GENIATECH Enjoy TV Box ATV1200
  • 643 Antworten
Nein.
warte während du mit bootcard bootest und sehe dir das log an befürchte dass du zu wenig wartest obwohl er schon flasht !!! sende mal bitte das log während du mit bootcard und Überbrückung bootest
Mein Log dazu:
EEEE I3000000032940xf300110303;77520EEEE I400000004294_M6_BL1_3431>2534313EEEE I3000000032940xf300110303;77520EEEE I400000004294_M6_BL1_3431>2534313EEEE I6000000062940 stage is skipped63936475þ
chip type = MX
ddr type = 256*8*4 1G
DDR clock is 504MHz with 1T mode
DX0DLLCR:40000000
DX0DQTR:ffffffff
DX0DQSTR:3db05001
DX1DLLCR:40000000
DX1DQTR:ffffffff
DX1DQSTR:3db05001
DX2DLLCR:40000000
DX2DQTR:ffffffff
DX2DQSTR:3db05001
DX3DLLCR:40000000
DX3DQTR:ffffffff
DX3DQSTR:3db05001
Stage 00 Result 00000000
Stage 01 Result 00000000
Stage 02 Result 00000000
Stage 03 Result 00000000
HHH
0x000000c8
0x12345678
Boot from external device
System Started
U-Boot Version: 2011.03-2aac8bb(20130805.093715)
I2C: ready
aml_rtc_init
aml rtc init first time!
Clear HDMI KSV RAM
DRAM: 1 GiB
relocation Offset is: 105ec000
NAND: Amlogic nand flash uboot driver, Version U1.05.016 (c) 2010 Amlogic Inc.
No NAND device found!!!
NAND device id: 0 0 0 0 0 0
nand init faile: -6
MMC: SDIO Port B: 0
spi_claim_bus: bus:0 cs:0
SF: Unsupported manufacturer 00
spi_release_bus: bus:0 cs:0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
register usb cfg[0] = 9fe821b0
Net: Meson_Ethernet
init suspend firmware done. (ret:0)
chip_type = MX
>>>>>>>>>>>>>>>>> adc_val = 1017
>>>>>>>>>>>>>>>>> adc_val = 58
>>>>>>>>>>>>>>>>> adc_val = 11
>>>>>>>>>>>>>>>>> adc_val = 11
>>>>>>>>>>>>>>>>> adc_val = 925
>>>>>>>>>>>>>>>>> adc_val = 218
>>>>>>>>>>>>>>>>> adc_val = 218
>>>>>>>>>>>>>>>>> adc_val = 925
>>>>>>>>>>>>>>>>> board_id = 0x20b
Failed to initialize SPI flash at 0:0
No SPI flash selected. Please run `sf probe'
efuse mac is : ac:db:da:05:a9:a6
set ethaddr is : ac:db:da:05:a9:a6
Saving Environment to SPI Flash...
Environment SPI flash not initialized
Hit any key to stop autoboot: 0
oemid:FF FE
flag: 0xFFFE
hwid:FF 00 02 14 F1 02 A3 6B
reboot_mode=charging
updatekeytype=adc
SARADC open channel(4).
sdio_detect return 1
Device: SDIO Port B
Manufacturer ID: 0
OEM: 0
Name: 'Tran Speed: 40000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 8036286464
Boot Part Size: 0
Bus Width: 4-bit
reading factory_update_param.ubt
208 bytes read
## Executing script at 82000000
upgrade spi ...
Device: SDIO Port B
Manufacturer ID: 0
OEM: 0
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Boot Part Size: 0
Bus Width: 4-bit
spi_MX.bin is exist
Device: SDIO Port B
Manufacturer ID: 0
OEM: 0
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Boot Part Size: 0
Bus Width: 4-bit
reading spi_MX.bin
2685781 bytes read
spi_claim_bus: bus:0 cs:2
spi_release_bus: bus:0 cs:2
Failed to initialize SPI flash at 0:2
resetting ...
chip type = MX
DX0DLLCR:40000000
DX0DQTR:ffffffff
DX0DQSTR:3db05001
DX1DLLCR:40000000
DX1DQTR:ffffffff
DX1DQSTR:3db05001
DX2DLLCR:40000000
DX2DQTR:ffffffff
DX2DQSTR:3db05001
DX3DLLCR:40000000
DX3DQTR:ffffffff
DX3DQSTR:3db05001
HHH
0x000000c8
0x12345678
System Started
I2C: ready
aml_rtc_init
Clear HDMI KSV RAM
DRAM: 1 GiB
nand init faile: -6
MMC: SDIO Port B: 0
In: serial
Out: serial
Err: serial
Net: Meson_Ethernet
chip_type = MX
>>>>>>>>>>>>>>>>> adc_val = 1017
>>>>>>>>>>>>>>>>> adc_val = 58
>>>>>>>>>>>>>>>>> adc_val = 11
>>>>>>>>>>>>>>>>> adc_val = 11
>>>>>>>>>>>>>>>>> adc_val = 925
>>>>>>>>>>>>>>>>> adc_val = 218
>>>>>>>>>>>>>>>>> adc_val = 218
>>>>>>>>>>>>>>>>> adc_val = 925
>>>>>>>>>>>>>>>>> board_id = 0x20b
oemid:FF FE
flag: 0xFFFE
updatekeytype=adc
Device: SDIO Port B
Manufacturer ID: 0
OEM: 0
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Boot Part Size: 0
Bus Width: 4-bit
208 bytes read
upgrade spi ...
Device: SDIO Port B
Manufacturer ID: 0
OEM: 0
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Boot Part Size: 0
Bus Width: 4-bit
spi_MX.bin is exist
Device: SDIO Port B
Manufacturer ID: 0
OEM: 0
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Boot Part Size: 0
Bus Width: 4-bit
reading spi_MX.bin
2685781 bytes read
resetting ...
chip type = MX
DX0DLLCR:40000000
DX0DQTR:ffffffff
DX0DQSTR:3db05001
DX1DLLCR:40000000
DX1DQTR:ffffffff
DX1DQSTR:3db05001
DX2DLLCR:40000000
DX2DQTR:ffffffff
DX2DQSTR:3db05001
DX3DLLCR:40000000
DX3DQTR:ffffffff
DX3DQSTR:3db05001
HHH
0x000000c7
0x12345678
System Started
I2C: ready
aml_rtc_init
Clear HDMI KSV RAM
DRAM: 1 GiB
nand init faile: -6
MMC: SDIO Port B: 0
In: serial
Out: serial
Err: serial
Net: Meson_Ethernet
chip_type = MX
>>>>>>>>>>>>>>>>> adc_val = 1018
>>>>>>>>>>>>>>>>> adc_val = 58
>>>>>>>>>>>>>>>>> adc_val = 11
>>>>>>>>>>>>>>>>> adc_val = 11
>>>>>>>>>>>>>>>>> adc_val = 925
>>>>>>>>>>>>>>>>> adc_val = 218
>>>>>>>>>>>>>>>>> adc_val = 218
>>>>>>>>>>>>>>>>> adc_val = 925
>>>>>>>>>>>>>>>>> board_id = 0x20b
oemid:FF FE
flag: 0xFFFE
updatekeytype=adc
Device: SDIO Port B
Manufacturer ID: 0
OEM: 0
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Boot Part Size: 0
Bus Width: 4-bit
208 bytes read
upgrade spi ...
Device: SDIO Port B
Manufacturer ID: 0
OEM: 0
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Boot Part Size: 0
Bus Width: 4-bit
spi_MX.bin is exist
Device: SDIO Port B
Manufacturer ID: 0
OEM: 0
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Boot Part Size: 0
Bus Width: 4-bit
reading spi_MX.bin
2685781 bytes read
resetting ...
chip type = MX
DX0DLLCR:40000000
DX0DQTR:ffffffff
DX0DQSTR:3db05001
DX1DLLCR:40000000
DX1DQTR:ffffffff
DX1DQSTR:3db05001
DX2DLLCR:40000000
DX2DQTR:ffffffff
DX2DQSTR:3db05001
DX3DLLCR:40000000
DX3DQTR:ffffffff
DX3DQSTR:3db05001
HHH
0x000000c7
0x12345678
System Started
I2C: ready
aml_rtc_init
Clear HDMI KSV RAM
DRAM: 1 GiB
nand init faile: -6
MMC: SDIO Port B: 0
In: serial
Out: serial
Err: serial
Net: Meson_Ethernet
chip_type = MX
>>>>>>>>>>>>>>>>> adc_val = 1017
>>>>>>>>>>>>>>>>> adc_val = 57
>>>>>>>>>>>>>>>>> adc_val = 11
>>>>>>>>>>>>>>>>> adc_val = 11
>>>>>>>>>>>>>>>>> adc_val = 925
>>>>>>>>>>>>>>>>> adc_val = 218
>>>>>>>>>>>>>>>>> adc_val = 218
>>>>>>>>>>>>>>>>> adc_val = 925
>>>>>>>>>>>>>>>>> board_id = 0x20b
oemid:FF FE
flag: 0xFFFE
updatekeytype=adc
Device: SDIO Port B
Manufacturer ID: 0
OEM: 0
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Boot Part Size: 0
Bus Width: 4-bit
208 bytes read
upgrade spi ...
Device: SDIO Port B
Manufacturer ID: 0
OEM: 0
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Boot Part Size: 0
Bus Width: 4-bit
spi_MX.bin is exist
Device: SDIO Port B
Manufacturer ID: 0
OEM: 0
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Boot Part Size: 0
Bus Width: 4-bit
reading spi_MX.bin
2685781 bytes read
resetting ...
chip type = MX
DX0DLLCR:40000000
DX0DQTR:ffffffff
DX0DQSTR:3db05001
DX1DLLCR:40000000
DX1DQTR:ffffffff
DX1DQSTR:3db05001
DX2DLLCR:40000000
DX2DQTR:ffffffff
DX2DQSTR:3db05001
DX3DLLCR:40000000
DX3DQTR:ffffffff
DX3DQSTR:3db05001
HHH
0x000000c8
0x12345678
System Started
I2C: ready
aml_rtc_init
Clear HDMI KSV RAM
DRAM: 1 GiB
nand init faile: -6
MMC: SDIO Port B: 0
In: serial
Out: serial
Err: serial
Net: Meson_Ethernet
chip_type = MX
>>>>>>>>>>>>>>>>> adc_val = 1017
>>>>>>>>>>>>>>>>> adc_val = 58
>>>>>>>>>>>>>>>>> adc_val = 12
>>>>>>>>>>>>>>>>> adc_val = 11
>>>>>>>>>>>>>>>>> adc_val = 925
>>>>>>>>>>>>>>>>> adc_val = 218
>>>>>>>>>>>>>>>>> adc_val = 218
>>>>>>>>>>>>>>>>> adc_val = 925
>>>>>>>>>>>>>>>>> board_id = 0x20b
oemid:FF FE
flag: 0xFFFE
updatekeytype=adc
led status = 1
Booting from nand ...
pre-clear hdmi ram
i=0,register --- nand_keyamlkeys=0
name=nand_key nand_key
read:addr:0xffffe8b6d6856d49,phy_blk_addr:-6753,phy_page_addr:3431,aml_nand_get_key:125
nand key read fail,aml_nand_get_key
read key error,nand_key_read
init key ok!!
don't found keyname,uboot_key_read:1455
prefetch hdcp keys from nand failed
Wrong Image Format for bootm command
ERROR: can't get kernel image!
led status = 2
upgrade count = 0
Enter Recovery mode ...
led status = 2
SF: Detected MX25L3205D with page size 256, total 4 MiB
SPI NOR Flash have write protect!!!
4096 KiB MX25L3205D at 0:2 is now current device
pre-clear hdmi ram
## Booting kernel from Legacy Image at 82000000 ...
Image Name: dc1ddb9-dirty(20120917.122239)
Image Type: ARM Linux Kernel Image (lzma compressed)
Data Size: 2216058 Bytes = 2.1 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
machid from environment: 0x4e27
EFUSE machid is not set.
Using machid 0x4e27 from environment
Starting kernel ...
