for current thread.
    Frameworks: Cursor leakage due to cancellation signal
    Frameworks: Fix visibility of multiple non-fullscreen activities.
    Frameworks: Fix a JNI local reference leak in MediaDrm
    Frameworks telephony: do only run setCellInfoListRate for RIL version >= 8 old ...
    Frameworks telephony: Fix typo
    Frameworks datetimepicker: trds: darker time picker
    Build: qcom_utils: Update list of QCOM_BOARD_PLATFORMS
    Build: Fix cflags for QC targets
    Bionic: libc: Unbreak build for scorpion
    Telephony/InCallUI/Dialer: Remove non intrusive incall ui
    Telephony/InCallUI/Dialer: Add Incoming Call in Background
    Telephony/InCallUI/Dialer: Flip to Mute/Reject Call
    Telephony/InCallUI/Dialer:add decline and answer incoming call action on notifications
    Frameworks AV: tons of upstream in caf branch for caf based devices
    And as usual lots of device fixes, upstreams and ehancements on device and kernel level
Installationsanleitung:
Neuste Recovery musst installiert sein
Download Rom hier
Download Slim Apps hier
Backup machen!
FullWipe im Recovery
Manueller /System Wipe
Flash Rom
Flash Slim Apps
Reboot System
F.A.Q.
Source Code
Kernel Source Code
Credits
Reaktionen: Steveria, AndroidFTW, wikie und eine weitere Person
Top
Neuer Weekly-Changelog ist draußen, Jenkins hat die Builds bald fertig ;)
Dran denken ein Backup zu machen, es handelt sich um automatische Builds im Beta Status!
Grüße
Danke, ich flashe es gerade.
Kannst Du schon etwas zu der Stabilität des Roms und der Akkulaufzeit sagen?
Also die Beta 2 läuft mit teamseven Kernel super stabil :)
Komme 48 Stunden mim Akku hin.
Edit, weekly 2.1 ist raus
Reaktionen: MarkusK
Guten Abend,
Gibt es bei Slimkat auch diesen Knopf der im Taskmanager alle Programme schließt? Finde ihn nicht. Fand das eigentlich immer ganz gut.
Liebe Grüße Jochen
Hallo erstmal, es ist nicht gern gesehen die selbe Frage in mehreren Threads zu stellen ;)
Zur Zeit gibt es diesen Button nicht, wird evtl nach der Beta Phase kommen.
LG
Ja mein Fehler, tut mir leid. Fand aber keine Option in tapatalk die Frage zu löschen. Und irgendwann war es vergessen. ;-) Entschuldige und Danke für die prompte Antwort.
Reaktionen: Dare
Könnte man den nicht über xposed und Gravitybox nach installieren? Kann mich aber auch irren
Gesendet von meinem HTC One mit der Android-Hilfe.de App
bauernfeind schrieb:
Guten Abend,
Liebe Grüße Jochen
Wird nicht mehr kommen - es ist kontraproduktiv alle Apps zu löschen / schliessen. Was nicht mehr gebraucht wird, einfach raus wischen und gut ist ;-)
Wahnsinn wie gut diese Rom läuft... Was ich nicht gefunden habe ist slimpie... Für im ich ein sehr wichtiges Element... Weiss einer ob das noch kommt?? Oder finde ich es einfach nicht??
Slim Pie ist noch nicht integriert, deswegen auch noch "Beta Status" der Rom, obwohl sie stabil läuft!
Wenn alle bzw. die meisten Slim Features integriert sind, (wo Pie wohl auch dazu gehören soll), wird es Stable Releases geben.
Weekly 2.3 ist draußen, Startpost angepasst.
Reaktionen: Freshmaker
Hallo Leute,
hab die rom auf dem S3 meines Bruders installiert und finde Sie dort echt gut.
Wie sieht es aber mit dem Sound beim One aus? BeatsAudio ist dann ja nicht mehr.
Der gute Sound war bisher der einzige Grund nicht von Sense zu wechseln
Der Sound ist super wenn du Viper 4 Android installierst, is ne super Sound app!
