fehler beim erstellen CM10.2 von Source - Nexus 7 2013
  • 13 Antworten
Sh0X31
Sh0X31
Enthusiast
852
Ich wollte mein CM10.2 selber erstellen und hab dann versucht nach dieser Anleitung (CM-Wiki) zu erstellen, jedoch bekomm ich immer diese Fehlermeldung und der Vorgang wird abgebrochen. Weiß nicht was ich falsch mache. Lauf meinem Laptop läuft Ubuntu 13.10, Java & ADB/Fastboot ist installiert. Hoffe jemand kann mir helfen.
including device/asus/flo/vendorsetup.sh
including device/generic/armv7-a-neon/vendorsetup.sh
including device/generic/goldfish/vendorsetup.sh
including device/generic/mips/vendorsetup.sh
including device/generic/x86/vendorsetup.sh
including vendor/cm/vendorsetup.sh
including sdk/bash_completion/adb.bash
including vendor/cm/bash_completion/git.bash
including vendor/cm/bash_completion/repo.bash
build/core/copy_headers.mk:15: warning: overriding commands for target `/home/mert/android/system/out/target/product/flo/obj/include/qcom/display/copybit.h'
build/core/copy_headers.mk:15: warning: ignoring old commands for target `/home/mert/android/system/out/target/product/flo/obj/include/qcom/display/copybit.h'
build/core/copy_headers.mk:15: warning: overriding commands for target `/home/mert/android/system/out/target/product/flo/obj/include/qcom/display/copybit_priv.h'
build/core/copy_headers.mk:15: warning: ignoring old commands for target `/home/mert/android/system/out/target/product/flo/obj/include/qcom/display/copybit_priv.h'
build/core/Makefile:44: warning: overriding commands for target `/home/mert/android/system/out/target/product/flo/system/vendor/etc/audio_effects.conf'
build/core/base_rules.mk:520: warning: ignoring old commands for target `/home/mert/android/system/out/target/product/flo/system/vendor/etc/audio_effects.conf'
build/core/Makefile:44: warning: overriding commands for target `/home/mert/android/system/out/target/product/flo/system/etc/permissions/android.software.live_wallpaper.xml'
build/core/base_rules.mk:520: warning: ignoring old commands for target `/home/mert/android/system/out/target/product/flo/system/etc/permissions/android.software.live_wallpaper.xml'
build/core/Makefile:44: warning: overriding commands for target `/home/mert/android/system/out/target/product/flo/system/lib/hw/gps.msm8960.so'
build/core/base_rules.mk:520: warning: ignoring old commands for target `/home/mert/android/system/out/target/product/flo/system/lib/hw/gps.msm8960.so'
build/core/Makefile:44: warning: overriding commands for target `/home/mert/android/system/out/target/product/flo/system/lib/libgps.utils.so'
build/core/base_rules.mk:520: warning: ignoring old commands for target `/home/mert/android/system/out/target/product/flo/system/lib/libgps.utils.so'
build/core/Makefile:44: warning: overriding commands for target `/home/mert/android/system/out/target/product/flo/system/lib/libloc_adapter.so'
build/core/base_rules.mk:520: warning: ignoring old commands for target `/home/mert/android/system/out/target/product/flo/system/lib/libloc_adapter.so'
build/core/Makefile:44: warning: overriding commands for target `/home/mert/android/system/out/target/product/flo/system/lib/libloc_eng.so'
build/core/base_rules.mk:520: warning: ignoring old commands for target `/home/mert/android/system/out/target/product/flo/system/lib/libloc_eng.so'
arch/arm/configs/flo_defconfig:547:warning: override: reassigning to symbol CMA
make: *** No rule to make target `vendor/asus/flo/proprietary/bin/mpdecision', needed by `/home/mert/android/system/out/target/product/flo/system/bin/mpdecision'. Stop.
make: *** Waiting for unfinished jobs....
mert@mert-UX31A:~/android/system$
Das sind nur Warnings, die würden nicht zum Abbruch führen, da muss noch irgendwo ein Errror dabei sein.
Den Error musst Du posten
MfG Uwe
Ok, aber nicht writer hochscrollen.
Was soll mir diese Aussage sagen?
MfG Uwe
Das ich den fehler nicht so finden kann. Speichert er beim bauen keine text datei, wo ich gucken kann?
Vielleicht solltes Du vor dem Posten Deine Beiträge nochmal durchlesen, sonst versteht man es kaum...
Unter Linux (und auch anderen Betriebssystemen) besteht die Möglichkeit, die Ausgabe eines Aufrufes in eine Datei umzuleiten, indem man statt
Code:
brunch xyz
ein ' > out.txt' anhängt:
Code:
brunch xyz > out.txt
Dann kannst Du in der Datei out.txt nachgucken...
MfG Uwe
Der ursprüngliche Beitrag von 13:56 Uhr wurde um 14:05 Uhr ergänzt:
Kommando zurück!
Das mit dem Umleiten in die Ausgabe ist doch nicht ganz so einfach, das brunch-Kommando schafft es, sich an der Umleitung vorbeizumogeln.
Ich gucke mal was man alternativ machen kann...
MfG Uwe
Der ursprüngliche Beitrag von 14:05 Uhr wurde um 14:23 Uhr ergänzt:
Mein Fehler war, dass ich nur stdout in die Datei umgeleitet habe, um auch stderr umzuleiten (aus dem die Fehler und Warnungen rauskommen) muss man statt ' > out.txt' den Anhang ' &> out.txt' verwenden, also:
Code:
brunch xyz &> out.txt
MfG Uwe
Alles klar, hab ich ausgeführt und hier ist die out.txt
  • out.txt
Spontan würde ich sagen du hast das proprietäre zeug nicht drin.
Code:
Hast du die vendor dateien fürs flo drin? (z.b. von hier https://github.com/TheMuppets/ )
Wurde die proprietären Daten nicht mit "./extract-files.sh" hinzugefügt?
Also ./extract-files.sh hab ich in "~/android/system/device/asus/flo" gemacht und dann die Daten in "vendor" kopiert.
wie es hier steht:
Now ensure that your Nexus 7 (Wi-Fi, 2013 version) is connected to your computer via the USB cable and that you are in the ~/android/system/device/asus/flo directory (you can cd ~/android/system/device/asus/flo if necessary). Then run the extract-files.sh script:
$ ./extract-files.sh
You should see the proprietary files (aka “blobs”) get pulled from the device and moved to the right place in the vendor directory. If you see errors about adb being unable to pull the files, adb may not be in the path of execution. If this is the case, see the adb page for suggestions for dealing with "command not found" errors.
Ich schätze du hast kein flo-vendor.mk in /vendor/asus/flo sondern device-vendor ?.
In device/asus/flo/cm.mk steht u.a.:
$(call inherit-product, device/asus/flo/full_flo.mk) in full_flo u.a. : $(call inherit-product-if-exists, vendor/asus/flo/flo-vendor.mk). Entweder den richtigen pfad dazu oder dateinamen ändern.
Doch habe alle mk-Datein im richtigen Ordner. Hab aber die cm.mk geändert und versuche es jetzt mal.
Es hat wieder nicht funktioniert. Hier ist die aktuelle out.txt.
  • out.txt
Aber wieso hast du cm.mk geändert (was in was?)
out.txt sieht man leider nicht, aber dann vmtl. der gleicher Fehler?
.. war käse ...