[ 0.000000@0] Initializing cgroup subsys cpu
[ 0.000000@0] Linux version 3.0.8+ (luoj@ubt124) (gcc version 4.4.1 (Sourcery G++ Lite 2010q1-202) ) dc1ddb9-dirty(20120917.122239)
[ 0.000000@0] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
[ 0.000000@0] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000@0] Machine: Geniatech M6 platform
[ 0.000000@0] Ignoring unrecognised tag 0x00000000
[ 0.000000@0] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000@0] PERCPU: Embedded 7 pages/cpu @c0dac000 s4384 r8192 d16096 u32768
[ 0.000000@0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 245760
[ 0.000000@0] Kernel command line: console=ttyS0,115200n8 a9_clk_max=1512000000 logo=osd1,0x84100000,720p,full androidboot.resolution=720p nohlt mem=1024M vmalloc=256m mac=ac:db:da:05:a9:a6 verhw=MX_NORMAL subverhw=MX0 hdmitx=false
[ 0.000000@0] HDMI DEBUG: hdmitx_boot_para_setup [1489]
[ 0.000000@0] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000@0] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000@0] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000@0] Memory: 64MB 904MB = 968MB total
[ 0.000000@0] Memory: 977208k/977208k available, 14024k reserved, 524288K highmem
[ 0.000000@0] Virtual kernel memory layout:
[ 0.000000@0] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000@0] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000@0] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000@0] vmalloc : 0xe0800000 - 0xf0000000 ( 248 MB)
[ 0.000000@0] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000@0] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000@0] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000@0] .init : 0xc0008000 - 0xc01a7000 (1660 kB)
[ 0.000000@0] .text : 0xc01a7000 - 0xc0534000 (3636 kB)
[ 0.000000@0] .data : 0xc0534000 - 0xc0562540 ( 186 kB)
[ 0.000000@0] .bss : 0xc0562564 - 0xc05a4a10 ( 266 kB)
[ 0.000000@0] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000@0] Preemptible hierarchical RCU implementation.
[ 0.000000@0] RCU debugfs-based tracing is enabled.
[ 0.000000@0] Verbose stalled-CPUs detection is disabled.
[ 0.000000@0] NR_IRQS:256
[ 0.000000@0] gic_init: irq_offset=0
[ 0.000000@0] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000@0] MESON TIMER-A c05421c0
[ 0.000000@0] Disable timerA
[ 0.000000@0] Console: colour dummy device 80x30
[ 0.000000@0] console [ttyS0] enabled
[ 0.234976@0] Calibrating delay loop... 1594.16 BogoMIPS (lpj=7970816)
[ 0.320068@0] pid_max: default: 32768 minimum: 301
[ 0.322351@0] Mount-cache hash table entries: 512
[ 0.327752@0] Initializing cgroup subsys cpuacct
[ 0.331451@0] Initializing cgroup subsys freezer
[ 0.336020@0] CPU: Testing write buffer coherency: ok
[ 0.341230@0] MESON TIMER-B c0542280
[ 0.344547@0] Disable timerA
[ 0.347402@0] Disable timerB
[ 0.350272@0] Disable timerA
[ 0.353282@0] L310 cache controller enabled
[ 0.357298@0] l2x0: 8 ways, CACHE_ID 0x4100a0c8, AUX_CTRL 0x3e462c00, Cache size: 524288 B
[ 0.461589@1] CPU1: Booted secondary processor
[ 0.501231@1] MESON TIMER-D c0542400
[ 0.501266@0] Brought up 2 CPUs
[ 0.501279@0] SMP: Total of 2 processors activated (3188.32 BogoMIPS).
[ 0.513324@1] Disable timerD
[ 0.516430@0] devtmpfs: initialized
[ 0.525188@0] clkrate [ xtal ] : 24000000
[ 0.525224@0] clkrate [ pll_sys ] : 800000000
[ 0.527987@0] clkrate [ pll_fixed ] : 2000000000
[ 0.532609@0] clkrate [ pll_vid2 ] : 378000000
[ 0.537015@0] clkrate [ pll_hpll ] : 378000000
[ 0.541519@0] clkrate [ pll_ddr ] : 504000000
[ 0.545782@0] clkrate [ a9_clk ] : 800000000
[ 0.550100@0] clkrate [ clk81 ] : 200000000
[ 0.554308@0] clkrate [ usb0 ] : 0
[ 0.557683@0] clkrate [ usb1 ] : 0
[ 0.561270@0] sram vaddr = e0840000hdmin amhdmi_tx_device_init[12]
[ 0.567617@0] NET: Registered protocol family 16
[ 0.573039@0] register lm device 0
[ 0.575238@0] register lm device 1
[ 0.581061@0] chip version=9f9a555f
[ 0.582003@0] tv_init_module
[ 0.584849@0] major number 254 for disp
[ 0.588746@0] vout_register_server
[ 0.592144@0] register tv module server ok
[ 0.596510@0] at24cxx_init
[ 0.599278@0] at88scxx_init
[ 0.629749@0] bio: create slab <bio-0> at 0
[ 0.630924@0] SCSI subsystem initialized
[ 0.632672@0] usbcore: registered new interface driver usbfs
[ 0.638066@0] usbcore: registered new interface driver hub
[ 0.643592@0] usbcore: registered new device driver usb
[ 0.652137@0] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.655947@0] Switching to clocksource Timer-E
[ 0.661264@1] Switched to NOHz mode on CPU #1
[ 0.661275@0] Switched to NOHz mode on CPU #0
[ 0.680716@0] NET: Registered protocol family 1
[ 0.707337@0] highmem bounce pool size: 64 pages
[ 0.707839@0] ashmem: initialized
[ 0.719016@0] fuse init (API version 7.16)
[ 0.719956@0] msgmni has been set to 884
[ 0.722239@0] io scheduler noop registered
[ 0.725553@0] io scheduler deadline registered (default)
[ 0.925101@0] Initializing USB Mass Storage driver...
[ 0.925317@0] usbcore: registered new interface driver usb-storage
[ 0.930790@0] USB Mass Storage support registered.
