Mucky2
Dauer-User
- 406
Device: m7 (HTC One)
Quote:
Alles was ich getan habe ist, dass ich neue sourcen komplimiert habe um euch diese Builds zu geben. Meine Ganze arbeitet habe ich hier verrichtet: https://github.com/htc-msm8960 - Danke an diese Leute, sie arbeiten hart um AOSP auf unserem Gerät zu bringen. Danke an folgende Entwickler: h8rift, intervigil, toastcfh, deck, Flinny, Flemmard, Codeworkx, birdman
Das bedeutet, dass hier die gleichen Bugs wie in anderen AOSP Builds auftauchen.
» Die Installation ist einfach:
- If coming from another ROM or another major AOKP version, wipe data in recovery
- Make sure you're using the latest CWM or TWRP
- Flash ROM
- Flash Google Apps (GAPPS)
- Reboot
Code:
May 11 - birthday edition!- updated device sources from CM- included my bug fix for a tiny kernel glitchsome broken things/tips:- taking pics with ffc- taking pics with flash off will produce bad picture (leave it auto)- outgoing calls (for me) don't work after the first one. toggling noise suppression in phone settings seems to reset the speaker behavior after every call. not sure if this works all the time. - not sure about BT yet- oh! make sure to toggle CRT on/off in rom control > general ui, seems to make the screen behavior better when turning it off and on- check settings > device options for neat things CM guys added!May 6- upstream changes- fixed a silly error in my source--- seems the build was missing a bunch of flags--- result: butter injection / stability improvementsMay 5- upstream changes https://github.com/htc-msm8960/-- device settings (vibration config)May the 4th- be with you
» Check merged commits on AOKP's Gerrit
build: Goo.im Downloads - Browsing aokp_m7 - Meine Nightlys sind in diesem Ordner. Ich versuche auch, sie hier unterzubringen AOKPush
gapps: Goo.im Downloads - Downloading gapps-jb-20130301-signed.zip - b7e53e96e1c8b1a1c4865bf29418c8e0
» Building AOKP for your m7
- First, create file .repo/local_manifests/m7.xml with the following contents: https://gist.github.com/romanbb/5517890
- repo sync
- Next, edit devices/htc/msm8960-common/Android.mk and comment out all the lines with # (or delete them, don't delete the actual file). For some reason this commit wasn't doing the trick for me.
- delete file: device/htc/m7-common/overlay/packages/apps/Settings/res/values/arrays.xml
- open device/htc/m7-common/overlay/frameworks/base/core/res/res/values/config.xml, (line 86) find <integer name="config_deviceHardwareKeys">3</integer> and delete that line.
- Finally, cherry pick this: Gerrit Code Review
- Build as usual
» AOKP on Github
» SOURCE on AOKP.co
Wir freuen uns sehr auf code, oder PayPal spenden.
» Spenden gehen an AOKP.com
Genieße es!
Quelle: http://forum.xda-developers.com/showthread.php?t=2264416