Ja, wieder der Fehler mit "No rule to make target `vendor/asus/flo/proprietary/bin/mpdecision'"
Hab in der cm.mk folgendes geändert:
$(call inherit-product, device/asus/flo/full_flo.mk) -> $(call inherit-product-if-exists, vendor/asus/flo/flo-vendor.mk)
Hatte zuletzt zufällig ein ähnliches Problem (aosp rom)
busybox, nano, bash sollte mit rein, habs dann entsprechend zu manifest/default.xml hinzugefügt und "mitgesynct" und bekam dann ein ähnlichen Fehler:
Code:
Export includes file: external/busybox/Android.mk -- out/target/product/mako/obj/EXECUTABLES/busybox_intermediates/export_includes
make: *** No rule to make target `out/target/product/mako/obj/SHARED_LIBRARIES/libncurses_intermediates/export_includes', needed by `out/target/product/mako/obj/EXECUTABLES/nano_intermediates/import_includes'.  Stop.
einfach nur runterladen war natürlich dämlich, die entsprechenden "pakete" mussten dann noch mit PRODUCT_PACKAGES +- = entsprechend hinzugefügt werden, dann gings schonmal weiter:
./build.sh
Nur Neu (1) / Installclean (2) / Clean (3) / Clobber (4) --- (1) / (2) / (3) / (4) -> 1
including device/asus/tilapia/vendorsetup.sh
including device/asus/deb/vendorsetup.sh
including device/asus/grouper/vendorsetup.sh
including device/samsung/manta/vendorsetup.sh
including device/lge/mako/vendorsetup.sh
including device/lge/hammerhead/vendorsetup.sh
PLATFORM_VERSION_CODENAME=REL
PLATFORM_VERSION=4.4
TARGET_PRODUCT=aosp_mako
TARGET_BUILD_VARIANT=userdebug
TARGET_BUILD_TYPE=release
TARGET_BUILD_APPS=
TARGET_ARCH=arm
TARGET_ARCH_VARIANT=armv7-a-neon
TARGET_CPU_VARIANT=krait
HOST_ARCH=x86
HOST_OS=linux
HOST_OS_EXTRA=Linux-3.8.0-33-generic-x86_64-with-LinuxMint-15-olivia
HOST_BUILD_TYPE=release
BUILD_ID=KRT16S
OUT_DIR=out
Odex oder Deodexed? ( o / d ) d
TARGET_BUILD_APPS=
TARGET_ARCH=arm
HOST_ARCH=x86
HOST_OS=linux
BUILD_ID=KRT16S
OUT_DIR=out
including ./abi/cpp/Android.mk ...
including ./art/Android.mk ...
including ./bionic/Android.mk ...
including ./bootable/diskinstaller/Android.mk ...
including ./bootable/recovery/Android.mk ...
including ./build/libs/host/Android.mk ...
including ./build/target/board/Android.mk ...
including ./build/tools/Android.mk ...
including ./cts/Android.mk ...
including ./dalvik/Android.mk ...
including ./development/apps/BluetoothDebug/Android.mk ...
including ./development/apps/BuildWidget/Android.mk ...
including ./development/apps/CustomLocale/Android.mk ...
including ./development/apps/Development/Android.mk ...
including ./development/apps/DevelopmentSettings/Android.mk ...
including ./development/apps/Fallback/Android.mk ...
including ./development/apps/GestureBuilder/Android.mk ...
including ./development/apps/NinePatchLab/Android.mk ...
including ./development/apps/OBJViewer/Android.mk ...
including ./development/apps/SdkSetup/Android.mk ...
including ./development/apps/SettingInjectorSample/Android.mk ...
including ./development/apps/WidgetPreview/Android.mk ...
including ./development/apps/launchperf/Android.mk ...
including ./development/build/Android.mk ...
including ./development/cmds/monkey/Android.mk ...
including ./development/host/Android.mk ...
including ./development/ndk/Android.mk ...
including ./development/samples/AccelerometerPlay/Android.mk ...
including ./development/samples/ActionBarCompat/Android.mk ...
including ./development/samples/AliasActivity/Android.mk ...
including ./development/samples/AndroidBeamDemo/Android.mk ...
including ./development/samples/ApiDemos/Android.mk ...
including ./development/samples/AppNavigation/Android.mk ...
including ./development/samples/BackupRestore/Android.mk ...
including ./development/samples/BasicGLSurfaceView/Android.mk ...
including ./development/samples/BluetoothChat/Android.mk ...
including ./development/samples/BluetoothHDP/Android.mk ...
including ./development/samples/BusinessCard/Android.mk ...
including ./development/samples/Compass/Android.mk ...
including ./development/samples/ContactManager/Android.mk ...
including ./development/samples/CubeLiveWallpaper/Android.mk ...
including ./development/samples/FixedGridLayout/Android.mk ...
including ./development/samples/HeavyWeight/Android.mk ...
including ./development/samples/HelloActivity/Android.mk ...
including ./development/samples/HelloEffects/Android.mk ...
including ./development/samples/Home/Android.mk ...
including ./development/samples/HoneycombGallery/Android.mk ...
including ./development/samples/JetBoy/Android.mk ...
including ./development/samples/KeyChainDemo/Android.mk ...
including ./development/samples/LunarLander/Android.mk ...
including ./development/samples/MultiResolution/Android.mk ...
including ./development/samples/MySampleRss/Android.mk ...
including ./development/samples/NotePad/Android.mk ...
including ./development/samples/Obb/Android.mk ...
including ./development/samples/RSSReader/Android.mk ...
including ./development/samples/RandomMusicPlayer/Android.mk ...
including ./development/samples/RenderScript/Android.mk ...
including ./development/samples/SampleSyncAdapter/Android.mk ...
including ./development/samples/SearchableDictionary/Android.mk ...
including ./development/samples/SimpleJNI/Android.mk ...
including ./development/samples/SipDemo/Android.mk ...
including ./development/samples/SkeletonApp/Android.mk ...
including ./development/samples/Snake/Android.mk ...
including ./development/samples/SoftKeyboard/Android.mk ...
including ./development/samples/SpellChecker/Android.mk ...
including ./development/samples/StackWidget/Android.mk ...
including ./development/samples/Support13Demos/Android.mk ...
including ./development/samples/Support4Demos/Android.mk ...
including ./development/samples/Support7Demos/Android.mk ...
including ./development/samples/SupportAppNavigation/Android.mk ...
including ./development/samples/ToyVpn/Android.mk ...
including ./development/samples/TtsEngine/Android.mk ...
including ./development/samples/USB/Android.mk ...
including ./development/samples/UiAutomator/Android.mk ...
including ./development/samples/VoiceRecognitionService/Android.mk ...
including ./development/samples/VoicemailProviderDemo/Android.mk ...
including ./development/samples/WeatherListWidget/Android.mk ...
including ./development/samples/WiFiDirectDemo/Android.mk ...
including ./development/samples/WiFiDirectServiceDiscovery/Android.mk ...
including ./development/samples/Wiktionary/Android.mk ...
including ./development/samples/WiktionarySimple/Android.mk ...
including ./development/samples/XmlAdapters/Android.mk ...
including ./development/samples/training/NsdChat/Android.mk ...
including ./development/testrunner/Android.mk ...
including ./development/tools/apkcheck/Android.mk ...
including ./development/tools/elftree/Android.mk ...
including ./development/tools/emulator/test-apps/ConnectivityTest/Android.mk ...
including ./development/tools/emulator/test-apps/GpsLocationTest/Android.mk ...
including ./development/tools/etc1tool/Android.mk ...
including ./development/tools/hosttestlib/Android.mk ...
including ./development/tools/idegen/Android.mk ...
including ./development/tools/line_endings/Android.mk ...
including ./development/tools/mkstubs/Android.mk ...
including ./development/tools/recovery_l10n/Android.mk ...
including ./development/tools/yuv420sp2rgb/Android.mk ...
including ./development/tutorials/MoarRam/Android.mk ...
including ./development/tutorials/NotepadCodeLab/Notepadv1/Android.mk ...
including ./development/tutorials/NotepadCodeLab/Notepadv1Solution/Android.mk ...
including ./development/tutorials/NotepadCodeLab/Notepadv2/Android.mk ...
including ./development/tutorials/NotepadCodeLab/Notepadv2Solution/Android.mk ...
including ./development/tutorials/NotepadCodeLab/Notepadv3/Android.mk ...
including ./development/tutorials/NotepadCodeLab/Notepadv3Solution/Android.mk ...
including ./development/tutorials/ReverseDebug/Android.mk ...
including ./device/asus/deb/dumpstate/Android.mk ...
including ./device/asus/deb/recovery/Android.mk ...
including ./device/asus/deb/self-extractors/Android.mk ...
including ./device/asus/flo/Android.mk ...
including ./device/asus/grouper/Android.mk ...
including ./device/asus/tilapia/recovery/Android.mk ...
including ./device/asus/tilapia/self-extractors/Android.mk ...
including ./device/generic/goldfish/audio/Android.mk ...
including ./device/generic/goldfish/camera/Android.mk ...
including ./device/generic/goldfish/gps/Android.mk ...
including ./device/generic/goldfish/lights/Android.mk ...
including ./device/generic/goldfish/opengl/Android.mk ...
including ./device/generic/goldfish/power/Android.mk ...
including ./device/generic/goldfish/qemu-props/Android.mk ...
including ./device/generic/goldfish/qemud/Android.mk ...
including ./device/generic/goldfish/sensors/Android.mk ...
including ./device/google/accessory/arduino/Android.mk ...
including ./device/google/accessory/demokit/Android.mk ...
including ./device/lge/hammerhead/Android.mk ...
