[HowTo] Standard SE 2.1 ROM - Tuning/Anpassung [Anleitung]
  • 16 Antworten
UKSheep
UKSheep
Dauer-User
569
dieser Thread soll dazu dienen, zu erklären welche Apps man aus dem Standard SE Rom entfernen kann und wie ihr euer System so weit Optimiert, das euer X10 um einiges besser läuft.
Auflistung der Apps die entfernt werden können.
Code:
[I]
[LIST]
[*][B]Nordic Apps ([COLOR=Red]Only in Generic Nordic ROM[/COLOR])[/B]
[LIST]
[*] /system/etc/customization/applications/Supernytt.apk
/system/app/Telenor_Wrapper.apk
/data/app/com.apegroup.aftonbladet.supernytt.zip
/data/app-private/com.apegroup.aftonbladet.supernytt.apk
[/LIST]
[LIST]
[*] [B]Backup And Restore[/B]
apk: backupandrestore
[*] [B]Documentation[/B]
apk: EManualLauncher EManual usersupport
[*] [B]Creatouch (SE)[/B]
apk: creatouch
[*] [B]DebugHelper (Service)[/B]
apk: CrashSMS
[*] [B]Digital Clock (Widget)[/B]
apk: DigitalClockWidget
[*] [B]Facebook (Client)[/B]
apk: facebook
[*] [COLOR=Red][B]Face Recognition (Service for Camera)[/B][/COLOR]
apk: FaceRecognition
Drawbacks:
[LIST]
[*]Face Recognition doesn't work anymore
[/LIST]
[*] [B]Learning Client (Service)[/B]
apk: LearningClient
Drawbacks:
[LIST]
[*]Word-Learning for the default keyboards is removed.
[/LIST]
[*] [B]Live Wallpapers (Wallpapers only)[/B]
apk: LiveWallpapers MagicSmokeWallpapers VisualizationWallpapers
Drawbacks:
[LIST]
[*] Only Google Maps Live-wallpaper left
but market live-wallpapers still work
[/LIST]
[*] [B]MediaScape[/B]
apk: mediascape MediaScapePluginManager
Drawbacks:
[LIST]
[*] Camera App is hard-coded to use Mediascape for Gallery/Share.
Vignette Does well but doesn't help in Video mode.
Means: No easy sharing/viewing for taken videos
[*] No easy way to create a wallpaper from taken pictures.
[*] No way to set contact picture from phonebook. Need to go through Gallery3D instead.
[/LIST]
[*] [B]MoxierMail[/B]
apk: moxiermail
[*] [B]Music Player (Hidden)[/B]
apk: Music.apk
[*] [B]OfficeSuite[/B]
apk: officesuite
[*] [B]PC Companion (PC-Sync Service)[/B]
apk: PcCompanion
[*] [B]PlayNow[/B]
apk: playnow*
[*] [B]Quadrapop (Game)[/B]
apk: quadrapop
[*] [B]Recent Calls (Widget)[/B]
apk: RecentCalls
[*] [B]Status Switch (Widget)[/B]
apk: StatusSwitch
[*] [B]Sony Ericsson Synchronisation[/B]
apk: Sync SyncWizard OmaDatasyncService
[*] [B]Search (Widget)[/B]
apk: SearchWidget
[*] [B]SetupWizard[/B]
apk: SEMCSetupWizard
[*] [B]TimeScape[/B]
apk: Timescape* TimeScape*
[*] [B]TrackID[/B]
apk: trackid
[*] [B]Voice Dialer[/B]
apk: VoiceDialer
[*] [B]Wallpaper Chooser (Selector in Titanium)[/B]
apk: Wallpaper Chooser
standard wallpapers: /etc/customization/content/com/sonyericsson/android/wallpaperchooser/wallpaper/
Drawbacks:
[LIST]
[*] No Standard Wallpapers available anymore
Workaround: Get "Wallpaper Set and Save" from Market
[/LIST]
[*] [B]Wisepilot[/B]
apk: wisepilot
[*] [B]YouTube[/B]
apk: YouTube
[/LIST]
[*] [B]Excess Keyboards[/B]
Note: Keep one of these around, so you can type [IMG]http://media.xda-developers.com/images/smilies/wink.gif[/IMG] Or install some Keyboard from the Market before you remove these.
