[Anleitung] Bootloader öffnen/schließen
  • 257 Antworten
Sagte ich doch und wieso sollte es beim zweiten mal anders sein als beim ersten mal?
also ich habe jetzt versucht über ta backup meinen bootloader zu schliesen ,will ja das update drauf machen.er erkennt mein handy ich kann auch mein backup aus wählen aber nach dem restart ist alles beim alten ...
03/054/2015 00:54:51 - INFO - Flashtool Version 0.9.18.4 built on 12-05-2014 22:00:00
03/054/2015 00:54:51 - INFO - Executing search strategies to find proxy selector
03/054/2015 00:54:51 - INFO - No proxy found for IE. Trying next one
03/054/2015 00:54:51 - INFO - Strategy firefox failed trying next one : No Firefox installation found
03/054/2015 00:54:51 - INFO - No proxy found for java. Trying next one
03/054/2015 00:54:51 - INFO - Syncing devices from github
03/054/2015 00:54:51 - INFO - Scanning devices folder for changes.
03/054/2015 00:54:55 - INFO - Pulling changes from github.
03/054/2015 00:54:55 - INFO - Devices sync finished.
03/054/2015 00:54:55 - INFO - Device connected with USB debugging on
03/054/2015 00:54:56 - INFO - Connected device : Sony Xperia Z3
03/054/2015 00:54:56 - INFO - Installed version of busybox : BusyBox v1.20.2-jb static (2012-11-25 17:47 +0100) multi-call binary.
03/054/2015 00:54:56 - INFO - Android version : 4.4.4 / kernel version : 3.4.0-perf-g1b1963a-02930-g23f7791 / Build number : 23.0.1.A.5.77
03/054/2015 00:54:56 - INFO - Checking root access
03/054/2015 00:54:56 - INFO - Root Access Allowed
03/055/2015 00:55:05 - INFO - Please connect your device into flashmode.
03/055/2015 00:55:08 - INFO - Bootloader unlock canceled
03/056/2015 00:56:13 - INFO - Please connect your device into flashmode.
03/056/2015 00:56:22 - INFO - Device disconnected
03/056/2015 00:56:48 - INFO - Device connected in flash mode
03/056/2015 00:56:49 - INFO - Opening device for R/W
03/056/2015 00:56:57 - INFO - Processing loader.sin
03/056/2015 00:56:57 - INFO - Checking header
03/056/2015 00:56:57 - ERROR - Processing of loader.sin finished with errors.
03/056/2015 00:56:57 - INFO - Your phone bootloader cannot be officially unlocked
03/056/2015 00:56:57 - INFO - You can now unplug and restart your phone
das kommt im flashtool.
Weil dein Bootloader wahrscheinlich nicht entsperrt werden kann, wie Flashtool es auch anzeigt.
Der ist ja schon entsperrt. Ich will ihn wieder schließen
Einfach oefter probieren, Flashtool zickt gerne mal
Hmm ich kann auch nirgendwo relock drücken so wie es in der Anleitung steht.
Flashtool und ta backuptool sind zwei paar Schuhe.. Ta backup tool ist die bessere alternative weil so eben die DRMs zurück kommen.. Ist das Handy gerootet?
Ja es ist gerootet
Was sagt das Service menu?
Also wenn man sich das verlinkte Bild so ansieht sieht soweit alles ganz in Ordnung aus und den Rest sollte man wie von "Aaskereija" bereits angemerkt über das ServiceMenü kontrollieren können.
Zum einen sollte unter "Servicetests - Security" sämtliche Keys auf OK und Active stehen und unter "Serviceinfo - Configuration" sollte bei Rootingstatus
Bootoader unlock allowed:Yes stehen.
Das solltest halt mal soweit kontrollieren und hier als Rückmeldung geben!
Gruß,
snoopy-1
Ok es hat anscheinend alles geklappt. Im Service Menü ist alles auf ok und yes.Mein Fehler war wohl das ich das update machen wollte als es noch gerootet war.Ich hab einen wipe und dalvik wipe gemacht danach konnte ich einfach updaten. Danke für die Hilfe. Kann ich jetzt einfach wieder rooten? Bzw sollte ich dann ein ein neues Backup machen?
Verstehe ich das jetzt richtig und du hast zuerst mal die ganze Aktion gemacht um das Original Lollipop Update zu machen und willst jetzt diese wieder rooten und danach evtl. auch den Bootloader wieder öffnen?
Sorry, wenn dem so sein sollte, dann würde ich dir empfehlen dich nochmal genau zu den Themen einzulesen. Normal macht man das einlesen bevor man mit irgendwelchen Aktionen beginnt. Nur mal soviel, die aktuelle Version kann man nicht so einfach direkt rooten, da musst du leider ein paar Umwege gehen, die nicht gerade mit deinen aktuellen Aktionen vereinbar sind!
Besser wärst mal da geblieben wo du schon warst und hättest von da aus weiter gemacht.:winki:
Gruß,
snoopy-1
Ich bekomme von Sony diesen Link nicht, komme also nur bis schritt2. Habe drei Email Adressen angegeben, aber passiert nix. Jemand ne Idee?
Ägruss
Internationale emailadresse nehmen.. Deutsche gehen nicht richtig
Also gmail.com und icloud.com sind doch internationale,oder???
Welcher Anbieter wäre das.
TechEmail.com z. B.
Reaktionen: riskis
Ich hatte seinerzeit gmail genutzt und das funktionierte einwandfrei.
@riskis
Eigentlich habe ich dir den Link im anderen Thread gegeben mit dem Hinweis dich hier erst mal einzulesen und nicht gleich wieder den selbigen Beitrag abzusetzen. Das ganze Thema mit den Mails ist hier alles schon mal durch, auch wenn ich für mich es nicht nachvollziehen kann und scheinbar auch andere nicht!
Gruß,
snoopy-1
Hi Leute bei mir steht leider Bootloader unlock allowed: NO
Mein Handy kommt aus Canada.
Gibt es einen Weg um das auf Yes zu stellen?
Viele Grüße!
Aaskereija
Aaskereija
Aaskereija
Willi1658
Aaskereija
aguilucho