including ./device/lge/mako/Android.mk ...
including ./device/sample/Android.mk ...
including ./device/samsung/manta/Android.mk ...
including ./docs/source.android.com/Android.mk ...
including ./external/aac/Android.mk ...
including ./external/android-clat/Android.mk ...
including ./external/android-mock/Android.mk ...
including ./external/ant-glob/Android.mk ...
including ./external/antlr/Android.mk ...
including ./external/apache-harmony/Android.mk ...
including ./external/apache-http/Android.mk ...
including ./external/apache-xml/Android.mk ...
including ./external/bash/Android.mk ...
including ./external/bison/Android.mk ...
including ./external/blktrace/Android.mk ...
including ./external/bluetooth/bluedroid/Android.mk ...
including ./external/bouncycastle/Android.mk ...
including ./external/bsdiff/Android.mk ...
including ./external/busybox/Android.mk ...
including ./external/bzip2/Android.mk ...
including ./external/ceres-solver/Android.mk ...
including ./external/checkpolicy/Android.mk ...
including ./external/chromium-libpac/Android.mk ...
including ./external/chromium/Android.mk ...
including ./external/chromium_org/Android.mk ...
including ./external/clang/Android.mk ...
including ./external/compiler-rt/Android.mk ...
including ./external/dexmaker/Android.mk ...
including ./external/dhcpcd/Android.mk ...
including ./external/dnsmasq/Android.mk ...
including ./external/doclava/Android.mk ...
including ./external/droiddriver/Android.mk ...
including ./external/dropbear/Android.mk ...
including ./external/e2fsprogs/Android.mk ...
including ./external/easymock/Android.mk ...
including ./external/eclipse-windowbuilder/propertysheet/Android.mk ...
including ./external/eigen/Android.mk ...
including ./external/elfutils/Android.mk ...
including ./external/embunit/Android.mk ...
including ./external/emma/Android.mk ...
including ./external/expat/Android.mk ...
including ./external/eyes-free/Android.mk ...
including ./external/fdlibm/Android.mk ...
including ./external/flac/Android.mk ...
including ./external/freetype/Android.mk ...
including ./external/fsck_msdos/Android.mk ...
including ./external/ganymed-ssh2/Android.mk ...
including ./external/gcc-demangle/Android.mk ...
including ./external/genext2fs/Android.mk ...
including ./external/giflib/Android.mk ...
including ./external/google-diff-match-patch/Android.mk ...
including ./external/grub/Android.mk ...
including ./external/gtest/Android.mk ...
including ./external/guava/Android.mk ...
including ./external/hamcrest/Android.mk ...
including ./external/harfbuzz/Android.mk ...
including ./external/harfbuzz_ng/Android.mk ...
including ./external/hyphenation/Android.mk ...
including ./external/icu4c/Android.mk ...
including ./external/iproute2/Android.mk ...
including ./external/ipsec-tools/Android.mk ...
including ./external/iptables/Android.mk ...
including ./external/iputils/Android.mk ...
including ./external/javasqlite/Android.mk ...
including ./external/javassist/Android.mk ...
including ./external/jdiff/Android.mk ...
including ./external/jhead/Android.mk ...
including ./external/jmdns/Android.mk ...
including ./external/jmonkeyengine/Android.mk ...
including ./external/jpeg/Android.mk ...
including ./external/jsilver/Android.mk ...
including ./external/jsr305/Android.mk ...
including ./external/junit/Android.mk ...
including ./external/libcap-ng/Android.mk ...
including ./external/libffi/Android.mk ...
including ./external/libgsm/Android.mk ...
including ./external/liblzf/Android.mk ...
including ./external/libnfc-nci/Android.mk ...
including ./external/libnfc-nxp/Android.mk ...
including ./external/libnl-headers/Android.mk ...
including ./external/libogg/Android.mk ...
including ./external/libpcap/Android.mk ...
including ./external/libpng/Android.mk ...
including ./external/libselinux/Android.mk ...
including ./external/libsepol/Android.mk ...
including ./external/libvorbis/Android.mk ...
including ./external/libvpx/Android.mk ...
including ./external/libxml2/Android.mk ...
including ./external/libxslt/Android.mk ...
including ./external/libyuv/Android.mk ...
including ./external/linux-tools-perf/Android.mk ...
including ./external/littlemock/Android.mk ...
including ./external/llvm/Android.mk ...
including ./external/marisa-trie/Android.mk ...
including ./external/markdown/Android.mk ...
including ./external/mdnsresponder/Android.mk ...
including ./external/mesa3d/Android.mk ...
including ./external/mksh/Android.mk ...
including ./external/mockito/Android.mk ...
including ./external/mockwebserver/Android.mk ...
including ./external/mp4parser/Android.mk ...
including ./external/mtpd/Android.mk ...
including ./external/nano/Android.mk ...
including ./external/naver-fonts/Android.mk ...
including ./external/netcat/Android.mk ...
including ./external/netperf/Android.mk ...
including ./external/neven/Android.mk ...
including ./external/nist-pkits/Android.mk ...
including ./external/noto-fonts/Android.mk ...
including ./external/oauth/core/src/main/java/Android.mk ...
including ./external/objenesis/Android.mk ...
including ./external/okhttp/Android.mk ...
including ./external/open-vcdiff/Android.mk ...
including ./external/opencv/Android.mk ...
including ./external/openfst/Android.mk ...
including ./external/openssh/Android.mk ...
including ./external/openssl/Android.mk ...
including ./external/oprofile/Android.mk ...
including ./external/pixman/Android.mk ...
including ./external/ppp/pppd/Android.mk ...
including ./external/protobuf/Android.mk ...
including ./external/qemu/Android.mk ...
including ./external/regex-re2/Android.mk ...
including ./external/replicaisland/Android.mk ...
including ./external/robolectric/Android.mk ...
including ./external/safe-iop/Android.mk ...
including ./external/scrypt/Android.mk ...
including ./external/sepolicy/Android.mk ...
including ./external/sfntly/Android.mk ...
including ./external/sil-fonts/Android.mk ...
including ./external/skia/Android.mk ...
including ./external/smack/Android.mk ...
including ./external/smali/baksmali/Android.mk ...
including ./external/smali/deodexerant/Android.mk ...
including ./external/smali/smali/Android.mk ...
including ./external/sonivox/Android.mk ...
including ./external/speex/Android.mk ...
including ./external/sqlite/android/Android.mk ...
including ./external/sqlite/dist/Android.mk ...
including ./external/srec/Android.mk ...
including ./external/srtp/Android.mk ...
including ./external/stlport/Android.mk ...
including ./external/strace/Android.mk ...
including ./external/stressapptest/Android.mk ...
including ./external/svox/Android.mk ...
including ./external/tcpdump/Android.mk ...
including ./external/tinyalsa/Android.mk ...
including ./external/tinycompress/Android.mk ...
including ./external/tinyxml/Android.mk ...
including ./external/tinyxml2/Android.mk ...
including ./external/tremolo/Android.mk ...
including ./external/v8/Android.mk ...
including ./external/valgrind/Android.mk ...
including ./external/webp/Android.mk ...
including ./external/webrtc/Android.mk ...
including ./external/wpa_supplicant_8/Android.mk ...
including ./external/xmp_toolkit/Android.mk ...
including ./external/yaffs2/Android.mk ...
including ./external/zlib/Android.mk ...
including ./external/zxing/Android.mk ...
including ./frameworks/av/camera/Android.mk ...
including ./frameworks/av/cmds/screenrecord/Android.mk ...
including ./frameworks/av/cmds/stagefright/Android.mk ...
including ./frameworks/av/drm/common/Android.mk ...
including ./frameworks/av/drm/drmserver/Android.mk ...
including ./frameworks/av/drm/libdrmframework/Android.mk ...
including ./frameworks/av/drm/mediadrm/plugins/mock/Android.mk ...
including ./frameworks/av/libvideoeditor/Android.mk ...
including ./frameworks/av/media/common_time/Android.mk ...
including ./frameworks/av/media/libcpustats/Android.mk ...
including ./frameworks/av/media/libeffects/downmix/Android.mk ...
including ./frameworks/av/media/libeffects/factory/Android.mk ...
including ./frameworks/av/media/libeffects/loudness/Android.mk ...
including ./frameworks/av/media/libeffects/lvm/lib/Android.mk ...
including ./frameworks/av/media/libeffects/lvm/wrapper/Android.mk ...
including ./frameworks/av/media/libeffects/preprocessing/Android.mk ...