[LIST]
[*] [B]SE Default English[/B]
apk: textinput-tng
[*] [B]Chinese[/B]
apk: chinesetextinput
[*] [B]Danish[/B]
apk: Danish_Keyboard
[*] [B]English[/B]
apk: LatinIME
[*] [B]Korean[/B]
apk: SEMCTouchPalKoreanQWERTY
[*] [B]Japanese[/B]
apk: JapaneseIME
[/LIST]
[/LIST]
[/I]
- wird noch ins Deutsche übersetzt !!! THX @ ttxdragon
Nun eine kurze Erklärung zu dieser App/apk
  • Face Recognition (Service for Camera)
    Drawbacks:
    • Face Recognition doesn't work anymore
Dieser Service prüft im Hintergrund ob auf der SDKarte Foto´s vorhanden sind... auf denen das Gesicht eines eurer Kontakte vorhanden ist...
Wer Time- und Mediascape schon vom System entfernt hat, der sollte auf jedenfall auch den FaceRecognition Service löschen...
Wer Time- und Mediascape weiterhin nutzt, sollte sich evtl Gedanken machen ob der Service so Wichtig/Nützlich ist...
denn er verbraucht viele System Ressourcen und das X10 läuft ohne den Service merklich schneller.
Wie entferne ich die Apps die ich nicht benötige ???
Ihr benötigt dazu root Rechte. Ihr werdet euch evtl fragen was denn root Rechte sind :) deswegen eine kurze Erklärung.
Root bei Linux ist in etwa wie Administrator bei Windows :) Ihr erlangt also mehr Rechte, die manche Programme benötigen. (um z.B. Systemprogramme zu entfernen)
Downloads:
1. z4root.1.3.0.apk | Mirror1 | Mirror2
2. Busybox - Market
3. Titanium Backup - Market
Diese drei Apps müsst ihr installieren... in der gleichen Reihenfolge wie aufgelistet. z4root & Busybox müssen jeweils installiert werden... und danach einmal ausgeführt werden...
Habt ihr das alles erledigt, könnt ihr Titanium Backup starten.
Nun drückt ihr auf "Sichern/Wiederherstellen" es erscheint eine Liste alle Apps die auf eurem System installiert sind.
Anhand der Liste oben könnt ihr nun entscheiden welche Programme ihr entfernt... wollt ihr z.B. "creatouch" entfernen, scrollt ihr runter bis "creatouch" und drückt drauf.
Es öffnet sich ein Popup wo ihr auswählen könnt was ihr mit der Datei macht. Es ist nicht verkehrt vor dem Deinstallieren eine Sicherung anzulegen. Solltet ihr keine Sicherung benötigen,
könnt ihr auch direkt auf Deinstallieren! drücken.
Time- und Mediascape ersetzen!!!
Bei Android ist eine 3D Gallery und ein standard Music Player integriert... SE hat diese aber gut versteckt :) und man muss Mediascape für das Betrachten von Bilder oder das hören von Music benutzen,
wenn man diese nicht durch andere Apps ersetzt. Mir persönlich gefällt Mediascape gar nicht... weswegen ich Time- und Mediascape von Anfang an entfernt habe...
Wollt ihr auch lieber die 3D Gallery und den Standard Music Player nutzen dann müsst ihr nur diese Datei runterladen.
Danach entpackt ihr die runter geladene "X10-Gallery&Music.rar" und die "Gallery_X10.apk" "Music_X10.apk" verschiebt ihr auf eure SDKarte.
Installation´s Variante 1:
Nun öffnet ihr auf eurem X10 einen Dateibrwoser (z.B. ES Datei Explorer | zu finden im Market via EStrong) und geht in den Ordner in den ihr die "Gallery_X10.apk" und "Music_X10.apk" abgelegt habt.