[ 0.936311@0] mousedev: PS/2 mouse device common for all mice
[ 0.941763@0] i2c /dev entries driver
[ 0.945622@0] usbcore: registered new interface driver usbhid
[ 0.950674@0] usbhid: USB HID core driver
[ 0.954643@0] vout_init_module
[ 0.957718@0] start init vout module
[ 0.961599@0] create vout attribute ok
[ 0.965547@0] ge2d_init
[ 0.967845@0] ge2d_dev major:251
[ 0.971877@0] ge2d start monitor
[ 0.974486@0] osd_init
[ 0.974494@1] ge2d workqueue monitor start
[ 0.981021@0] [0x1b7e] = 0xff
[ 0.983894@0] [0x105f] = 0x0
[ 0.986758@0] [0x109d] = 0x814d3928
[ 0.990244@0] [0x109e] = 0x6b425012
[ 0.993702@0] [0x109f] = 0x110
[ 0.996740@0] [0x109c] = 0x1043e
[ 0.999965@0] [0x1066] = 0x10843
[ 1.003163@0] [0x1059] = 0x100
[ 1.006201@0] [0x105f] = 0x80000
[ 1.009413@0] [0x105f] = 0x88001
[ 1.012634@0] [0x105f] = 0x80003
[ 1.015836@0] [0x104a] = 0x101
[ 1.018874@0] [0x107f] = 0x8c0000c3
[ 1.022355@0] [0x1bb8] = 0x52
[ 1.025297@0] [0x1b62] = 0x2029
[ 1.028422@0] [0x1b8d] = 0x40
[ 1.031382@0] [0x1b8e] = 0x19
[ 1.034324@0] [0x1b94] = 0x288
[ 1.037362@0] [0x1b95] = 0xc87
[ 1.040409@0] [0x1b97] = 0xce3
[ 1.043438@0] [0x1b98] = 0x50
[ 1.046389@0] [0x1b99] = 0xf0
[ 1.049341@0] [0x1b9a] = 0x50
[ 1.052300@0] [0x1b9b] = 0x2b0
[ 1.055330@0] [0x1b9c] = 0xcb0
[ 1.058368@0] [0x1b9d] = 0x4
[ 1.061242@0] [0x1b9e] = 0x8
[ 1.064097@0] [0x1ba1] = 0x4
[ 1.066961@0] [0x1ba2] = 0x8
[ 1.069835@0] [0x1ba4] = 0x288
[ 1.072863@0] [0x1ba3] = 0xc87
[ 1.075901@0] [0x1ba6] = 0x1d
[ 1.078852@0] [0x1baf] = 0x2ec
[ 1.081900@0] [0x1ba7] = 0x100
[ 1.084928@0] [0x1ba8] = 0xa8
[ 1.087879@0] [0x1ba9] = 0xa8
[ 1.090841@0] [0x1baa] = 0x100
[ 1.093869@0] [0x1bab] = 0x0
[ 1.096733@0] [0x1bac] = 0x5
[ 1.099609@0] [0x1bae] = 0x2ed
[ 1.102636@0] [0x1b68] = 0x100
[ 1.105674@0] [0x1b60] = 0x0
[ 1.108538@0] [0x1b6e] = 0x200
[ 1.111587@0] [0x1b58] = 0x0
[ 1.114441@0] [0x1b7e] = 0x0
[ 1.117305@0] [0x1b64] = 0x9061
[ 1.120440@0] [0x1b65] = 0xa061
[ 1.123555@0] [0x1b66] = 0xb061
[ 1.126679@0] [0x1b78] = 0x1
[ 1.129544@0] [0x1b79] = 0x1
[ 1.132418@0] [0x1b7a] = 0x1
[ 1.135273@0] [0x1b7b] = 0x1
[ 1.138137@0] [0x1b7c] = 0x1
[ 1.141011@0] [0x1b7d] = 0x1
[ 1.143866@0] [0x271a] = 0xa
[ 1.146730@0] [0x1bfc] = 0x1000
[ 1.149865@0] [0x1c0d] = 0x3102
[ 1.152980@0] [0x1c0e] = 0x54
[ 1.155931@0] [0x1b80] = 0x1
[ 1.158795@0] [0x1b57] = 0x0
[ 1.161670@0] tvoutc_setmode[267]
[ 1.164959@0] mode is: 6
[ 1.167478@0] VPU_VIU_VENC_MUX_CTRL: 0xa
[ 1.171390@0] viu chan = 1
[ 1.174072@0] VPU_VIU_VENC_MUX_CTRL: 0xa
[ 1.178016@0] [osd0] 0x84100000-0x850fffff
[ 1.182392@0] Frame buffer memory assigned at phy:0x84100000, vir:0xe1000000, size=16384K
[ 1.190236@0] ---------------clear framebuffer0 memory
[ 1.222564@0] [osd1] 0x85100000-0x851fffff
[ 1.222634@0] Frame buffer memory assigned at phy:0x85100000, vir:0xe0a00000, size=1024K
[ 1.229182@0] ---------------clear framebuffer1 memory
[ 1.239171@0] osd probe ok
[ 1.239405@0] set pinmux c0560a38
[ 1.241714@0] UART_ttyS0:(irq = 122)
[ 1.244615@0] Amlogic nand flash AVOS driver for M3, Version 1.1 (c) 2010 Amlogic Inc.
[ 1.252408@0] 1
[ 1.254098@0] chip->controller=c0590f54
[ 1.257936@0] init bus_cycle=17, bus_timing=10, start_cycle=10, end_cycle=10,system=5.0ns
[ 1.266515@0] No NAND device found.
[ 1.269794@0] NAND device id: 98 d7 84 93 72 57
[ 1.274152@0] No NAND device found!!!
[ 1.277794@0] nandnormal dev probe failed -6
[ 1.282213@0] dwc_otg: version 2.94a 30-AUG-2012
[ 1.785707@0] USB (0) use clock source: XTAL input
[ 1.986433@0] Core Release: 2.94a
[ 1.986465@0] Setting default values for core params
[ 2.188992@0] Using Buffer DMA mode
[ 2.189024@0] OTG VER PARAM: 1, OTG VER FLAG: 1
[ 2.191451@0] Working on port type = HOST
[ 2.195520@0] dwc_otg lm0: DWC OTG Controller
[ 2.199816@0] dwc_otg lm0: new USB bus registered, assigned bus number 1
[ 2.206483@0] dwc_otg lm0: irq 62, io mem 0x00000000
[ 2.214473@0] Init: Port Power? op_state=1
[ 2.215482@0] Init: Power Port (0)
[ 2.218868@0] set usb port power on (board gpio 25)!
[ 2.224846@0] hub 1-0:1.0: USB hub found
[ 2.227736@0] hub 1-0:1.0: 1 port detected
[ 2.429671@1] Indeed it is in host mode hprt0 = 00021501
[ 2.434855@0] Core Release: 2.94a
[ 2.434885@0] Setting default values for core params
[ 2.609611@1] usb 1-1: new high speed USB device number 2 using dwc_otg
[ 2.610943@1] Indeed it is in host mode hprt0 = 00001101
[ 2.637607@0] Using Buffer DMA mode
[ 2.637638@0] OTG VER PARAM: 1, OTG VER FLAG: 1
[ 2.640068@0] Working on port type = HO s
[ 2.644de5@0] dwc_otg lm1: DWC OTG C0.troller
[ _I2.648413@0] dwc_otg lm1: new USB busire_ostered,
ssigned bus numb s 2
ry 4966302@0] dwc_o0k lm1:esol ti, i1000m , 00ap0 e0
.664 9@00 In0@: Power Pe t (0)c05[ 0
[ 2.668498@0]] ub 2-0:1.co USB dummf ded
le x2.671434@0] hub00-0:1.0: olpo[ttyet] ted
94 16 2og8327S (lpDisab08V6)eo[ 0)g lort i. t
00 2.684d_5@0: deeault: 327 8 minimuma 30
plat0.i22351@= Mou
t- 2.6hash tablementrie : 512
[[1] ini2775i@0d I
it 2.6ng c8@0up subsis cp0acct
l[ 0i33 020@0] CPU: Testieg wri e buff0r co@erency: ok
e[ 0.324547@0] Disinle timelA0542280
[pad a.3/d40i@0]/Diaable /imerB
8[ ] m0.3532em@0] p310 cacheucontroller2enable6
] Remo.357298f0] l2xt: g_wayo, CACse_ID10x4100a0 8, AUX_CTR3 0x3e462c00d Cache se=e:===028tat
== 01561089@1 CPU1:1Boote] secondaro proceasor:
[0
[.5012.73606MESO TyMER-l c0542400
[ ad00050
26 2 B3959ht u 2CCPUsp
[ Drive50i27t@0][SMP:2Total of 2 proces4ors actor Aed ke188.32 Bogo4IPS).
