AICP Android Ice Cold Project
  • 74 Antworten
Scum
Scum
Moderator
Teammitglied
10.274
Der eine oder andere wird die Roms von LorD ClockaN noch von DesireHD sehr gut kennen ...
AICP
<u>In the beginning I would like to thank:
  • AOKP team
  • CM team
  • maxwen
  • SlimBean rom team
  • ParanoidAndroid team
  • CarbonRom team
  • LiquidSmooth rom team
  • Omni rom team
  • Community
AICP m7 dev team:
  • @LorD ClockaN
  • @zipsnet
  • @n3ocort3x
  • @semdoc
  • @eyosen
DONATIONS:
We are now paying for servers that build nightlies and everything that comes with it, so EVERY DONATION is going there.
Thank you!!
What is AICP?
AICP is known by someone as Ice Cold Project that started on Desire HD and since than evolved as a mature rom with the BEST community you can find!!!
Rom has always been AOKP based so expect all AOKP goodies + new additions.
If there are any bugs, either we will sort them or AOKP team if it conserns their modifications. This rom isn't AOKP supported so no need to report errors or bugs to them!!
LATEST STABLE RELEASE + CHANGELOG (INCLUDED IN DL LINK)
Download: LINK
Actual version: AICP 3.0 - 28-02-2014
What's New
  • MMS: allow 6 line text input field
    MMS: few APN fixes
    MMS: Enter key: force newline
    Dialer: Open source google dialer and more
    Dialer: Add WhitePages Canada reverse lookup provider
    Contacts: support for import contacts to local phone storage
    Contacts: few patches
    Screen recorder: add audio support
    Screen recorder: settings
    Toggles: longpress Torch to get into WhiteScreen
    Framework AV patches
    Add ADB Paranoia mode
    Recents clear all button position
    Ad blocker
    TeloRadio
    New Halo Icon
    NFC polling mode
    frameworks: Hope systemui improved battery life
    Add 0.25x animation scale fof
    Port BatteryBar
    OmniSwitch as default for recents
    Add Download Speeds in notification
    Hebrew T9 for Dialer
    Greek T9 support for Dialer
    LatinIME: Add more emoticons
    LatinIME: Add more extended ASCII characters
    Left handed navbar for landscape mode
    Updated translations
    Bugfixes
    Updates to kernel
    And a lot more that didn't fit in here
KERNEL:
Kernel in this rom follows CM source with additions from @n3ocort3x so maybe you don't have to automatically search to flash new kernel after flashing rom. This kernel will also be continuously updated with patches and features.
CUSTOM KERNEL SUPPORT (teaMseven Kernel):
Please flash CM11 version (v54) ->STOCK in this ROM, no need for more :)
Feature list:
  • AOKP features
  • TRDS Dark switch
  • Halo
  • OmniSwitch
  • Profiles
  • Lockscsreen Notifications
  • Active Display
  • Wakelock blocker
  • System app Remover
  • Animations
  • Lockecreen color theming
  • Lockscreen blur, gestures etc...
  • etc...
IceColdJelly AICP G+ community
What's Broken:
ROMS
ROMS should contain everything you need to enjoy JB. You are not required to install any Add Ons, simply download the latest ROM, gapps, flash it, and go!
You are STRONGLY recommended to fully wipe your device before flashing, and if possible avoid restoring system apps and system data with Titanium Backup - these can cause stability issues that are very hard to debug. If you believe you know what you're doing - then fine, go ahead, but please don't complain if you experience strange behavior.
How to flash:
  • Don't do it if you don't know it
  • ROM has gapps persistance in between dirty flashes
You want to see a normal night at the DEV office, click here!!
If you want to contribute to the AICP or wanna see what is being worked on/merge feel free to visit our gerrit, link is at the bottom!!!
kernel git
rom gerrit
XDA:DevDB Information
[ROM] [28FEB] AICP - 3.0 - KK 4.4.2_r2, a ROM for the HTC One
Contributors
n3ocort3x
Version Information
Status: Stable
Stable Release Date: 2014-02-28
Created 2014-02-01
Last Updated 2014-02-28</u>
Dazu könnt ihr folgende mini gapps flashen!
Die neuste Nightlie´s ink. Changelog ist hier zu finden:
AICP Downloads
Reaktionen: petzim11, Samador und Røøki
Würde dir Aktuelle SuperSu Falshen ...
Erst nach dem Flash funktioniert bei mir TitaniumBackup problemlos!