Führt beide Dateien nacheinander aus. Nun habt ihr die 3D Gallery und den Standard Music Player auf eurem System.
Installation´s Variante 2:
Im Market nach "apkinstaller" suchen... installieren... ausführen...
Nun die beiden vorher verschobenen "apk´s" nacheinander ausführen.
Das war Schritt 1. Ich werde diese Anleitung im laufe des Tages erweitern... es wird noch einiges erklärt... und es werden noch einige interessante Informationen folgen :D
Ich übernehme keinerlei Verantwortung für eventuelle Schäden an euren Geräten.
Jeder sollte wissen was er tut.
MfG
UKSheep
P.S. Verbesserungsvorschläge bitte per PN :)
Reaktionen: anime, YanuFreaky und PitBuLL
Just-in-time-Kompilierung
Just-in-time-Kompilierung (JIT-Kompilierung) ist eine Technik aus der Praktischen Informatik, um Software zur Laufzeit in Maschinen-Code zu übersetzen. Just in time bedeutet „gerade rechtzeitig“.
Funktionsweise:
Im Gegensatz zu einem herkömmlichen Compiler übersetzt ein JIT-Compiler erst während der Laufzeit und bei Bedarf den vorliegenden Code in einen nativen Maschinen-Code (also einen Code, den der Prozessor direkt verarbeiten kann). Anschließend wird der Maschinen-Code ausgeführt, was zu einer deutlichen Performancesteigerung gegenüber Interpretern führt. Bei der Kompilierung werden üblicherweise Codeblöcke gesamthaft kompiliert, was gegenüber dem zeilenweisen Abarbeiten des Interpreters einen weiteren Geschwindigkeitsvorteil darstellt.
Hochentwickelte JIT-Compiler können speziell für dynamische Sprachen schnelleren Code als herkömmliche Compiler generieren, da sie Closed-World-Annahmen treffen können und Dynamische Optimierungen durchführen.
Im Gegensatz zum Just-in-time-Compiler werden herkömmliche Compiler auch als „Ahead-of-time-Compiler“ (AOT-Compiler) bezeichnet, weil sie den Programm-Code vor Ausführung des Programms übersetzen. Ahead of time bedeutet „vorzeitig“.
Beispiele:
Typische Beispiele findet man bei Java, .NET, Perl 6, JRuby, PyPy sowie in kommerziellen Smalltalk-Versionen. Der Just-in-time-Compiler (JIT-Compiler) ist (neben dem Interpreter) ein Teil einer modernen virtuellen Maschine (z. B. JVM bei Java oder CLR bei .NET).
Quelle: http://de.wikipedia.org/wiki/Just-in-time-Kompilierung
________________________________________________
!!! https://www.android-hilfe.de/forum/...pack-score-for-xrecovery-anleitung.64508.html !!!
habe bei XDA folgendes gefunden - JIT Enabler | for xRecovery - xda-developers
Ersteller ist zdzihu vom XDA-Developers Forum
Link zum Thread: JIT Enabler | for xRecovery - xda-developers
In diesem Thread kann über das Tool diskutiert werden... oder User die Probleme haben können auch Fragen stellen... evtl. findet sich jemand der ähnliche Probleme hatte und diese Lösen konnte.
Dennoch weise ich darauf hin das das hier nicht der offizielle Support Thread ist.
Installations-Anleitung:
Voraussetzungen:
1. Ihr müsst xRecovery auf eurem X10 installiert haben. | xRecovery installation
Installation:
1. Ladet das aktuelle RLS vom JIT_enabler laden | JIT_enabler.zip
2. Kopiert die heruntergeladene Datei "JIT_enabler.zip auf eure SD Karte.
3. Wenn ihr euer X10 nun Ausschaltet und erneut Anschaltet... könnt ihr kurz nach dem "Sony Ericsson" Logo eine Taste drücken... [Menü - Home - Zurück] um in das Recovery Menü zu gelangen.
4. im xRecovery wählt ihr nun "Install custom zip" danach "Choose custom zip from sdcard" nun wählt ihr die "JIT_enabler.zip"
5. Ist der Flashvorgang abgeschlossen, drückt ihr "zurück" und "Reboot Phone"
Bekannte Probleme!