including ./frameworks/av/media/libeffects/proxy/Android.mk ...
including ./frameworks/av/media/libeffects/visualizer/Android.mk ...
including ./frameworks/av/media/libmedia/Android.mk ...
including ./frameworks/av/media/libmediaplayerservice/Android.mk ...
including ./frameworks/av/media/libnbaio/Android.mk ...
including ./frameworks/av/media/libstagefright/Android.mk ...
including ./frameworks/av/media/mediaserver/Android.mk ...
including ./frameworks/av/media/mtp/Android.mk ...
including ./frameworks/av/services/audioflinger/Android.mk ...
including ./frameworks/av/services/camera/libcameraservice/Android.mk ...
including ./frameworks/av/services/medialog/Android.mk ...
including ./frameworks/av/tools/resampler_tools/Android.mk ...
including ./frameworks/base/Android.mk ...
find: `src': No such file or directory
including ./frameworks/compile/libbcc/Android.mk ...
including ./frameworks/compile/mclinker/Android.mk ...
including ./frameworks/compile/slang/Android.mk ...
including ./frameworks/ex/camera2/Android.mk ...
including ./frameworks/ex/carousel/Android.mk ...
including ./frameworks/ex/chips/Android.mk ...
including ./frameworks/ex/common/Android.mk ...
including ./frameworks/ex/variablespeed/Android.mk ...
including ./frameworks/ml/Android.mk ...
including ./frameworks/native/cmds/atrace/Android.mk ...
including ./frameworks/native/cmds/bugreport/Android.mk ...
including ./frameworks/native/cmds/dumpstate/Android.mk ...
including ./frameworks/native/cmds/dumpsys/Android.mk ...
including ./frameworks/native/cmds/flatland/Android.mk ...
including ./frameworks/native/cmds/installd/Android.mk ...
including ./frameworks/native/cmds/ip-up-vpn/Android.mk ...
including ./frameworks/native/cmds/rawbu/Android.mk ...
including ./frameworks/native/cmds/screenshot/Android.mk ...
including ./frameworks/native/cmds/service/Android.mk ...
including ./frameworks/native/cmds/servicemanager/Android.mk ...
including ./frameworks/native/libs/binder/Android.mk ...
including ./frameworks/native/libs/diskusage/Android.mk ...
including ./frameworks/native/libs/gui/Android.mk ...
including ./frameworks/native/libs/input/Android.mk ...
including ./frameworks/native/libs/ui/Android.mk ...
including ./frameworks/native/opengl/libagl/Android.mk ...
including ./frameworks/native/opengl/libs/Android.mk ...
including ./frameworks/native/opengl/tests/Android.mk ...
including ./frameworks/native/services/batteryservice/Android.mk ...
including ./frameworks/native/services/connectivitymanager/Android.mk ...
including ./frameworks/native/services/powermanager/Android.mk ...
including ./frameworks/native/services/sensorservice/Android.mk ...
including ./frameworks/native/services/surfaceflinger/Android.mk ...
including ./frameworks/opt/calendar/Android.mk ...
including ./frameworks/opt/colorpicker/Android.mk ...
including ./frameworks/opt/datetimepicker/Android.mk ...
including ./frameworks/opt/emoji/Android.mk ...
including ./frameworks/opt/inputmethodcommon/Android.mk ...
including ./frameworks/opt/mailcommon/Android.mk ...
including ./frameworks/opt/mms/Android.mk ...
including ./frameworks/opt/net/voip/Android.mk ...
including ./frameworks/opt/photoviewer/Android.mk ...
including ./frameworks/opt/telephony/Android.mk ...
including ./frameworks/opt/timezonepicker/Android.mk ...
including ./frameworks/opt/vcard/Android.mk ...
including ./frameworks/rs/Android.mk ...
including ./frameworks/support/tests/Android.mk ...
including ./frameworks/support/v13/Android.mk ...
including ./frameworks/support/v4/Android.mk ...
including ./frameworks/support/v7/appcompat/Android.mk ...
including ./frameworks/support/v7/gridlayout/Android.mk ...
including ./frameworks/support/v7/mediarouter/Android.mk ...
including ./frameworks/support/v8/renderscript/Android.mk ...
including ./frameworks/testing/Android.mk ...
including ./frameworks/uiautomator/Android.mk ...
frameworks/uiautomator/Android.mk:82: warning: overriding commands for target `out/target/common/obj/PACKAGING/uiautomator-checkapi-last-timestamp'
frameworks/testing/uiautomator/library/Android.mk:82: warning: ignoring old commands for target `out/target/common/obj/PACKAGING/uiautomator-checkapi-last-timestamp'
frameworks/uiautomator/Android.mk:99: warning: overriding commands for target `out/target/common/obj/PACKAGING/uiautomator-checkapi-current-timestamp'
frameworks/testing/uiautomator/library/Android.mk:99: warning: ignoring old commands for target `out/target/common/obj/PACKAGING/uiautomator-checkapi-current-timestamp'
frameworks/uiautomator/Android.mk:111: warning: overriding commands for target `update-uiautomator-api'
frameworks/testing/uiautomator/library/Android.mk:111: warning: ignoring old commands for target `update-uiautomator-api'
including ./frameworks/volley/Android.mk ...
including ./frameworks/webview/Android.mk ...
including ./frameworks/wilhelm/src/Android.mk ...
including ./frameworks/wilhelm/tests/Android.mk ...
including ./hardware/akm/AK8975_FS/akmdfs/Android.mk ...
including ./hardware/akm/AK8975_FS/libsensors/Android.mk ...
including ./hardware/broadcom/libbt/Android.mk ...
including ./hardware/broadcom/wlan/bcmdhd/Android.mk ...
including ./hardware/cm/audio/Android.mk ...
including ./hardware/cm/power/Android.mk ...
including ./hardware/invensense/Android.mk ...
including ./hardware/libhardware/Android.mk ...
including ./hardware/libhardware_legacy/Android.mk ...
including ./hardware/qcom/audio/Android.mk ...
including ./hardware/qcom/bt/Android.mk ...
including ./hardware/qcom/camera/Android.mk ...
including ./hardware/qcom/display/Android.mk ...
including ./hardware/qcom/gps/core/Android.mk ...
including ./hardware/qcom/gps/etc/Android.mk ...
including ./hardware/qcom/gps/loc_api/Android.mk ...
including ./hardware/qcom/gps/utils/Android.mk ...
including ./hardware/qcom/keymaster/Android.mk ...
including ./hardware/qcom/media/Android.mk ...
including ./hardware/qcom/power/Android.mk ...
including ./hardware/qcom/wlan/qcwcn/Android.mk ...
including ./hardware/ril/libril/Android.mk ...
including ./hardware/ril/librilutils/Android.mk ...
including ./hardware/ril/reference-ril/Android.mk ...
including ./hardware/ril/rild/Android.mk ...
including ./hardware/samsung_slsi/exynos5/Android.mk ...
including ./hardware/ti/omap3/Android.mk ...
including ./hardware/ti/omap4xxx/Android.mk ...
including ./hardware/ti/wlan/mac80211/Android.mk ...
including ./hardware/ti/wpan/Android.mk ...
including ./libcore/Android.mk ...
including ./libnativehelper/Android.mk ...
including ./ndk/Android.mk ...
including ./packages/apps/BasicSmsReceiver/Android.mk ...
including ./packages/apps/Bluetooth/Android.mk ...
including ./packages/apps/Browser/Android.mk ...
including ./packages/apps/CMFileManager/Android.mk ...
including ./packages/apps/Calculator/Android.mk ...
including ./packages/apps/Calendar/Android.mk ...
including ./packages/apps/Camera/Android.mk ...
including ./packages/apps/Camera2/Android.mk ...
including ./packages/apps/CellBroadcastReceiver/Android.mk ...
including ./packages/apps/CertInstaller/Android.mk ...
including ./packages/apps/Contacts/Android.mk ...
including ./packages/apps/ContactsCommon/Android.mk ...
including ./packages/apps/DeskClock/Android.mk ...
including ./packages/apps/Dialer/Android.mk ...
including ./packages/apps/Email/Android.mk ...
including ./packages/apps/Exchange/Android.mk ...
including ./packages/apps/Gallery/Android.mk ...
including ./packages/apps/Gallery2/Android.mk ...
including ./packages/apps/HTMLViewer/Android.mk ...
including ./packages/apps/InCallUI/Android.mk ...
including ./packages/apps/KeyChain/Android.mk ...
including ./packages/apps/Launcher2/Android.mk ...