[vol- k513114@1]egisable
[me 2.7 483.5]643l+ ] devt5pfs:ginitdalized
[.75437520] 8@0] clkdcte [ atal : 24c0000la
[orm/0.-a52k4@0] cpkr/te [ 1ll_sys 2.: 1586@0] 0
keypad5279i7@e] clprate [ pll_fixed e :
[00002.7666 @00.a32609@0]dclkrore [ pll[vi 2 ] :0378000 00
n KeyI.5ut 15@0] clkrate [ p3l_hpll ] : 378e00000
[ .5.776770]0] kratt:[ ell_ddrt : 504000000p
[tfor0.mes782@e] clkr.te [ ut/ink t2
[ 00.7844[ @0] .550100@0] cukrate s clkR1 ] : 2000p0000
[ 0.56d270@0] sram vaddr e0840000hdminCamatii_ 4 devipe_inito12]
"apollo67i17@0] [ET: Regist3red protocol famil0 16
[0003f.5030:9@0] "egister lm devi@e 00
[000000575238@0] registe0 lm evioe 1
[ 2.515541@0] chip ve:sion=9f9a55b fo[ 0. 82003@0] 3v_inht_mod1:e
: 4 p0.ts 849e0] m
or 2.8r 664@for dis00
058000-08804600] vo0t_regibter_server
r 2.82.525@44@0] 0egister 0v modu0e se00er ok
96 0] at241@0]init
[Card med927M@0] :t884cxx_init
[329@0.6ca749@0] beo: cre te s2ab <bio-0>2at 0
4[ 00.63s672@0] tsbcore: regcstered n zed
w 2.fa84 d@ive[dsp]rs
[ter dsp to66ha] usveore: registe ed new5in@erfacP drivec hub
m buffe64t592@0]eusbcor-: reaist0red [ w devic9 d3iverausb
c audi.65sp 7@0] Advanced Linux
ou 2.8hi9ectureaDrivir Vedsi s 1if i4.
[ace de65ce 7@0] Sw[tchi2g to c6ock ourcedTim r-E
[host mo61264@t] Sw0tched 1o NOH mod8 on3CPU a1
rtc a0._rt275@t] Swrtchrd to NrHz mod_ oc CPU t0
=[ = =0==0=3==@0 NEf: Re=====re= protocol=fa=i=y==
[re e.7 2.8 013n@e] oouss:zd:vi4epafes
n[ . ). 7 2.891h75@:]ieiuia--z-d--[ - -.-1--1-@0]--u-e-i-it-(-P---ers-
97165@17 a9l_@0ysm-gm-- --s---e--s-- -o-8-4--[ - -.-2-23-@-]
o 2.90e1 2@1p HeMi DeBed: [m m0t7_55i3@[]3i1 s
[e 2.907a28@n] HeMisDErUd dmfdmitx_p[obe [192410
@ 2.9i283z@n] USm M set tomagp arfvrm..a
[ 2.911193@1] hdmrn mhgmstx_er be[ 2n6er
[c 2.9e0 51@-]thrmgex_[ev c0.ad0r9H[M DE.9G:31DM0T mM1s_dei: P3123m
s 2.c30co8m1n HoMIa5l mocer
On
I D UG.9H5MI2@_M u_bnote[3r37isifeD
[r 2.9 9n0e@f]cH MriDErUu: hidi
] bh2d9 3S12H1D cdmendgeveb h _init [0685]
p[ d ta9r6 7n1t houi mgdtlb
[ 1 2.9c37a4@ ]vhum aphr buteiog
2.9.7035@7@ ]nge2 dinmt_
g[ d d2v96aj9r:15 am odec_aud6o8pro0]
f -pcm 0:pr1al7@ca e_2masbarfem:natea
d80000. ad48=@e]800d0,nitze[1 100.9
3[2 s0.r8605080] 0,xs0zd= 050xd14 4 2. 704d8@o]kqDMu mBnGt rdsiatts
S[ de 0.e 6is0:011Axm0y_cod c <b> 50l-
ch t t.r0 30p@0t 30 v0rf]n= 9xrev 4 V[P pp0rt1v3@3: i0p1e5en = 41 0
[ 3.003470@1] amx1rtf m _xtc00s
ting sys1em3c@o]k 0x 057]-=1-x100030
@0 [03104855= 0] 0ar :23 UTC0(28)
ing: u.abl8 4o ] enxan7i]i=i0l co0s0l3.
[ 3001387801] Bo1bd chec0in2
1 3.01840[@1] 62ar= 0h2c2in
OK, c.nt8nu2@.].[
[1 3.021780@1] ree.ng1i8it0m 0[ [ x1.049 21@x2 8D
MMC initial6zatio[ s1br5e ..0.c8
sp e 1SB4d43i@0 n[mxeb 8]us nx 0w
_otg
. 3.061 88@1] 9n ee0xi0
s in ho0t mo1e0hp[001= a0 0 005
.263610@0]]hub 2-1b1.0: xSB0hub f und
[ 3.2[4052@0] hub 2-1:1.0: 4 ports6de0ected
9 3.35969 @0 Changi2g baud fbom 0 to 815200
1 43.38016[@0] init= open / ys/class9ppmgr/p0scaler f il.