1. keine
Lösung:
1. keine
Hier nun der Original Thread... und viel spaß beim testen
zdzihu schrieb:
Hi guys, here's the JIT enabler to be flashed with xRecovery. Not much more to say here :)
1. Copy JIT_enabler.zip to the SD Card
2. Flash it using xRecovery / install custom zip
Download: JIT_enabler.zip
Merry Xmass everyone!
zdzihu
MfG
UKSheep
Reaktionen: YanuFreaky
Reserviert für spätere Nutzung (eigenes Angepasstes ROM erstellen)
Reaktionen: anime, YanuFreaky und quercus
Weiss jemand wie man das Standard Hintergundbild ändern kann dass angezeigt wird wenn ich zB Einstellungen, Telefon App und Ähnliches öffne? (siehe Bild im Anhang)
Hab schon folgendes versucht:
framework-res.apk mittels winrar (und auch 7zip) geöffnet (nicht entpackt).
Dann die default_wallpaper.jpg im Ordner res\drawable-hdpi gegen meine eigene getauscht. Auflösung und Bildgröße sind wie im Original.
Dann die framework-res.apk wieder mittels adb aufs X10 geflasht. Reboot.
Trotzdem wird immer noch das alte Hintergrundbild angezeigt.
Dachte eigentlich dass ich das richtige Bild erwischt habe.
Jemand ne Idee?
Danke echt für die Arbeit! Habe gerade gemerkt das da oben im Zitat die Datei offline ist. Könntest du sie wider uploaden :D?
Hast mir echt viel geholfen thx!
Gruss
Yanu
Uppe sie gleich... sage dir per PM bescheid... wenn der neue Link On ist...
Kleines Problem mit Z4Root. Wenn ich es ausführe sagt mir mein X10, dass es unerwartet beendet wurde und ich es nochmal versuchen soll. Das endet dann in einer Endlosschleife. :huh:
Das Z4Root ist auch nicht mehr aktuell - nimm das neue von Bin4ryDigit
Flashtool
mfg Quercus :)
Gibt es mittlerweile einen anderen, aktuelleren jit compiler, oder kann ich den aus dem ersten post noch verwenden?
Edit : sehe gerade das auch der link nicht mehr funktioniert, konnte das vllt jemand schnell andern ?
Es gibt nur den einen :o
Reaktionen: debiba
Jit hast eh schon drauf - weisst eh - Flashtool rechts oben - optimieren anklicken - wie gestern Abend!
Sicherlich kann es schon niemand mehr hören...ganz google hab ich nun durchforstet und irgendwie funktioniert nichts so wie ich das will.
Habe die Anleitung genauso befolgt wie hier beschrieben...konnte auch alles installieren, jedoch rootet dieses verdammte Handy einfach nich -.-
Ich hab echt schon alles probiert...alles nochma runtergeschmissen, nochma neuinstalliert, neu gestartet...nichts hilft - Titanium will einfach nicht laufen =(
Fehlermeldung ist immer dieselbe, hab halt keine Rootrechte ...HILFE !!!
Ich hoffe jemand kann mir helfen...
Hey
was hast du denn gemacht?
welche Firmware hast du? Wieso noch 2.1?
Guten Morgen =)
Na ich habe diese z4root runtergeladen, Busybox und Titanium Backup...
Aber es funktioniert einfach nich, bei Busybox kommt schon die erste Fehlermeldung
Warum 2.1? tja...mein handy sagt öfters das es ein Update gibt, wenn ich mein Telefon dann mit PC Companion verbinde sagt es mir, das mein handy aufm neuesten Stand is...grrr
dann mach erst mal mit seus (sony ericsson update service) ein update und dann sagst du mir welches android du hast ;) und welche baseband usw...
sry aber wenn ich was von z4root und busybox und titanium backup lese, glaube ich nicht, dass du die anleitung mit dem flashtool (ist auch eine von mir dabei) gelesen hast ;)
egal
