Probleme beim kompilieren mit apktools
  • 1 Antworten
U
uncle-m
ich habe mir apktools auf mein Ubuntu 14.04.lts installiert. Habe aber probleme mit dem kompilieren.
Code:
mario@mario:~$ apktool d SystemUI.apk
I: Using Apktool 2.0.0-RC2 on SystemUI.apk
I: Loading resource table...
I: Decoding AndroidManifest.xml with resources...
I: Loading resource table from file: /home/mario/apktool/framework/1.apk
I: Regular manifest package...
I: Decoding file-resources...
I: Decoding values */* XMLs...
I: Copying assets and libs...
I: Copying unknown files...
I: Copying original files...
mario@mario:~$ apktool b SystemUI
W: Could not find sources
I: Checking whether resources has changed...
I: Building resources...
Exception in thread "main" brut.androlib.AndrolibException: brut.androlib.AndrolibException: brut.common.BrutException: could not exec command: [/tmp/brut_util_Jar_5394691898287693623.tmp, p, --forced-package-id, 127, --min-sdk-version, 16, --target-sdk-version, 16, --version-code, 16, --version-name, 4.1.2-1358455837, -F, /tmp/APKTOOL6471534235149665357.tmp, -0, arsc, -I, /home/mario/apktool/framework/1.apk, -S, /home/mario/SystemUI/res, -M, /home/mario/SystemUI/AndroidManifest.xml]
    at brut.androlib.Androlib.buildResourcesFull(Androlib.java:449)
    at brut.androlib.Androlib.buildResources(Androlib.java:383)
    at brut.androlib.Androlib.build(Androlib.java:286)
    at brut.androlib.Androlib.build(Androlib.java:258)
    at brut.apktool.Main.cmdBuild(Main.java:240)
    at brut.apktool.Main.main(Main.java:89)
Caused by: brut.androlib.AndrolibException: brut.common.BrutException: could not exec command: [/tmp/brut_util_Jar_5394691898287693623.tmp, p, --forced-package-id, 127, --min-sdk-version, 16, --target-sdk-version, 16, --version-code, 16, --version-name, 4.1.2-1358455837, -F, /tmp/APKTOOL6471534235149665357.tmp, -0, arsc, -I, /home/mario/apktool/framework/1.apk, -S, /home/mario/SystemUI/res, -M, /home/mario/SystemUI/AndroidManifest.xml]
    at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.java:487)
    at brut.androlib.Androlib.buildResourcesFull(Androlib.java:434)
    ... 5 more
Caused by: brut.common.BrutException: could not exec command: [/tmp/brut_util_Jar_5394691898287693623.tmp, p, --forced-package-id, 127, --min-sdk-version, 16, --target-sdk-version, 16, --version-code, 16, --version-name, 4.1.2-1358455837, -F, /tmp/APKTOOL6471534235149665357.tmp, -0, arsc, -I, /home/mario/apktool/framework/1.apk, -S, /home/mario/SystemUI/res, -M, /home/mario/SystemUI/AndroidManifest.xml]
    at brut.util.OS.exec(OS.java:93)
    at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.java:481)
    ... 6 more
Caused by: java.io.IOException: Cannot run program "/tmp/brut_util_Jar_5394691898287693623.tmp": error=2, Datei oder Verzeichnis nicht gefunden
    at java.lang.ProcessBuilder.start(ProcessBuilder.java:1047)
    at java.lang.Runtime.exec(Runtime.java:617)
    at java.lang.Runtime.exec(Runtime.java:485)
    at brut.util.OS.exec(OS.java:84)
    ... 7 more
Caused by: java.io.IOException: error=2, Datei oder Verzeichnis nicht gefunden
    at java.lang.UNIXProcess.forkAndExec(Native Method)
    at java.lang.UNIXProcess.<init>(UNIXProcess.java:186)
    at java.lang.ProcessImpl.start(ProcessImpl.java:130)
    at java.lang.ProcessBuilder.start(ProcessBuilder.java:1028)
    ... 10 more
mario@mario:~$
Ich weiß leider nicht viel damit anzufangen.
Keine Ahnung , aber
I: STRING
müsste für Info: STRING stehen,
W: STRING
müsste für Warning: STRING stehen .
Da du den Befehl ein zeites Mal laufen hast, direkt nach dem funktionierenden ersten Mal,
müsste apktool die Files ge-moved haben , und nicht ge-copied .. ?
:thumbup:
