Root und unrooting für das Xperia 2011 Easy Rooting Toolkit [v1.0]
  • 100 Antworten
Slimmer2
Slimmer2
Philosoph
863
Habe dieses Thema grad auf XDA devlopers gefunden.
Habs auch gleich getest. Funktionierte ohne Probleme
Für Windows: [04/Jan][ROOTING/UNROOTING] Xperia 2011 Easy Rooting Toolkit [v4.0](zergRush Exploit)
Linux: [HOW-TO] Root Phones w/ Android v2.2.x-2.3.x (zergRush Method) - xda-developers Updated version of Rooting script for Linux
Unterstützte Geräte:
Confirmed to be working on the following devices:
  • Sony Xperia X10 (GB firmware)
  • Sony Xperia Arc
  • Sony Xperia Arc S
  • Sony Xperia Play [R800i/R800x]
  • Sony Xperia Ray
  • Sony Xperia Neo
  • Sony Xperia Neo V
  • Sony Xperia Mini
  • Sony Xperia Mini S51SE
  • Sony Xperia Mini Pro
  • Sony Xperia Pro
  • Sony Xperia Active
  • Sony Xperia Live Walkman
  • NTT Docomo Xperia ARCO SO-02C
  • Samsung Galaxy S2 [GT-i9100/i9100P/i9100T]
  • Samsung Galaxy S II for T-Mobile (SGH-T989)
  • Samsung Galaxy S II for AT&T (SGH-I777), Skyrocket (SGH-i727)
  • Samsung Galaxy S II LTE Rogers Canada (SGH-I727R), Android version 2.3.5, Baseband version I727RUXKJ7
  • Samsung Galaxy S II Epic 4g Touch
  • Samsung Galaxy S2 HD LTE (SHV-E120S)(korea)
  • Samsung Galaxy S2 LTE (SHV-E110S)
  • Samsung Galaxy S2 LTE Japanese version (carrier DoCoMo) [SC-03D] (2.3.6) {OMKK3}
  • Samsung Galaxy i9100G
  • Samsung Galaxy S [i9000B] & [i9000 2.3.3 (PDA I9000BOJV8, Phone I9000XXJVO, CSC I9000GDTMJV7) and german T-Mobile branding], XWJVW (2.3.6)
  • Samsung Galaxy S 4G (aka SGH-T959V)
  • Samsung Galaxy S Plus (GT-I9001) OS 2.3.3 and 2.3.6 (I9001ZSKP6) & 2.3.4 firmware (i9001XXKP4)
  • Samsung Galaxy Mini GT-S5570 (GB only)
  • Samsung Galaxy Mini Pro i5510
  • Samsung Galaxy W [i8150]
  • Samsung Galaxy Y
  • Samsung Galaxy Y pro [B5510] (2.3.5)
  • Samsung Galaxy Tab [P1000] (2.3.3 firmware), [P1000N]
  • Samsung Galaxy Note [N7000]
  • Samsung Galaxy Player YP-G70 2.3.5 (GINGERBREAD.XXKPF)
  • Samsung Galaxy Ace (2.3.3, 2.3.4 firmware)
  • Samsung S5670 FIT DDKQ5 2.3.5
  • Samsung Nexus S [i9023] (2.3.6)
  • Samsung Nexus S 4G 2.3.7
  • Samsung Galaxy Nexus S [i9020] (2.3.6)
  • Samsung Exhibit (SGH-T759)
  • Samsung Exhibit 4G (SGH-T759) (2.3.3) Build UVKE8
  • Samsung Epic 4G
  • Samsung Captivate i897 UCKH3
  • Motorola ATRIX
  • Motorola Milestone 3 [ME863 HK]
  • Motorola Milestone 2 with Gingerbread
  • Motorola XT860, Bell XT860
  • Motorola Defy+
  • Motorola Droid X sys ver 4.5.605 w/ gingerbread
  • Motorola Droid X2 (2.3.4) Sys ver 1.3.380.MB870.Verizon.en.US Build 4.5.1A-DTN-150-30
  • Motorola XT883 (China Telecom)
  • Motorola XT862 (Verizon Droid3)
  • Motorola DROID RAZR
  • Nexus One (2.3.6 stock)
  • LG Revolution
  • LG Nitro HD
  • Vizio VTAB1008 Tablet
  • Huawei IDEOS U8150 (2.2)
  • HTC Sensation (S-OFF only)
  • Acer Liquid Mini (2.3.5)
  • Acer Liquid Metal (2.3.6)
Diese Rootmethode ist auch im Flashtool Integriert. Die neuste Version von Flashtool findet ihr unter Flashtool - Xperia devices flashing
Im Flashtool findet ihr das unter Advanced (Erweitert) > Root > Force zerg Rush
Reaktionen: DraxD, statler, standroid und 5 andere
Habe die Linux Version gerade über mein xperia Arc S laufen lassen:flapper: funktionierte bei mir fehlerfrei:thumbsup:
hallo, habe heute mein arc bekommen. muss ich bei dieser Methode meinen bootloader nicht entsperren? danke viele Grüße peter_pan
musst man nicht entsperren
Ich habe zwei Fragen:
1. Sollte ich mein Gesamtsystem vorher irgendwie sichern und wenn ja wie?
2. Entfernt das Toolkit den Root restlos?
-> kein GarantiertVerlust (wäre zu schön,oder?... :D)
Du kannst die neue Firmware immer mit dem Flashtool draufspielen, danach sind die Root-Rechte aber verloren und du musst das Toolkit wieder anwenden.
Kannst die Firmware auch einfach OTA (WiFi) einspielen.
Aber nur mit Geschlossenen Bootloader, nicht das dein Handy Bricket
hallo,
habs mit dem Flashtool aufgespielt und danach wieder das easy rooting toolkit durchlaufen lassen...
hat alles einwandfrei ohne probleme funktioniert :)
hallo, eine Frage:
habe heute mein nagelneues xperia arc s bekommen und möchte es rooten. Firmware ist bereits 2.3.4 aufgespielt. Kernel ist 2.6.32.9, Build 4.0.2.A.0.42. in der XDA-Anleitung steht bei before you begin :
Before u begin: (1) make sure u have installed adb drivers for ur devicemuss ich hier irgendwas installieren oder kann ich das einfach laufenlassen ohne etwas zu beachten ?
Sollte der normale Treiber vom ARC reichen
Diese Methode ist jetzt auch im Flashtool integriert, hab das im ersten Post schon abgeändert
danke hat einwandfrei funktioniert.
noch ein Hinweis an alle die es neu machen : erst die runme.bat starten, dann das Telefon anstecken sonst wird es nicht erkannt. Ist wirklich kinderleicht wenn man sich an die Anleitung hält.
Startpost auf v4.0 angepasst. Bitte einer der Mods Thematitel anpassen. danke
ich würde mein Arc S auch gerne rooten, allerdings habe ich die Build 4.0.2.A.0.62.
Laut dem am Anfang beschriebenen Link funktioniert das nicht damit.
Hat jemand noch einen Tipp ????
... Und ein herzliches Halllloooo ans Forum (fast vergessen) :laugh:
Willkommen im Forum :)
Einfach auf .42 downgraden und dann rooten ;)
Ist das einfachste, wenn du Root bei .62 willst, musst du den Bootloader unlocken.
Geht das bei der .42 nicht auch mit geschlossenen Bootloader?
@ Benzinger wie ich sehe hast du Arc S, da bist du hier Falsch.
musst dort hin.
@ Slimmer2 ja die 42 kann man rooten
Hier kannste ist die LT15i_4.0.2.A.0.42_GENERIC DE :rolleyes2:
brauchst noch das Flashtool .
übrigens mit dem Flashtool kann man das Arc auch rooten.:scared:
@statler ich weiß ist eigentlich das falsche Unterforum aber Überschrift heißt ja "Root und unrooting für das Xperia 2011..."
Ausserdem wurde ich aus dem Arc S Forum hierher verlinkt.
Erzählt noch jemand wie ich die FW downgrade ??
  • RudiSchmonske
statler
statler
Salvadore
  • chrishase89
statler
statler