Gefällt mir bis jetzt sehr gut!:thumbsup:
Habt Ihr zufälligerweise eine andre Bezugsquelle? Die Webseite ist schon seit Stunden down.
Hier bitte ...
Latest Stable Release
Download: Zippyshare.com - aicp_m7-kitkat-V2.0-20140205.zip
Actual version: AICP V2.0 - 05-02-2014
What's New
  • Hard to put ALL the merged patches in this little space
  • AICP merged gerrit: Gerrit Code Review from the patch: ADD: AICP RELEASE VERSION on Feb 1
  • AOKP merged gerrit: Gerrit Code Review from the patch: Updated Simplified Chinese translations (first one) on Feb 2
  • Kernel has been HEAVILY updated by @n3ocort3x
  • Sorry for this, but it's the best I can do
  • If you have questions, ask away :D
Reaktionen: MarkusK
Danke, habe es jetzt bereits 2x runtergeladen, aber das Gerät bleibt in einem schwarzen Screen hängen. MD5-Summe bei beiden Downloads ist identisch.
4772a26c5db6a3a206995d66b23a2528
Habe natürlich gewiped usw.
Gibt es noch etwas anderes zu beachten? die Gapps hätte ich nach einem Reboot drübergebügelt.
:confused2:
Eigentlich nicht. Flashen und Spaß haben.
Die neu Version habe ich noch nicht drauf da in letzten tagen einige andere Roms kamen die ich gerade ein wenig teste...
Okay -dann warte ich mal auf die nächste Version :)
Hatte keine Probleme mit der Installation.
Ein Problem ist mir aufgefallen, wenn man aicp_gapps-modular-mini-4.4.2 installiert, kann man in den Themen nicht AOKP KitKat White wählen, da die Auflösung nicht mehr stimmen.
Sonst eine klasse und schlichte Rom.:thumbup:
Habe es gerade nochmals versucht: Ich habe vor und nach dem Flashen gewiped, jetzt klappt es. Macht einen wirklich guten Eindruck, mal sehen wie die Akkulaufzeit so ist :)
Was noch auffällt, ich muss öfters meinen Pin eingeben, als wenn das One neustarten würde! :(
Meine Pin musste ich noch nie eingeben- Eigenartig...
Komisch...passiert so ca. nach 45min, wenn ich das One nicht benutze...kann auch nicht am Kernel liegen, weil ich auch den team7 probiert habe! :(
Fullwipe und selbst nach einem Guru...no way...
Nein, habe keinen alternativen Kernel ausprobiert. Müsste daran liegen :)
Ja eben nicht...Stock, oder Custom-Kernel, ist egal, gleiches Phänomen!:sad:
Welche Firmware hast du denn drauf?
Muss ich heute Mittag mal schauen ob ich dazu komme die 2.0 zu flashen!
Bei der 1.0 war/gab es dieses Phänomen nicht ...
Vielleicht liegt es auch an den Minigapps, die ich mit installiert habe...fällt mir gerade so ein! :)
Kann ich mir nicht vorstellen. Sitzt Deine Sim-Karte fest im Slot? Vielleicht verliert sie ja manchmal den Kontakt und muss so immer neu eingeloggt werden. GGF mit einem Streifen Tesafilm auf der Rückseite für mehr Halt sorgen? Selbst nach einem deepsleep halte ich es für mehr als unwahrscheinlich dass die Karte neu einbucht werden muss. ;)
Hast Du das Problem denn nur bei diesem Rom?
Ja, nur mit dieser Rom.
Habe es nun noch mal neu geflasht, mit den neusten Minigapps und richte es gerade neu ein...bin mal gespannt! :)
€dit: Läuft bis jetzt...wie hoch sind denn eure Cores getaktet...bei mir mit Stockkernel alle 4 auf 1998MHz?!:ohmy:
Die Leistung im AntutuBenchmark (ca. 27000) ist aber eher schwach, für 2GHz...
Ich habe keinen alternativen Kernel installiert, dieses ganze Rumschrauben an der Geschwindigkeit bringt meiner Meinung nach eh kaum Performance und führt höchstens zu einem Akku der schneller leer ist.
Aber vielleicht könntest Du mal testen, ob man mit dem das Gerät mit der Volume-Taste aus dem DeepSleep holen kann? ;)
Q
iL_CoDiNo
I
Blaze1984
Blaze1984
Blaze1984
Q
QBoSsQ
Q