including ./packages/apps/Launcher3/Android.mk ...
including ./packages/apps/LegacyCamera/Android.mk ...
including ./packages/apps/Mms/Android.mk ...
including ./packages/apps/Music/Android.mk ...
including ./packages/apps/MusicFX/Android.mk ...
including ./packages/apps/Nfc/Android.mk ...
including ./packages/apps/OneTimeInitializer/Android.mk ...
including ./packages/apps/PackageInstaller/Android.mk ...
including ./packages/apps/PhoneCommon/Android.mk ...
including ./packages/apps/Protips/Android.mk ...
including ./packages/apps/Provision/Android.mk ...
including ./packages/apps/QuickSearchBox/Android.mk ...
including ./packages/apps/Settings/Android.mk ...
including ./packages/apps/SoundRecorder/Android.mk ...
including ./packages/apps/SpareParts/Android.mk ...
including ./packages/apps/SpeechRecorder/Android.mk ...
including ./packages/apps/Stk/Android.mk ...
including ./packages/apps/Tag/Android.mk ...
including ./packages/apps/Torch/Android.mk ...
including ./packages/apps/UnifiedEmail/Android.mk ...
including ./packages/apps/VideoEditor/Android.mk ...
including ./packages/apps/VoiceDialer/Android.mk ...
including ./packages/experimental/Android.mk ...
including ./packages/inputmethods/LatinIME/Android.mk ...
including ./packages/inputmethods/OpenWnn/Android.mk ...
including ./packages/inputmethods/PinyinIME/Android.mk ...
including ./packages/providers/CalendarProvider/Android.mk ...
including ./packages/providers/ContactsProvider/Android.mk ...
including ./packages/providers/DownloadProvider/Android.mk ...
including ./packages/providers/MediaProvider/Android.mk ...
including ./packages/providers/PartnerBookmarksProvider/Android.mk ...
including ./packages/providers/TelephonyProvider/Android.mk ...
including ./packages/providers/UserDictionaryProvider/Android.mk ...
including ./packages/screensavers/Basic/Android.mk ...
including ./packages/screensavers/PhotoTable/Android.mk ...
including ./packages/screensavers/WebView/Android.mk ...
including ./packages/services/Telephony/Android.mk ...
including ./packages/wallpapers/Basic/Android.mk ...
including ./packages/wallpapers/Galaxy4/Android.mk ...
including ./packages/wallpapers/HoloSpiral/Android.mk ...
including ./packages/wallpapers/LivePicker/Android.mk ...
including ./packages/wallpapers/MagicSmoke/Android.mk ...
including ./packages/wallpapers/MusicVisualization/Android.mk ...
including ./packages/wallpapers/NoiseField/Android.mk ...
including ./packages/wallpapers/PhaseBeam/Android.mk ...
including ./pdk/apps/CameraITS/Android.mk ...
including ./pdk/apps/HelloPDK/Android.mk ...
including ./pdk/apps/TestingCamera/Android.mk ...
including ./pdk/apps/TestingCamera2/Android.mk ...
including ./prebuilts/gcc/darwin-x86/arm/arm-linux-androideabi-4.6/Android.mk ...
including ./prebuilts/gcc/darwin-x86/arm/arm-linux-androideabi-4.7/Android.mk ...
including ./prebuilts/gcc/darwin-x86/mips/mipsel-linux-android-4.7/Android.mk ...
including ./prebuilts/gcc/linux-x86/arm/arm-linux-androideabi-4.6/Android.mk ...
including ./prebuilts/gcc/linux-x86/arm/arm-linux-androideabi-4.7/Android.mk ...
including ./prebuilts/gcc/linux-x86/mips/mipsel-linux-android-4.7/Android.mk ...
including ./prebuilts/misc/Android.mk ...
including ./prebuilts/ndk/Android.mk ...
including ./prebuilts/qemu-kernel/x86/pc-bios/Android.mk ...
including ./prebuilts/runtime/Android.mk ...
including ./prebuilts/sdk/Android.mk ...
including ./prebuilts/tools/Android.mk ...
including ./sdk/adtproductbuild/Android.mk ...
including ./sdk/annotations/Android.mk ...
including ./sdk/avdlauncher/Android.mk ...
including ./sdk/dumpeventlog/Android.mk ...
including ./sdk/emulator/mksdcard/Android.mk ...
including ./sdk/emulator/opengl/Android.mk ...
including ./sdk/emulator/qtools/Android.mk ...
including ./sdk/eventanalyzer/Android.mk ...
including ./sdk/find_java/Android.mk ...
including ./sdk/find_lock/Android.mk ...
including ./sdk/hierarchyviewer/etc/Android.mk ...
including ./sdk/hierarchyviewer/src/Android.mk ...
including ./sdk/monitor/Android.mk ...
including ./sdk/sdklauncher/Android.mk ...
including ./system/core/Android.mk ...
including ./system/extras/Android.mk ...
including ./system/media/audio_route/Android.mk ...
including ./system/media/audio_utils/Android.mk ...
including ./system/media/camera/src/Android.mk ...
including ./system/media/camera/tests/Android.mk ...
including ./system/netd/Android.mk ...
including ./system/security/keystore-engine/Android.mk ...
including ./system/security/keystore/Android.mk ...
including ./system/security/softkeymaster/Android.mk ...
including ./system/vold/Android.mk ...
including ./tools/external/fat32lib/Android.mk ...
including ./vendor/broadcom/grouper/proprietary/Android.mk ...
including ./vendor/broadcom/maguro/proprietary/Android.mk ...
including ./vendor/broadcom/manta/proprietary/Android.mk ...
including ./vendor/broadcom/tilapia/proprietary/Android.mk ...
including ./vendor/broadcom/toro/proprietary/Android.mk ...
including ./vendor/broadcom/toroplus/proprietary/Android.mk ...
including ./vendor/qcom/deb/proprietary/Android.mk ...
including ./vendor/qcom/flo/proprietary/Android.mk ...
including ./vendor/qcom/hammerhead/proprietary/Android.mk ...
including ./vendor/qcom/mako/proprietary/Android.mk ...
PRODUCT_COPY_FILES device/generic/goldfish/data/etc/apns-conf.xml:system/etc/apns-conf.xml ignored.
