Scum
Moderator
Teammitglied
- 12.210
- Themenstarter
- #41
V3.5 finals have started rolling out of jenkins...
so check download link for your device.
Those on nightlies should be getting OTA notification.
Just a reminder, that I also put up in the OP and in the new version of OTA app the you'll be getting.. Flashing with OTA app is ONLY possible if you're on TWRP recovery. If not, than just manually go to recovery and flash after OTA app downloaded.. FIle should be located in AICP_ota folder. No need to reflash gapps as before.
