Einmaliger, anonymer Poster
Gast
vielen Dank erstmal für die Mühe, die man sich hier gemacht hat.
Kurz und schmerzlos:
Xperia Go, Ubuntu 12.04
Ich bin wohl schlicht zu blöd. Flashtool sagt:
26/037/2013 07:37:34 - INFO - Now open your device and restore "RootMe" backup. Waiting ...
26/037/2013 07:37:34 - INFO - You have 60 seconds to follow the restore advice
26/037/2013 07:37:34 - INFO - Running adbrestoreexploit
26/037/2013 07:37:35 - INFO - Restore worked fine. Rebooting device. Please wait ...
26/037/2013 07:37:38 - INFO - Waiting for device
26/037/2013 07:37:38 - INFO - Device disconnected
26/037/2013 07:37:45 - INFO - Device connected with USB debugging off
26/037/2013 07:37:45 - INFO - For 2011 devices line, be sure you are not in MTP mode
26/037/2013 07:37:47 - INFO - Device connected with USB debugging on
26/037/2013 07:37:48 - INFO - Root hack did not work.
26/037/2013 07:37:48 - INFO - Cleaning hack files
26/037/2013 07:37:49 - INFO - Rebooting device. Please wait.
26/037/2013 07:37:49 - INFO - Device disconnected
26/037/2013 07:37:56 - INFO - Device connected with USB debugging off
26/037/2013 07:37:56 - INFO - For 2011 devices line, be sure you are not in MTP mode
26/037/2013 07:37:57 - INFO - Device connected with USB debugging on
26/037/2013 07:37:57 - INFO - Connected device : ST27
26/037/2013 07:37:57 - INFO - Installed version of busybox : N/A
26/037/2013 07:37:57 - INFO - Android version : 4.0.4 / kernel version : 3.0.8+ / Build number : 6.1.1.B.1.54
Was's da los?
Ich lese die Anleitung meist doch recht gewissenhaft und es ist nicht das erste Telefon, dass ich roote, aber irgendwie...
Viele Grüße
Was's da los?
Viele Grüße