Reaktionen: cmd500
bin ich grad eben drüber gestolpert. :) danke für den Tip. ist der Sound damit ähnlich gut wie mit beats?
Ist ähnlich gut, wenn nicht sogar besser, alles subjektiv ;)
Einfach ausprobieren, lässt sich problemlos deinstallieren!
Und PIE kann man ja einfach über LMT nachinstallieren. Ist eh besser als die vielen "kastrierten Pies", die einige Rom-Köche verwendet.
Changelog:
Changelog:
  • New devices: p5100 and p5110
  • Frameworks base: Fix Derp in Chamber of secrets
  • Frameworks base: Appears black screen fix for a while
  • Frameworks base: AssetManager cookies should be int32_t and not void*.
  • Frameworks base: Fix dest == src bugs in Matrix.cpp.
  • Frameworks base: Fixed race condition in Spinner.DialogPopup on null reference.
  • Frameworks base: [ActivityManager]: Fix the activity visibility state not sync between ...
  • Frameworks base: GpsLocationProvider: look for config file in /etc/gps.<ro.hardware.gps>.conf
  • Frameworks base: Framework: Super advanced Custom Toggle
  • Frameworks base: implement noise suppression for phone calls
  • Frameworks base: fb: handle for our navigation bar recentspreload in the button
  • Frameworks base: SystemUI: Fix missing top task in recent panel.
  • Frameworks base: fb: handle globalmenu in SlimActions not over Powerbutton anymore
  • Frameworks base: Perform NTP lookup at Mobile data connections
  • Frameworks base: fb: unbreak recents animations on thumbnail click or dismiss recents screen
  • Frameworks base: fb: Handle navbar heights correct on dpi changes + more
  • Frameworks base: fix search textfield
  • Frameworks base: fix number picker blue line and highlight
  • Frameworks base: Fixed cancel() not working correctly
  • Frameworks base: Fix the issue that the top of fullscreen dialog is clipped away
  • Frameworks av upstreams
  • InCallUI: do not use reflection
  • Bluetooth: roll back phonebook sync changes
  • Bluetooth: Fix BT failed to enable issue.
  • Telephony: White emergency dialer
  • MediaProvider: Allow holders of WRITE_MEDIA_STORAGE to write to secondary external storage
  • Mms: Fix Null pointer expection when Phone is in low memory
  • Mms: The draft still exists after forwarding mms to the same sender
  • Mms: Display message type properly for MMS and SMS
  • Mms: Resize the image in background
  • ContactsProvider: make lookupAndCacheId() synchronized
  • Torch: add 2nd sysfs luminosity
  • Settings: 'When to daydream' dialog does not follow the JB dialog design guide
  • Settings: Bleed keyguard widget picker list into translucent bars
  • Settings: Fix memory leak in ManageApplication
  • Exchange: Fix mismatched function arguments in Contact query
  • Camera2: add option to prevend autofocus cancel if preview stopped
  • Camera2: Add an option to maintain the focus mode when using touch-to-focus
  • DashClock: fix dialog blue divider
  • Email: trds: fix white bg on email compose for sw600dp
  • Browser: Implement client-side incognito mode
  • Browser: Show a startup page in incognito mode
  • Browser: blue to grey browser's progress bar
  • Gallery2: gallery: change typo '&&' to '||'
  • SlimCenter: improve navigation
  • Bionic: Fix problems with certain games and apps
  • Bionic: fix toro and toroplus problems
  • Several translation updates
  • A lot small fixes
  • For device specific changes check the changelog which is published on the download section.
  • And as usual a lot device tree upstreams, fixes and ehancements
ROMS
GAPPS *new version of photosphere
Guten Morgen, die Symbole sind doch etwas klein. Weiß jemand wir man die Größe ändern kann? In den Launcher Einstellungen steht bei dem Punkt... nur in der Pro Version verfügbar. Gibt es noch eine andere Möglichkeit?
Blaze1984
Blaze1984
Blaze1984
kallehagen
  • raoul110
Roughneck_sp
Roughneck_sp