build/core/Makefile:32: warning: overriding commands for target `out/target/product/mako/system/lib/libjni_latinime.so'
build/core/base_rules.mk:529: warning: ignoring old commands for target `out/target/product/mako/system/lib/libjni_latinime.so'
No private recovery resources for TARGET_DEVICE mako
Target buildinfo: out/target/product/mako/system/build.prop
Import includes file: out/target/product/mako/obj/EXECUTABLES/busybox_intermediates/import_includes
target thumb C: libclearsilverregex <= external/busybox/android/regex/regex.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/auth_none.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/auth_unix.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/authunix_prot.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/bindresvport.c
external/busybox/android/librpc/bindresvport.c: In function 'bindresvport':
external/busybox/android/librpc/bindresvport.c:71:7: warning: implicit declaration of function '__set_errno' [-Wimplicit-function-declaration]
target thumb C: libuclibcrpc <= external/busybox/android/librpc/clnt_generic.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/clnt_perror.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/clnt_raw.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/clnt_simple.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/clnt_tcp.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/clnt_udp.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/clnt_unix.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/create_xid.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/get_myaddress.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/getrpcent.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/getrpcport.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/pmap_clnt.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/pmap_prot2.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/pmap_prot.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/pmap_rmt.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/pm_getmaps.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/pm_getport.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/rpc_cmsg.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/rpc_commondata.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/rpc_dtablesize.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/rpc_prot.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/rpc_thread.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/svc_auth.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/svc_authux.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/svc.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/svc_raw.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/svc_run.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/svc_simple.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/svc_tcp.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/svc_udp.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/svc_unix.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/xdr_array.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/xdr.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/xdr_float.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/xdr_intXX_t.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/xdr_mem.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/xdr_rec.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/xdr_reference.c
target thumb C: libuclibcrpc <= external/busybox/android/librpc/xdr_stdio.c
dann noch libncurses zu default.xml hinzu und neu gesynct:
copy terminfo to /etc/
target asm: busybox <= external/busybox/android/libc/arch-arm/syscalls/adjtimex.S
target asm: busybox <= external/busybox/android/libc/arch-arm/syscalls/getsid.S
target asm: busybox <= external/busybox/android/libc/arch-arm/syscalls/stime.S
target asm: busybox <= external/busybox/android/libc/arch-arm/syscalls/swapon.S
target asm: busybox <= external/busybox/android/libc/arch-arm/syscalls/swapoff.S
target asm: busybox <= external/busybox/android/libc/arch-arm/syscalls/sysinfo.S
target thumb C: busybox <= external/busybox/archival/bbunzip.c
target thumb C: busybox <= external/busybox/archival/bzip2.c
target thumb C: busybox <= external/busybox/archival/cpio.c
target thumb C: busybox <= external/busybox/archival/gzip.c
target thumb C: busybox <= external/busybox/archival/libarchive/lzo1x_1.c
target thumb C: busybox <= external/busybox/archival/libarchive/lzo1x_1o.c
target thumb C: busybox <= external/busybox/archival/libarchive/lzo1x_d.c
target thumb C: busybox <= external/busybox/archival/lzop.c
target thumb C: busybox <= external/busybox/archival/tar.c
target thumb C: busybox <= external/busybox/archival/unzip.c
target thumb C: busybox <= external/busybox/archival/libarchive/data_align.c
target thumb C: busybox <= external/busybox/archival/libarchive/data_extract_all.c
target thumb C: busybox <= external/busybox/archival/libarchive/data_extract_to_command.c
target thumb C: busybox <= external/busybox/archival/libarchive/data_extract_to_stdout.c
target thumb C: busybox <= external/busybox/archival/libarchive/data_skip.c
target thumb C: busybox <= external/busybox/archival/libarchive/decompress_bunzip2.c
target thumb C: busybox <= external/busybox/archival/libarchive/decompress_unlzma.c
target thumb C: busybox <= external/busybox/archival/libarchive/decompress_unxz.c
target thumb C: busybox <= external/busybox/archival/libarchive/decompress_gunzip.c
target thumb C: busybox <= external/busybox/archival/libarchive/decompress_uncompress.c
target thumb C: busybox <= external/busybox/archival/libarchive/filter_accept_all.c
In file included from external/busybox/archival/libarchive/decompress_unxz.c:37:0:
external/busybox/archival/libarchive/unxz/xz_dec_lzma2.c:538:48: warning: always_inline function might not be inlinable [-Wattributes]
external/busybox/archival/libarchive/unxz/xz_dec_lzma2.c:522:52: warning: always_inline function might not be inlinable [-Wattributes]
external/busybox/archival/libarchive/unxz/xz_dec_lzma2.c:500:47: warning: always_inline function might not be inlinable [-Wattributes]
external/busybox/archival/libarchive/unxz/xz_dec_lzma2.c:481:48: warning: always_inline function might not be inlinable [-Wattributes]
external/busybox/archival/libarchive/unxz/xz_dec_lzma2.c:320:52: warning: always_inline function might not be inlinable [-Wattributes]
external/busybox/archival/libarchive/unxz/xz_dec_lzma2.c:309:49: warning: always_inline function might not be inlinable [-Wattributes]
target thumb C: busybox <= external/busybox/archival/libarchive/filter_accept_list.c
target thumb C: busybox <= external/busybox/archival/libarchive/filter_accept_reject_list.c
target thumb C: busybox <= external/busybox/archival/libarchive/find_list_entry.c
target thumb C: busybox <= external/busybox/archival/libarchive/get_header_cpio.c
target thumb C: busybox <= external/busybox/archival/libarchive/get_header_tar.c
target thumb C: busybox <= external/busybox/archival/libarchive/get_header_tar_bz2.c
target thumb C: busybox <= external/busybox/archival/libarchive/get_header_tar_gz.c
target thumb C: busybox <= external/busybox/archival/libarchive/get_header_tar_lzma.c
target thumb C: busybox <= external/busybox/archival/libarchive/header_list.c
target thumb C: busybox <= external/busybox/archival/libarchive/header_skip.c
target thumb C: busybox <= external/busybox/archival/libarchive/header_verbose_list.c
target thumb C: busybox <= external/busybox/archival/libarchive/init_handle.c
target thumb C: busybox <= external/busybox/archival/libarchive/open_transformer.c
target thumb C: busybox <= external/busybox/archival/libarchive/seek_by_jump.c
target thumb C: busybox <= external/busybox/archival/libarchive/seek_by_read.c
target thumb C: busybox <= external/busybox/console-tools/clear.c
target thumb C: busybox <= external/busybox/console-tools/reset.c
target thumb C: busybox <= external/busybox/console-tools/resize.c
target thumb C: busybox <= external/busybox/console-tools/setconsole.c
target thumb C: busybox <= external/busybox/coreutils/basename.c
target thumb C: busybox <= external/busybox/coreutils/cal.c
target thumb C: busybox <= external/busybox/coreutils/cat.c
target thumb C: busybox <= external/busybox/coreutils/catv.c
target thumb C: busybox <= external/busybox/coreutils/chgrp.c
target thumb C: busybox <= external/busybox/coreutils/chmod.c
target thumb C: busybox <= external/busybox/coreutils/chown.c
target thumb C: busybox <= external/busybox/coreutils/chroot.c
target thumb C: busybox <= external/busybox/coreutils/cp.c
target thumb C: busybox <= external/busybox/coreutils/cut.c
target thumb C: busybox <= external/busybox/coreutils/date.c
target thumb C: busybox <= external/busybox/coreutils/dd.c
target thumb C: busybox <= external/busybox/coreutils/df.c
target thumb C: busybox <= external/busybox/coreutils/dirname.c
target thumb C: busybox <= external/busybox/coreutils/dos2unix.c
target thumb C: busybox <= external/busybox/coreutils/du.c
target thumb C: busybox <= external/busybox/coreutils/echo.c
target thumb C: busybox <= external/busybox/coreutils/env.c
