[ANLEITUNG] 100% zurück auf Stock für Vodafone UK/DE/NL/IT/ES/PT/A1 Austria/Swisscom
  • 217 Antworten
kommt ne fehlermeldung
D:\fastboot>htc_fastboot.exe oem relock
... (bootloader) [ERR] Command error !!!
OKAY
Execution time is 4(ms)
und bleibt auf unlocked
ist schon richtig damit ich das aus vom bootloader aus mache, oder.
Ah, sorry, wäre folgendes:
Code:
htc_fastboot.exe oem lock
Ja, klar ist richtig, dass du's vom Bootloader aus machst.
:thumbsup: fortschritt
relock =passt
htc_fastboot.exe flash zip firmware_4.19.161.11.zip = passt
D:\fastboot>htc_fastboot.exe flash zip firmware_4.19.161.11.zip
sending 'zip'... (43236 KB) OKAY
sending time = 3.078 secs
writing 'zip'... (bootloader) adopting the signature contained in this image...
(bootloader) signature checking...
(bootloader) zip header checking...
(bootloader) zip info parsing...
(bootloader) checking model ID...
(bootloader) checking custom ID...
(bootloader) checking main version...
(bootloader) checking hboot version...
(bootloader) start image[hboot] unzipping for pre-update check...
(bootloader) start image[hboot] flushing...
(bootloader) [RUU]WP,hboot,0
(bootloader) [RUU]WP,hboot,99
(bootloader) [RUU]WP,hboot,100
(bootloader) ...... Successful
FAIL90 hboot pre-update! please flush image again immediately
FAILED (remote: 90 hboot pre-update! please flush image again immediately)
For "hboot-preupdate" response, restart the same procedure for device FA35LW9066
28...
sending time = 3.083 secs
(bootloader) start image[boot] unzipping & flushing...
(bootloader) [RUU]UZ,boot,0
(bootloader) [RUU]UZ,boot,11
(bootloader) [RUU]UZ,boot,24
(bootloader) [RUU]UZ,boot,35
(bootloader) [RUU]UZ,boot,46
(bootloader) [RUU]UZ,boot,59
(bootloader) [RUU]UZ,boot,72
(bootloader) [RUU]UZ,boot,85
(bootloader) [RUU]UZ,boot,99
(bootloader) [RUU]UZ,boot,100
(bootloader) [RUU]WP,boot,0
(bootloader) [RUU]WP,boot,99
(bootloader) [RUU]WP,boot,100
(bootloader) start image[recovery] unzipping & flushing...
(bootloader) [RUU]UZ,recovery,0
(bootloader) [RUU]UZ,recovery,8
(bootloader) [RUU]UZ,recovery,16
(bootloader) [RUU]UZ,recovery,24
(bootloader) [RUU]UZ,recovery,31
(bootloader) [RUU]UZ,recovery,38
(bootloader) [RUU]UZ,recovery,45
(bootloader) [RUU]UZ,recovery,67
(bootloader) [RUU]UZ,recovery,73
(bootloader) [RUU]UZ,recovery,78
(bootloader) [RUU]UZ,recovery,86
(bootloader) [RUU]UZ,recovery,95
(bootloader) [RUU]UZ,recovery,100
(bootloader) [RUU]WP,recovery,0
(bootloader) [RUU]WP,recovery,99
(bootloader) [RUU]WP,recovery,100
(bootloader) start image[rpm] unzipping & flushing...
(bootloader) [RUU]UZ,rpm,0
(bootloader) [RUU]UZ,rpm,100
(bootloader) start image[sbl1-1] unzipping & flushing...
(bootloader) [RUU]UZ,sbl1-1,0
(bootloader) [RUU]UZ,sbl1-1,100
(bootloader) verified fail
(bootloader) ..... Bypassed
(bootloader) start image[sbl1-2] unzipping & flushing...
(bootloader) [RUU]UZ,sbl1-2,0
(bootloader) [RUU]UZ,sbl1-2,100
(bootloader) start image[sbl1-3] unzipping & flushing...
(bootloader) [RUU]UZ,sbl1-3,0
(bootloader) [RUU]UZ,sbl1-3,100
(bootloader) start image[sbl2] unzipping & flushing...
(bootloader) [RUU]UZ,sbl2,0
(bootloader) [RUU]UZ,sbl2,100
(bootloader) start image[sbl3] unzipping & flushing...
(bootloader) [RUU]UZ,sbl3,0
(bootloader) [RUU]UZ,sbl3,100
(bootloader) start image[tp] unzipping & flushing...
(bootloader) [RUU]UZ,tp,0
(bootloader) [RUU]UZ,tp,100
(bootloader) start image[radio] unzipping & flushing...
(bootloader) [RUU]UZ,radio,0
(bootloader) [RUU]UZ,radio,6
(bootloader) [RUU]UZ,radio,12
(bootloader) [RUU]UZ,radio,18
(bootloader) [RUU]UZ,radio,24
(bootloader) [RUU]UZ,radio,31
(bootloader) [RUU]UZ,radio,37
(bootloader) [RUU]UZ,radio,43
(bootloader) [RUU]UZ,radio,49
(bootloader) [RUU]UZ,radio,55
(bootloader) [RUU]UZ,radio,62
(bootloader) [RUU]UZ,radio,68
(bootloader) [RUU]UZ,radio,74
(bootloader) [RUU]UZ,radio,80
(bootloader) [RUU]UZ,radio,87
(bootloader) [RUU]UZ,radio,93
(bootloader) [RUU]UZ,radio,99
(bootloader) [RUU]UZ,radio,100
(bootloader) [RUU]WP,radio,0
(bootloader) [RUU]WP,radio,24
(bootloader) [RUU]WP,radio,49
(bootloader) [RUU]WP,radio,74
(bootloader) [RUU]WP,radio,99
(bootloader) [RUU]WP,radio,100
(bootloader) start image[rcdata] unzipping & flushing...