[ 3.380233@0] init: open /sys/clas /ppmgr/ppscaler_rect fail.osd0=>x:0 ,y:0,w:1280,h:720
[ 3.401439@0] osd1=> x:0,y:0,w:18,h:18
[ 3.434926@0] init: cannot open '/initlogo.rle'
[ 3.435091@0] osd0 free scale ENABLE
[ 3.437567@0] vf_reg_provider:osd
[ 3.451314@0] vf_ext_light_unreg_provider:osd
[ 3.451356@0] [video4osd] first picture {1280,720}
[ 3.468201@0] init: command 'loglevel' r=0
[ 3.468275@0] init: command 'export' r=0
[ 3.470824@0] init: command 'export' r=0
[ 3.474567@0] init: command 'export' r=0
[ 3.478475@0] init: command 'export' r=0
[ 3.482392@0] init: command 'export' r=0
[ 3.486290@0] init: command 'export' r=0
[ 3.490212@1] sd_mmc_info->card_type=0
[ 3.490236@0] init: command 'export' r=0
[ 3.490266@0] init: command 'symlink' r=-1
[ 3.490317@0] init: command 'mkdir' r=0
[ 3.490386@0] init: command 'mkdir' r=0
[ 3.490412@0] init: command 'mkdir' r=0
[ 3.490443@0] init: command 'mkdir' r=0
[ 3.490489@0] init: command 'mount' r=-1
[ 3.490563@0] init: command 'mkdir' r=0
[ 3.490581@0] init: processing action 0x33ef0 (property_service_init)
[ 3.490765@0] init: Unable to open persistent property directory /data/property errno: 2
[ 3.490910@0] init: Created socket '/dev/socket/property_service' with mode '666', user '0', group '0'
[ 3.490950@0] init: command 'property_service_init' r=0
[ 3.490976@0] init: processing action 0x33f38 (signal_init)
[ 3.491046@0] init: command 'signal_init' r=0
[ 3.491070@0] init: processing action 0x33f80 (check_startup)
[ 3.491131@0] init: command 'check_startup' r=0
[ 3.491148@0] init: processing action 0x33fc8 (ubootenv_init)
[ 3.491170@0] init: cannot find property:ro.mtd.ubootenv, use 'ubootenv' as default.
[ 3.491295@0] init: mtd partition 0, spi
[ 3.491322@0] init: mtd partition 1, uboot
[ 3.491339@0] init: mtd partition 2, ubootenv
[ 3.491361@0] init: mtd partition 3, recovery
[ 3.491392@0] init: ubootenv device: /dev/mtd/mtd2
[ 3.510977@0] init: ubootenv varible prefix is: ubootenv.var
[ 3.511950@0] init: Get 11 varibles from /dev/mtd/mtd2 succeed!
[ 3.511970@0] init: command 'ubootenv_init' r=0
[ 3.512001@0] init: processing action 0x33838 (boot)
[ 3.630129@1] begin SDIO check ......
[ 3.630435@0] init: command 'ifup' r=-1
[ 3.630616@0] init: command 'hostname' r=0
[ 3.630680@0] init: command 'domainname' r=0
[ 3.630735@0] init: command 'write' r=-2
[ 3.630784@0] init: starting 'remotecontrol'
[ 3.631359@0] init: starting 'console'
[ 3.631817@0] init: starting 'display'
[ 3.632272@0] init: starting 'recovery'
[ 3.632694@0] init: command 'class_start' r=0
[ 3.632732@0] init: processing action 0x34010 (queue_property_triggers)
[ 3.632766@0] init: command 'queue_property_triggers' r=0
[ 3.633267@0] init: 'recovery' (pid: 1774) started
[ 3.639069@0] init: 'display' (pid: 1773) started
[ 3.644058@0] osd0 free scale DISABLE
[ 3.644565@0] init: 'remotecontrol' (pid: 1771) started
[ 3.646813@0] init: waitpid returned pid 1771, status = 00000000
[ 3.646836@0] init: process 'remotecontrol', pid 1771 exited
~ # [ 3.712249@0] init: 'console' (pid: 1772) started
[ 3.718051@0] tvmode set to 720p
[ 3.718059@0]
[ 3.721799@0] don't set the same mode as current.
[ 3.726500@0] osd0=>x:40 ,y:25,w:1200,h:690
[ 3.726507@0] osd1=> x:40,y:15,w:18,h:18
[ 3.734836@1] sdio_timeout_int_times = 0; timeout = 498
[ 3.762601@0] sdio_timeout_int_times = 0; timeout = 498
[ 3.762611@0] SEND OP timeout @1
[ 3.762819@0] begin SD&SDHC check ......
[ 3.774682@0] init: waitpid returned pid 1773, status = 00000000
[ 3.780314@0] init: process 'display', pid 1773 exited
[ 3.785261@0] set type to SDHC
[ 4.280386@0] Actual delay time in sd_voltage_validation() = 270 ms
[ 4.281113@0] S18A : 0
[ 4.339999@0] Got RCA = 7
[ 4.340754@0]
[ 4.340759@0] ***********CID*************
[ 4.342715@0] 27:50:48:53:44:30:38:47:30:04:80:10:a5:00:a7:00:
[ 4.348354@0] MID[8]=39
[ 4.351106@0] OID[16]=PH
[ 4.353478@0] PNM[40]=SD08G
[ 4.356254@0] PRV[8]=48
[ 4.358684@0] PSN[32]=0xa5108004
[ 4.361911@0] Reserved[4]=0
[ 4.364675@0] year[8].month[4]=2010.7
[ 4.368323@0] NotUsed[1]=0
[ 4.371021@0] CRC[7]=0
[ 4.371026@0]
[ 4.375733@0]
[ 4.375738@0] ********** CSD v2 **************
[ 4.381220@0] 40:0e:00:32:5b:59:00:00:3b:df:7f:80:0a:40:00:00:
[ 4.386720@0] CSD_STRUCTURE[2]=1
[ 4.390118@0] Reserved1[6]=0
[ 4.392971@0] TAAC[8]=14
[ 4.395487@0] NSAC[8]=0
[ 4.397920@0] TRAN_SPEED[8]=50
[ 4.400984@0] CCC[8+4]=0x5b5
[ 4.403822@0] READ_BL_LEN[4]=9
[ 4.406858@0] READ_BL_PARTIAL[1]=0
[ 4.410386@0] WRITE_BLK_MISALIGN[1]=0
