vetzki
Philosoph
- 1.751
repo help Befehl zeigt die hilfe (also repo help sync).
probier mal -j8 oder so und/oder -c
Code:
Update working tree to the latest revision
Usage: repo sync [<project>...]
Options:
-h, --help show this help message and exit
-f, --force-broken continue sync even if a project fails to sync
-l, --local-only only update working tree, don't fetch
-n, --network-only fetch only, don't update working tree
-d, --detach detach projects back to manifest revision
-c, --current-branch fetch only current branch from server
-q, --quiet be more quiet
-j JOBS, --jobs=JOBS projects to fetch simultaneously (default 4)
-m NAME.xml, --manifest-name=NAME.xml
temporary manifest to use for this sync
--no-clone-bundle disable use of /clone.bundle on HTTP/HTTPS
-u MANIFEST_SERVER_USERNAME, --manifest-server-username=MANIFEST_SERVER_USERNAME
username to authenticate with the manifest server
-p MANIFEST_SERVER_PASSWORD, --manifest-server-password=MANIFEST_SERVER_PASSWORD
password to authenticate with the manifest server
--fetch-submodules fetch submodules from server
--no-tags don't fetch tags
-s, --smart-sync smart sync using manifest from a known good build
-t SMART_TAG, --smart-tag=SMART_TAG
smart sync using manifest from a known tag
repo Version options:
--no-repo-verify do not verify repo source code