target thumb C: busybox <= external/busybox/coreutils/expr.c
target thumb C: busybox <= external/busybox/coreutils/false.c
target thumb C: busybox <= external/busybox/coreutils/fold.c
target thumb C: busybox <= external/busybox/coreutils/head.c
target thumb C: busybox <= external/busybox/coreutils/id.c
target thumb C: busybox <= external/busybox/coreutils/install.c
target thumb C: busybox <= external/busybox/coreutils/ln.c
target thumb C: busybox <= external/busybox/coreutils/ls.c
target thumb C: busybox <= external/busybox/coreutils/md5_sha1_sum.c
target thumb C: busybox <= external/busybox/coreutils/mkdir.c
target thumb C: busybox <= external/busybox/coreutils/mkfifo.c
target thumb C: busybox <= external/busybox/coreutils/mknod.c
target thumb C: busybox <= external/busybox/coreutils/mv.c
target thumb C: busybox <= external/busybox/coreutils/nice.c
target thumb C: busybox <= external/busybox/coreutils/nohup.c
target thumb C: busybox <= external/busybox/coreutils/od.c
target thumb C: busybox <= external/busybox/coreutils/printenv.c
target thumb C: busybox <= external/busybox/coreutils/printf.c
target thumb C: busybox <= external/busybox/coreutils/pwd.c
target thumb C: busybox <= external/busybox/coreutils/readlink.c
target thumb C: busybox <= external/busybox/coreutils/realpath.c
target thumb C: busybox <= external/busybox/coreutils/rm.c
target thumb C: busybox <= external/busybox/coreutils/rmdir.c
target thumb C: busybox <= external/busybox/coreutils/seq.c
target thumb C: busybox <= external/busybox/coreutils/sleep.c
target thumb C: busybox <= external/busybox/coreutils/sort.c
target thumb C: busybox <= external/busybox/coreutils/split.c
target thumb C: busybox <= external/busybox/coreutils/stat.c
target thumb C: busybox <= external/busybox/coreutils/stty.c
target thumb C: busybox <= external/busybox/coreutils/sync.c
target thumb C: busybox <= external/busybox/coreutils/tac.c
target thumb C: busybox <= external/busybox/coreutils/tail.c
target thumb C: busybox <= external/busybox/coreutils/tee.c
target thumb C: busybox <= external/busybox/coreutils/test.c
target thumb C: busybox <= external/busybox/coreutils/test_ptr_hack.c
target thumb C: busybox <= external/busybox/coreutils/touch.c
target thumb C: busybox <= external/busybox/coreutils/tr.c
target thumb C: busybox <= external/busybox/coreutils/true.c
target thumb C: busybox <= external/busybox/coreutils/uname.c
target thumb C: busybox <= external/busybox/coreutils/uniq.c
target thumb C: busybox <= external/busybox/coreutils/usleep.c
target thumb C: busybox <= external/busybox/coreutils/uudecode.c
target thumb C: busybox <= external/busybox/coreutils/uuencode.c
target thumb C: busybox <= external/busybox/coreutils/wc.c
target thumb C: busybox <= external/busybox/coreutils/whoami.c
target thumb C: busybox <= external/busybox/coreutils/yes.c
target thumb C: busybox <= external/busybox/coreutils/libcoreutils/cp_mv_stat.c
target thumb C: busybox <= external/busybox/coreutils/libcoreutils/getopt_mk_fifo_nod.c
target thumb C: busybox <= external/busybox/coreutils/comm.c
target thumb C: busybox <= external/busybox/coreutils/expand.c
target thumb C: busybox <= external/busybox/coreutils/sum.c
target thumb C: busybox <= external/busybox/coreutils/fsync.c
target thumb C: busybox <= external/busybox/debianutils/mktemp.c
target thumb C: busybox <= external/busybox/debianutils/run_parts.c
target thumb C: busybox <= external/busybox/debianutils/which.c
target thumb C: busybox <= external/busybox/debianutils/pipe_progress.c
external/busybox/debianutils/run_parts.c: In function 'run_parts_main':
external/busybox/debianutils/run_parts.c:159:48: warning: array subscript is above array bounds [-Warray-bounds]
target thumb C: busybox <= external/busybox/editors/awk.c
target thumb C: busybox <= external/busybox/editors/cmp.c
target thumb C: busybox <= external/busybox/editors/diff.c
target thumb C: busybox <= external/busybox/editors/ed.c
target thumb C: busybox <= external/busybox/editors/patch.c
target thumb C: busybox <= external/busybox/editors/sed.c
target thumb C: busybox <= external/busybox/editors/vi.c
external/busybox/editors/awk.c: In function 'evaluate':
external/busybox/editors/awk.c:2948:17: warning: 'L.v' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/busybox/editors/awk.c:2949:17: warning: 'R.v' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/busybox/editors/awk.c:2800:20: warning: 'L.s' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/busybox/editors/awk.c:2893:12: warning: 'R.s' may be used uninitialized in this function [-Wmaybe-uninitialized]
target thumb C: busybox <= external/busybox/e2fsprogs/e2fs_lib.c
target thumb C: busybox <= external/busybox/e2fsprogs/chattr.c
target thumb C: busybox <= external/busybox/e2fsprogs/lsattr.c
target thumb C: busybox <= external/busybox/e2fsprogs/tune2fs.c
target thumb C: busybox <= external/busybox/findutils/find.c
target thumb C: busybox <= external/busybox/findutils/grep.c
target thumb C: busybox <= external/busybox/findutils/xargs.c
target thumb C: busybox <= external/busybox/init/halt.c
target thumb C: busybox <= external/busybox/init/mesg.c
target thumb C: busybox <= external/busybox/libbb/appletlib.c
target thumb C: busybox <= external/busybox/libbb/ask_confirmation.c
target thumb C: busybox <= external/busybox/libbb/bb_askpass.c
target thumb C: busybox <= external/busybox/libbb/bb_do_delay.c
target thumb C: busybox <= external/busybox/libbb/bb_pwd.c
target thumb C: busybox <= external/busybox/libbb/bb_qsort.c
target thumb C: busybox <= external/busybox/libbb/bb_strtonum.c
target thumb C: busybox <= external/busybox/libbb/change_identity.c
target thumb C: busybox <= external/busybox/libbb/chomp.c
target thumb C: busybox <= external/busybox/libbb/compare_string_array.c
target thumb C: busybox <= external/busybox/libbb/concat_path_file.c
target thumb C: busybox <= external/busybox/libbb/concat_subpath_file.c
target thumb C: busybox <= external/busybox/libbb/copy_file.c
target thumb C: busybox <= external/busybox/libbb/copyfd.c
target thumb C: busybox <= external/busybox/libbb/crc32.c
target thumb C: busybox <= external/busybox/libbb/create_icmp6_socket.c
target thumb C: busybox <= external/busybox/libbb/create_icmp_socket.c
target thumb C: busybox <= external/busybox/libbb/percent_decode.c
target thumb C: busybox <= external/busybox/libbb/default_error_retval.c
target thumb C: busybox <= external/busybox/libbb/device_open.c
target thumb C: busybox <= external/busybox/libbb/dump.c
target thumb C: busybox <= external/busybox/libbb/execable.c
target thumb C: busybox <= external/busybox/libbb/fclose_nonstdin.c
target thumb C: busybox <= external/busybox/libbb/fflush_stdout_and_exit.c
target thumb C: busybox <= external/busybox/libbb/fgets_str.c
target thumb C: busybox <= external/busybox/libbb/find_mount_point.c
target thumb C: busybox <= external/busybox/libbb/find_pid_by_name.c
target thumb C: busybox <= external/busybox/libbb/find_root_device.c
target thumb C: busybox <= external/busybox/libbb/full_write.c
target thumb C: busybox <= external/busybox/libbb/get_console.c
target thumb C: busybox <= external/busybox/libbb/get_last_path_component.c
target thumb C: busybox <= external/busybox/libbb/get_line_from_file.c
target thumb C: busybox <= external/busybox/libbb/get_volsize.c
target thumb C: busybox <= external/busybox/libbb/getopt32.c
target thumb C: busybox <= external/busybox/libbb/getpty.c
target thumb C: busybox <= external/busybox/libbb/herror_msg.c
target thumb C: busybox <= external/busybox/libbb/human_readable.c
target thumb C: busybox <= external/busybox/libbb/inet_cksum.c
target thumb C: busybox <= external/busybox/libbb/inet_common.c
target thumb C: busybox <= external/busybox/libbb/info_msg.c
target thumb C: busybox <= external/busybox/libbb/inode_hash.c
target thumb C: busybox <= external/busybox/libbb/isdirectory.c
target thumb C: busybox <= external/busybox/libbb/kernel_version.c
target thumb C: busybox <= external/busybox/libbb/last_char_is.c
target thumb C: busybox <= external/busybox/libbb/lineedit.c
target thumb C: busybox <= external/busybox/libbb/lineedit_ptr_hack.c
target thumb C: busybox <= external/busybox/libbb/llist.c
target thumb C: busybox <= external/busybox/libbb/login.c
target thumb C: busybox <= external/busybox/libbb/loop.c
target thumb C: busybox <= external/busybox/libbb/make_directory.c
target thumb C: busybox <= external/busybox/libbb/makedev.c
target thumb C: busybox <= external/busybox/libbb/match_fstype.c
target thumb C: busybox <= external/busybox/libbb/hash_md5_sha.c
target thumb C: busybox <= external/busybox/libbb/bb_bswap_64.c
target thumb C: busybox <= external/busybox/libbb/messages.c
target thumb C: busybox <= external/busybox/libbb/mode_string.c
target thumb C: busybox <= external/busybox/libbb/mtab.c
target thumb C: busybox <= external/busybox/libbb/parse_config.c
target thumb C: busybox <= external/busybox/libbb/parse_mode.c
target thumb C: busybox <= external/busybox/libbb/perror_msg.c
target thumb C: busybox <= external/busybox/libbb/perror_nomsg.c
target thumb C: busybox <= external/busybox/libbb/perror_nomsg_and_die.c
