[ROM][5.0.2][OFFICIAL] LiquidSmooth v4.0 | Lollipop | m7 [01-16-15]
  • 5 Antworten
der_berliner
der_berliner
Stamm-User
260
LiquidSmooth enthält folgende Features
* ROM built with SaberMod 4.8.4 GCC Toolchain
* Kernel built with SaberMod 4.9.3 GCC Toolchain
* Updated Linux to 3.10.62 * LCD KCAL control
* Disabled forced encryption
* Tweaked CPU governors (more gov's to come)
* ARM Optimized String Handling Routines
* Linaro and Code Aurora Optimizations
* Gesture Anywhere
* Gesture unlock
* Battery icon options
* SlimRoms Headsup customization
* Custom toast animations
* Option to disable screenshot noise
* Built in superuser options with Root access options
* Call blacklist options
* SMS rate limiting option
* Filter spam notifications
* Per app control for Lockscreen notifications
* Configurable 0, 90, 180 and 270 degree rotation
* Safe headset volume option
* Less annoying sound notifications option
* Option to use volume keys to control media volume anytime
* Option to customize device hostname
* Option to not wake up device when charge is plugged/unplugged
* Volume rocker wake up
* IME switcher notification control
* Option to disable fullscreen keyboard
* Force autorotation on IME
* Option to force show enter key
* CM's Privacy Guard
* Increasing ringtone option
* Dark UI (primarily in Settings for now)
* Screen Density changer
* Statusbar clock customization
* Option to disable searchbar in recents
* Statusbar brightness control
* Double tap statusbar to sleep control
* Custom Lockscreen shortcuts
* Extra info about your device (About phone/tablet)
* Custom Liquid Logo in about phone/tablet
* Google bug report and ota removed
* Option to show kernel toolchain and other info by tapping kernel version in about phone/tablet
* Timeout and instant lock options added to slide unlock instead of just secure keyguard options
* Developer options enabled by default
* Navigation bar height control
* Show application package name in app info
* LiquidSmooth Stats and Updater added
* Partition size info
* Option to disable immersive messages
Check our Google+ for updates
Source Links
Code:
LiquidSmooth Github LiquidSmooth Kernel Source
Download Links
Code:
ROM Download - v4 Nightlies Lollipop Gapps Download ( or use whatever works for you)
Screenshots
Kernel source: Link
Kernel source - MLG: Link
XDA:DevDB Information
[ROM][5.0][OFFICIAL] LiquidSmooth | Lollipop | m7 | v4.0 Alpha, ROM for the HTC One
Contributors
santod040
Source Code: https://github.com/LiquidSmooth/
ROM OS Version: 5.0.x Lollipop
ROM Kernel: Linux 3.4.x
ROM Firmware Required: latest kitkat
Based On: AOSP, Cyanogenmod
Version Information
Status: Beta
Current Stable Version: v3.1 6-10-14
Stable Release Date: 2014-06-10
Current Beta Version: v4.0
Beta Release Date: 2014-02-12
Created 2014-02-16
Last Updated 2015-01-16
Guten Abend,
wer eine schlanke und schnelle Rom sucht wird hier fündig. Für eine gerade einmal 256 MB große Custom Rom bekommt hier jedeR eine Menge an Einstellmöglichkeiten. Wer aber sehr viele Einstellmöglichkeiten haben will ist bei dieser Rom definitiv fehl am Platz. Demjenigen kann ich nur eine Rom mit Sense empfehlen.
Ich habe die Rom nun getestet und es gab keinen FC oder Reboot und auch kein "wird beendet". Alles läuft Butterweich, eben "Smooth". Der Batterieverbrauch ist normal wird aber höher wenn man im Inet unterwegs ist. Denke mal das ist normal. Der auf der XDA empfohlene Kernel lässt sich nicht OC/UC. Hier der Link zum Kernel
https://www.androidfilehost.com/?fid=95864024717072018
und hier der Link zum Originalthread auf XDA
http://forum.xda-developers.com/showthread.php?t=2472604
Meine Lieblingsicons, CM 11, wurden anstandsloss installiert nicht so bei meinem Thema, auch CM11. Es wurde zwar installiert doch danach gab es ein bisschen Stress. Also, Finger weg von CM11 Themes. Habe noch ein paar Screenshots gemacht damit ihr Euch ein besseres Bild von der Rom machen könnt.
Euch allen noch einen schönen Sonntag
Kann man den Beats Audio EQ und die HTC TV App auf der ROM zum laufen bekommen?
Was macht ihr eigentlich mit den spenden? Spritzt ihr die in die Venen? Besorgt euch mal Server welche etwas schneller sind
Wird die ROM auch mal geupdatet?
Hat ja seit dem letzten Update Soundbugs.
Oder hat jemand Tipps wie ich die umgehen/fixen kann?
Hallo liebe leute,
habe die Rom auf mein M7 installiert (Unlocked, S-On).
Habe eben erst bemerkt, dass es nicht der Stock Kernel ist.
Meine Frage, ob deswegen Funktionen wie Mikrofon und Lautsprecher nicht funktionieren?
Gruß broken09
Normal läuft alles, aber da hast dir ne Rom ausgesucht die seit Ewigkeiten kein update mehr bekommen hat. Da gibt's Roms die zumindest ein wenig aktueller sind
  • henschw73
ThoSta
  • raoul110
Roughneck_sp
Roughneck_sp
Blaze1984
Blaze1984
Blaze1984