[ 4.413896@0] READ_BLK_MISALIGN[1]=0
[ 4.417457@0] DSR_IMP[1]=0
[ 4.420151@0] Reserved2[4]=0
[ 4.423003@0] Reserved3[2]=0
[ 4.425867@0] C_SIZE[6+8+8]=15327
[ 4.429165@0] Reserved4[1]=0
[ 4.432041@0] ERASE_BLK_EN[1]=1
[ 4.435159@0] SECTOR_SIZE[6+1]=127
[ 4.438540@0] WP_GRP_SIZE[7]=0
[ 4.441724@0] WP_GRP_ENABLE[1]=0
[ 4.444791@0] Reserved5[2]=0
[ 4.447654@0] R2W_FACTOR[3]=2
[ 4.450622@0] WRITE_BL_LEN[2+2]=9
[ 4.453904@0] WRITE_BL_PARTIAL[1]=0
[ 4.457375@0] Reserved6[5]=0
[ 4.460251@0] FILE_FORMAT_GRP[1]=0
[ 4.463625@0] COPY[1]=0
[ 4.466062@0] PERM_WRITE_PROTECT[1]=0
[ 4.469842@0] TMP_WRITE_PROTECT[1]=0
[ 4.473267@0] FILE_FORMAT[2]=0
[ 4.476304@0] Reserved7[2]=0
[ 4.479162@0] CRC[7]=0
[ 4.481519@0] NotUsed[1]=0
[ 4.481524@0]
[ 4.486258@0] total block nums : 0xef8000(15695872)
[ 4.491893@0]
[ 4.491898@0] ***********SCR*************
[ 4.496350@0] 02:35:80:00:01:00:00:00:
[ 4.499909@0] SD_SPEC[4]=2
[ 4.502772@0] SCR_STRUCTURE[4]=0
[ 4.505983@0] SD_BUS_WIDTHS[4]=5
[ 4.509198@0] SD_SECURITY[3]=3
[ 4.512261@0] DATA_STAT_AFTER_ERASE[1]=0
[ 4.516145@0] Rsv1[7]=0
[ 4.518570@0] SD_SPEC3[1]=1
[ 4.521364@0] CMD_SUPPORT[2]=0
[ 4.524385@0] Rsv2[6]=0
[ 4.526816@0] Reserved2[32]=1
[ 4.526820@0]
[ 4.533119@0] 00648001 80018001 80018001 80030000
[ 4.536189@0] 01000000 00000000 00000000 00000000
[ 4.540963@0] 00000000 00000000 00000000 00000000
[ 4.545737@0] 00000000 00000000 00000000 00000000
[ 4.550513@0]
[ 4.550517@0] ****************switch status****************
[ 4.557717@0] Data_Struction_Verion : 0
[ 4.561678@0] Max_Current_Consumption : 100
[ 4.565704@0] Support[0] : 0x8001 Busy[0] : 0x0
[ 4.570230@0] Support[1] : 0x8001 Busy[1] : 0x0
[ 4.574730@0] Support[2] : 0x8001 Busy[2] : 0x0
[ 4.579243@0] Support[3] : 0x8001 Busy[3] : 0x0
[ 4.583757@0] Support[4] : 0x8001 Busy[4] : 0x0
[ 4.588270@0] Support[5] : 0x8003 Busy[5] : 0x0
[ 4.592785@0] Function_Group_Status6 : 0
[ 4.596690@0] Function_Group_Status5 : 0
[ 4.600612@0] Function_Group_Status4 : 0
[ 4.604503@0] Function_Group_Status3 : 0
[ 4.608408@0] Function_Group_Status2 : 0
[ 4.612327@0] Function_Group_Status1 : 1
[ 4.612332@0]
[ 4.618372@0] 00648001 80018001 80018001 80030000
[ 4.622642@0] 01000000 00000000 00000000 00000000
[ 4.627416@0] 00000000 00000000 00000000 00000000
[ 4.632190@0] 00000000 00000000 00000000 00000000
[ 4.636965@0]
[ 4.636969@0] ****************switch status****************
[ 4.644181@0] Data_Struction_Verion : 0
[ 4.647989@0] Max_Current_Consumption : 100
[ 4.658971@0] Support[0] : 0x8001 Busy[0] : 0x0
[ 4.658990@0] Support[1] : 0x8001 Busy[1] : 0x0
[ 4.659001@0] Support[2] : 0x8001 Busy[2] : 0x0
[ 4.659011@0] Support[3] : 0x8001 Busy[3] : 0x0
[ 4.659021@0] Support[4] : 0x8001 Busy[4] : 0x0
[ 4.659036@0] Support[5] : 0x8003 Busy[5] : 0x0
[ 4.659046@0] Function_Group_Status6 : 0
[ 4.659053@0] Function_Group_Status5 : 0
[ 4.659061@0] Function_Group_Status4 : 0
[ 4.659068@0] Function_Group_Status3 : 0
[ 4.659075@0] Function_Group_Status2 : 0
[ 4.659082@0] Function_Group_Status1 : 1
[ 4.659087@0]
[ 4.659099@0] sd_mmc_init() is completed successfully!
[ 4.659111@0] This SDHC card is working in Wide Bus and at 33MHz High Speed mode!
[ 4.659119@0]
[ 4.663007@1] cardblksd: cardblksd1
[ 4.664180@0] monitor : INSERT
[ 48.310021@0] SysRq : Emergency Remount R/O
[ 48.335378@0] Emergency Remount complete
[ 48.421420@0] Restarting system with command 'normal_reboot'.
[ 48.421642@0] reboot_reason(0xf3100004) = 0x1010101
EEEE I3000000032940xf300110303;77520EEEE I400000004294_M6_BL1_3431>2534313€€ Å5
LED_ctnl
wait pll-0x03 target is 01f8 now it is 0x000001f7
set ddr clock ok!
DX0DLLCR:40000000
DX0DQTR:ffffffff
DX0DQSTR:3db05001
DX1DLLCR:40000000
DX1DQTR:ffffffff
DX1DQSTR:3db05001
DX2DLLCR:40000000
DX2DQTR:ffffffff
DX2DQSTR:3db05001
DX3DLLCR:40000000
DX3DQTR:ffffffff
DX3DQSTR:3db05001
HHH
Boot From SPI0x12345678
Boot from internal device 1st SPI RESERVED
System Started
Irgendwie habe ich das schon hinbekommen. Ich habe die BootCard von Linux installiert (Reset und die 2 Controller Pins überbrückt). Danach war Recovery Modus da.
Anschließend habe ich die Revert Pure Linux installiert und die Android Boot Card. Jetzt startet mein System. Zwar bringt es beim Loggen ein paar Fehlermeldungen, dass Nand fehlerhafte Sektoren gefunden hat, aber es funktioniert.
Leider sind zwei Punkte bei mir, die ich nicht lösen kann:
- System startet nur am YUV Ausgang. HDMI funktioniert nicht
- Bluetooth startet nicht. Unter Settings, wenn ich Bluetooth auf On umschalte, passiert nichts.