(bootloader) [RUU]UZ,rcdata,0
(bootloader) [RUU]WP,rcdata,0
OKAY
Flash Zip Complete
Execution time is 28(s)
D:\fastboot>
hab jetzt noch den grünen balken (ca 95% voll)
was mach ich jetzt, will nix mehr falsch machen
Das ist absolut normal.
Prüfe mal deinen Bootloader:
Code:
htc_fastboot.exe reboot-bootloader
Was siehst du jetzt für Informationen (insbesondere die OS Version)?
Reaktionen: flyinglull
**TAMPERED**
*Relocked*
s-on
os 4.19.161.11 in grün
wie geht es jetzt weiter?
DANKE
Du kannst jetzt versuchen die RUU zu flashen. Dann sollte das TAMPERED Flag eigentlich weg sein (natürlich kann ich dir das nicht garantieren).
Am besten benennst du die RUU um (z.B. zu RUU.zip) und dann gehst du genau gleich vor, wie bei der Firmware.
Ein *Locked* wirst du ohne erneuten S-OFF nicht mehr erreichen. An dem sollte aber auch der Garantiefall nicht scheitern.
ok also du meinst ein relocked ist nicht weiter schlimm? wie groß ist denkst du das risiko im Garantiefall?
wenn ich die ruu flashe wird der hboot upgedatet, vlt, auf 1.57?
Die RUU wird dir den HBOOT auf Version 1.61 updaten. Das spielt aber keine Rolle, da du mit Version 1.56 sowieso keine Chance auf S-OFF hast, ohne zu bezahlen (Sunshine), da firewater eingestellt wurde und nicht mehr funktioniert (siehe hier: [veraltet][Anleitung] firewater S-OFF mit HBOOT 1.44, 1.54, 1.55, 1.56 und 1.57 - Android-Hilfe.de).
Wenn du doch das Gefühl hast, dass du mit einem S-OFF besser dran bist, dann kannst du das nur mit Sunshine machen. Dieser kostet aber $25.
HTC schreibt zu einem RELOCK, dass die Garantie "möglicherweise erlischt". Allerdings ist das eher unwahrscheinlich. Du kannst ja hier mal im Forum suchen. Dazu gibt es bestimmt schon Threads.
ok, danke
Was ist denn genau defekt?
die kamera hat den lila stich
den ruu nimmt er glaub nicht...
D:\fastboot>htc_fastboot.exe flash zip ruu.zip
sending 'zip'... (43289 KB) OKAY
sending time = 3.102 secs
(bootloader) rom parsing start ...
(bootloader) rom parsing finish ...
(bootloader) Read zipped android_info fail
FAILED (status read failed (Too many links))
Execution time is 9(s)
Das ist ein Problem, welches ich auch schon hatte...
Ich hatte das damals relativ elegant gelöst, allerdings kann ich dir nicht garantieren, dass das funktioniert (ich habe S-OFF)... Ich habe zuerst die Firmware geflasht (firmware_7.18.161.2.zip | firmware_7.18.161.2.zip | by sToRmInG for One) und danach die RUU. Allerdings könnte es sein, dass sich die RUU nicht mehr flashen lässt.
Du kannst es versuchen, aber garantieren kann ichs dir nicht.
**TAMPERED** ist weg :thumbsup: du bist Sueper
bekomm ich mit relocked meine Garantieanspruch?
Wie hast du's gelöst? Firmware flashen und danach die ganze RUU?
Ich denke, dass das OK ist. Ohne TAMPERED Schriftzug sagt RELOCKED lediglich aus, dass du den Bootloader auf- und wieder zugemacht hast. Das TAMPERED Flag erscheint nur, wenn die Signatur der System-Partition nicht mehr in Ordnung ist.
Super, keine Ursache! ;)
Hey storming,
hoffe dir geht es gut, da bin ich wieder.
Das zweite Gerät ist nun auch defekt (damals lila stich / Cam, Display löste sich, mic defekt = also neues Gerät bekommen), Display löst sich und LS unten knackt. Also wieder root runter und stock drauf.
Ich muss mich wieder einlesen und starte gleich los, hoffe es klappt diesmal auf anhieb.
Bis später :)
da bin ich wieder, also nachdem der ersteLaptop nicht mit dem adb treiber zhurecht kam, nutze ich einen anderen und es klappte alles auf anhieb. un hab ich allerdings einen Fehler begangen, und zwar hab ich das Backup vom OEM geflasht und anschliessen die falsche backup resotred. Jetzt startet das GErät ständig neu beim HTC logo.
S-On ist wieder aktiv, Bootloader habe ich wieder unlocked aber kan TWRP nicht installieren wenn S-ON ist, daher gilt es SOFF zu schalten ohne das ich das Gerät starten kann bis auf bootloader und fastboot.
Was muss ich tun ? :-/
****EDIT***
Entwarnung, ich musste lediglich TWRP aufspielen und damit die firmware wieder, dann wieder S-OFF mit rumrunner, und das ganze ab schritt 4 nochmal. nun hat es geklappt.!!
lG
slot
hadru-root
hadru-root
hadru-root
ferchi
maniatore2006
ferchi
mogi999999
mogi999999
