bananensaft
Enthusiast
- 4.466
Substratum für TouchWiz ist da - ohne Root: [7.0+][Samsung] substratum for SeX/TW (BETA) [12/6/17]
Funktioniert gut
Funktioniert gut
Das Ding kostet allerdings.Is Substratum officially supported on Stock Samsung Nougat TouchWiz or Samsung Experience? Yes, but you will need the addon package available here: Substratum Integration for Samsung (Addon Key) – Android-Apps auf Google Play
Substratum REQUIRES root, or else it will not function!
HOWEVER, if you're running on an OMS-based ROM or a Samsung device with Nougat and above then Substratum will run on rootless mode!