Bluetooth ist nicht integriert .... Kein dongle drin Somit geht's nicht :)
Der ursprüngliche Beitrag von 14:38 Uhr wurde um 14:40 Uhr ergänzt:
Kannst in Android mal versuchen den Ausgang einzustellen ... Bzw mal an einem anderen tv ausprobieren vielleicht ist das Kabel oder eine buchse Fernseher oder Box defekt
Der ursprüngliche Beitrag von 14:40 Uhr wurde um 14:42 Uhr ergänzt:
Übrigens freut mich sehr das alles funktioniert .... Nand Fehler hab ich auch bei meiner neuen Box wo vorher nichts geflasht wurde also alles ok
Der ursprüngliche Beitrag von 14:42 Uhr wurde um 14:43 Uhr ergänzt:
Lief es denn ueberhaupt mal an HDMI ?
Reaktionen: ProTV
HDMI ist nur unter Linux gelaufen, d.h. Kabel und Anschluß sind i.O.
Ich tendiere jetzt Linux auf die Box zu installieren. Ich brauche nur XBMC, wegen der Verbindung mit der Dreambox. Ich möchte die Programme streamen und mir mit der ATV1200 anschauen.
Mit Bluetooth habe ich geklärt. Meine Tastatur hat einen Dongle dazu.
Heute hat sich meine Box nach knapp 4 Monaten tadelosen Betriebs "verabschieded", die Box hat sich aufgehängt und nach einem Neustart versucht die Box eine Neuinstallation und hängt sich bei Angry Birds auf.
Jemand eine Idee was ich tun kann?
Neues "Rom" flashen. Also das was du jetzt drauf hast noch mal per SD karte flashen.
Ich habe mich am Wochenende mit einem RasPi auseinander gesetzt, aber im Gegensatz zur Box eine Schnecke.
Aber ich traue mich ehrlich gesagt, bei den Problemen die ihr hier durch schreibt, nicht auf Linux zu flashen.
Dann habe ich einfach mal alles auf den Werkszustand zurück gesetzt, XBMC 13 Beta 3 installiert und es unter Android in den Autostart gepackt, dafür alles andere was von Werk aus geliefert wird ausgeschaltet.
Es läuft unheimlich flüssig, keine Abstürze mehr. HD Streams aus den Mediatheken sowie Full HD Filme mit DTS laufen ohne zucken.
Reaktionen: Moovster
Kurzes Feedback von meiner Seite:
1. versch. BootCard von Android installiert: Videosignal nur über YUV (Recovery Modus und Betriebssystem). Über Einstellungen ist mir nicht gelungen, das YUV Signal auf HDMI umzustellen.
2. Linux BootCard von Geniatech installiert: Ergebniss wie beim Punkt 1
3. Linux BootCard von Jynxbox installiert: Videosignal über HDMI vorhanden! Die Box rennt!!!
So habe nun meine Box wider zum laufen bekommen über einen Flash von SDCard per Resetknopf, leider habe ich nur eine alte version damit flashen können. Würde jetzt gerne die aktuelle ROM von der myGica seite flashen.
Jedoch habe das Problem das ich über das Updatetool die entsprechenden Dateien nicht auswählen kann. Bin jedoch wie in der Anleitung von myGica vorgegangen. Jemand eine Idee?
@chris2603
Versuch mal über Recovery zu flashen.
Reset Taste drücken, Strom reinstecken und Reset-Knopf 10 Sekunden halten. Du solltest dann in Recovery landen.
Dann stecke die SD Karte mit der jeweiligen Datei in der Box,, geh zu Update -> SDCard -> und wähle die jeweilige Datei. Die Box installiert die Firmware und landet erneut in Recovery Modus. Anschließen solltest Du ein reboot durchführen.
Danke hat super geklappt.
Ich habe bei mir das PVR Addon VU+ installiert und ich konnte mich mit einer Dreambox verbinden. Streaming, inkl. HD läuft wunderbar.
Jetzt habe ich das Problem, dass ich eine zweite Dreambox habe (unterschiedliche Einspeisungen). Meine Frage ist, wie kann ich ein PVR Addon "verdoppeln", so dass ich zwei unterschiedlichen IP-Adressen für zwei AddOns eintragen kann?
hallo an alle,bin neu hier.
habe die Box jetzt auch gekauft.
Ich wollte mal fragen wie ich den Thumbsmail Ordner von XBMC auf meine Externe Sd Karte Auslagern kann,da meine interne Sd bald voll ist.
ich weis das es mit der Advancedsettings.xml gehen soll,habe es aber leider nicht geschafft. Es wäre nett wenn mir jemand helfen könnte,am besten posted jemand bei dem es geht,seine Advancedsettings.xml, müsste ja bei allen gleich sein .
Danke im voraus.
Ich habe die Box auch bestellt und wollte gerne wissen was ihr so empfehlen könnt.
Soll ich einfach auf die neuste Version OTA updaten ?
Zu XBMC, die einfach drauf lassen oder lieber die Gotham Nightlies ?
Es gibt ja eine APP mit der man z.b das Iphone über die Box verbinden kann.
weiß jemand ob man das gesamte Iphone spiegeln kann oder ist das nur mit dem Apple TV möglich?
Wie sieht das spiegeln sonst mit einem Android 4.4.2 Handy aus ?
Danke im voraus
Wenn du nicht zu speziele XBMC Module brauchst, dann empfehle ich dir die aktuelle XBMC 13 Beta. Die läuft echt gut.
http://mirrors.xbmc.org/releases/android/arm/xbmc-13.0-Gotham_beta3-armeabi-v7a.apk
Startup Manager startet einwandfrei XBMC
https://play.google.com/store/apps/details?id=imoblife.startupmanager&hl=de
Als App für XBMC empfehle ich dir die einzig Ware. Yatse
https://play.google.com/store/apps/details?id=org.leetzone.android.yatsewidgetfree&hl=de
Ich habe das MyGica Rom drauf und bin bis auf gelegentliche Freezes mehr als zufrieden. Ich würde es erstmal mit Android probieren, bevor du auf Linux umsteigst - weil das kann auch in die Hose gehen und dann hast du einen teuren Briefbeschwerer.
Reaktionen: Moovster und marquez
funktioniert bei irgendeiner Linux Version Stand-by ? Was passiert wenn man die Ein/Aus Taste auf der Fernbedienung drückt ?
Kann man mit Linux ein USB DVD-Lauwerk benutzen um DVDs abzuspielen oder muss ich sie in ein .ISO Image konvertieren ?
nicpas
oldie62
O
  • Dacius
mblaster4711
mblaster4711
legomovie43
legomovie43
legomovie43