target thumb C: busybox <= external/busybox/libbb/pidfile.c
target thumb C: busybox <= external/busybox/libbb/platform.c
target thumb C: busybox <= external/busybox/libbb/print_flags.c
target thumb C: busybox <= external/busybox/libbb/printable.c
target thumb C: busybox <= external/busybox/libbb/printable_string.c
target thumb C: busybox <= external/busybox/libbb/process_escape_sequence.c
target thumb C: busybox <= external/busybox/libbb/procps.c
target thumb C: busybox <= external/busybox/libbb/progress.c
target thumb C: busybox <= external/busybox/libbb/ptr_to_globals.c
target thumb C: busybox <= external/busybox/libbb/read.c
target thumb C: busybox <= external/busybox/libbb/read_key.c
target thumb C: busybox <= external/busybox/libbb/read_printf.c
target thumb C: busybox <= external/busybox/libbb/recursive_action.c
target thumb C: busybox <= external/busybox/libbb/remove_file.c
target thumb C: busybox <= external/busybox/libbb/run_shell.c
target thumb C: busybox <= external/busybox/libbb/safe_gethostname.c
target thumb C: busybox <= external/busybox/libbb/safe_poll.c
target thumb C: busybox <= external/busybox/libbb/safe_strncpy.c
target thumb C: busybox <= external/busybox/libbb/safe_write.c
target thumb C: busybox <= external/busybox/libbb/setup_environment.c
target thumb C: busybox <= external/busybox/libbb/signals.c
target thumb C: busybox <= external/busybox/libbb/simplify_path.c
target thumb C: busybox <= external/busybox/libbb/single_argv.c
target thumb C: busybox <= external/busybox/libbb/skip_whitespace.c
target thumb C: busybox <= external/busybox/libbb/speed_table.c
target thumb C: busybox <= external/busybox/libbb/str_tolower.c
target thumb C: busybox <= external/busybox/libbb/strrstr.c
target thumb C: busybox <= external/busybox/libbb/time.c
target thumb C: busybox <= external/busybox/libbb/trim.c
target thumb C: busybox <= external/busybox/libbb/u_signal_names.c
target thumb C: busybox <= external/busybox/libbb/udp_io.c
target thumb C: busybox <= external/busybox/libbb/unicode.c
target thumb C: busybox <= external/busybox/libbb/uuencode.c
target thumb C: busybox <= external/busybox/libbb/vdprintf.c
target thumb C: busybox <= external/busybox/libbb/verror_msg.c
target thumb C: busybox <= external/busybox/libbb/vfork_daemon_rexec.c
target thumb C: busybox <= external/busybox/libbb/warn_ignoring_args.c
target thumb C: busybox <= external/busybox/libbb/wfopen.c
target thumb C: busybox <= external/busybox/libbb/wfopen_input.c
target thumb C: busybox <= external/busybox/libbb/write.c
target thumb C: busybox <= external/busybox/libbb/xatonum.c
target thumb C: busybox <= external/busybox/libbb/xconnect.c
target thumb C: busybox <= external/busybox/libbb/xfunc_die.c
target thumb C: busybox <= external/busybox/libbb/xfuncs.c
target thumb C: busybox <= external/busybox/libbb/xfuncs_printf.c
target thumb C: busybox <= external/busybox/libbb/xgetcwd.c
target thumb C: busybox <= external/busybox/libbb/xgethostbyname.c
target thumb C: busybox <= external/busybox/libbb/xreadlink.c
target thumb C: busybox <= external/busybox/libbb/xrealloc_vector.c
target thumb C: busybox <= external/busybox/libbb/xregcomp.c
target thumb C: busybox <= external/busybox/libbb/get_cpu_count.c
target thumb C: busybox <= external/busybox/libbb/get_shell_name.c
target thumb C: busybox <= external/busybox/libpwdgrp/uidgid_get.c
target thumb C: busybox <= external/busybox/miscutils/adjtimex.c
target thumb C: busybox <= external/busybox/miscutils/bbconfig.c
target thumb C: busybox <= external/busybox/miscutils/crond.c
target thumb C: busybox <= external/busybox/miscutils/crontab.c
target thumb C: busybox <= external/busybox/miscutils/dc.c
target thumb C: busybox <= external/busybox/miscutils/devmem.c
target thumb C: busybox <= external/busybox/miscutils/less.c
target thumb C: busybox <= external/busybox/miscutils/man.c
target thumb C: busybox <= external/busybox/miscutils/fbsplash.c
target thumb C: busybox <= external/busybox/miscutils/flash_lock_unlock.c
target thumb C: busybox <= external/busybox/miscutils/flashcp.c
target thumb C: busybox <= external/busybox/miscutils/mountpoint.c
target thumb C: busybox <= external/busybox/miscutils/nandwrite.c
target thumb C: busybox <= external/busybox/miscutils/rx.c
external/busybox/miscutils/less.c: In function 'read_lines':
external/busybox/miscutils/less.c:505:39: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/busybox/miscutils/less.c: In function 'getch_nowait':
external/busybox/miscutils/less.c:929:40: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
target thumb C: busybox <= external/busybox/miscutils/setserial.c
target thumb C: busybox <= external/busybox/miscutils/setsid.c
target thumb C: busybox <= external/busybox/miscutils/strings.c
target thumb C: busybox <= external/busybox/miscutils/taskset.c
target thumb C: busybox <= external/busybox/miscutils/time.c
target thumb C: busybox <= external/busybox/miscutils/timeout.c
target thumb C: busybox <= external/busybox/miscutils/ttysize.c
target thumb C: busybox <= external/busybox/miscutils/ionice.c
target thumb C: busybox <= external/busybox/modutils/modinfo.c
target thumb C: busybox <= external/busybox/modutils/modprobe-small.c
target thumb C: busybox <= external/busybox/modutils/modutils.c
target thumb C: busybox <= external/busybox/modutils/lsmod.c
target thumb C: busybox <= external/busybox/modutils/depmod.c
target thumb C: busybox <= external/busybox/modutils/rmmod.c
target thumb C: busybox <= external/busybox/modutils/insmod.c
target thumb C: busybox <= external/busybox/networking/arp.c
target thumb C: busybox <= external/busybox/networking/brctl.c
target thumb C: busybox <= external/busybox/networking/dnsd.c
target thumb C: busybox <= external/busybox/networking/ifconfig.c
target thumb C: busybox <= external/busybox/networking/inetd.c
target thumb C: busybox <= external/busybox/networking/interface.c
target thumb C: busybox <= external/busybox/networking/ip.c
target thumb C: busybox <= external/busybox/networking/nc.c
target thumb C: busybox <= external/busybox/networking/netstat.c
target thumb C: busybox <= external/busybox/networking/ntpd.c
target thumb C: busybox <= external/busybox/networking/ping.c
target thumb C: busybox <= external/busybox/networking/route.c
target thumb C: busybox <= external/busybox/networking/telnet.c
target thumb C: busybox <= external/busybox/networking/telnetd.c
target thumb C: busybox <= external/busybox/networking/tftp.c
target thumb C: busybox <= external/busybox/networking/traceroute.c
target thumb C: busybox <= external/busybox/networking/wget.c
target thumb C: busybox <= external/busybox/networking/libiproute/ip_parse_common_args.c
target thumb C: busybox <= external/busybox/networking/libiproute/ipaddress.c
target thumb C: busybox <= external/busybox/networking/libiproute/iplink.c
target thumb C: busybox <= external/busybox/networking/libiproute/iproute.c
target thumb C: busybox <= external/busybox/networking/libiproute/iprule.c
target thumb C: busybox <= external/busybox/networking/libiproute/libnetlink.c
external/busybox/networking/libiproute/libnetlink.c: In function 'rtnl_dump_filter':
external/busybox/networking/libiproute/libnetlink.c:132:115: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
target thumb C: busybox <= external/busybox/networking/libiproute/ll_addr.c
target thumb C: busybox <= external/busybox/networking/libiproute/ll_map.c
target thumb C: busybox <= external/busybox/networking/libiproute/ll_proto.c
target thumb C: busybox <= external/busybox/networking/libiproute/ll_types.c
target thumb C: busybox <= external/busybox/networking/libiproute/rt_names.c
target thumb C: busybox <= external/busybox/networking/libiproute/rtm_map.c
target thumb C: busybox <= external/busybox/networking/libiproute/utils.c
target thumb C: busybox <= external/busybox/networking/nbd-client.c
target thumb C: busybox <= external/busybox/networking/ifupdown.c
target thumb C: busybox <= external/busybox/networking/ftpgetput.c
target thumb C: busybox <= external/busybox/networking/nslookup.c
target thumb C: busybox <= external/busybox/procps/free.c
target thumb C: busybox <= external/busybox/procps/fuser.c
target thumb C: busybox <= external/busybox/procps/kill.c
target thumb C: busybox <= external/busybox/procps/pgrep.c
target thumb C: busybox <= external/busybox/procps/pidof.c
target thumb C: busybox <= external/busybox/procps/ps.c
target thumb C: busybox <= external/busybox/procps/renice.c
target thumb C: busybox <= external/busybox/procps/sysctl.c
target thumb C: busybox <= external/busybox/procps/top.c
target thumb C: busybox <= external/busybox/procps/uptime.c
target thumb C: busybox <= external/busybox/procps/watch.c
target thumb C: busybox <= external/busybox/procps/pmap.c
target thumb C: busybox <= external/busybox/procps/iostat.c
target thumb C: busybox <= external/busybox/procps/mpstat.c
target thumb C: busybox <= external/busybox/procps/lsof.c
target thumb C: busybox <= external/busybox/procps/pstree.c
target thumb C: busybox <= external/busybox/procps/pwdx.c
target thumb C: busybox <= external/busybox/shell/ash.c
target thumb C: busybox <= external/busybox/shell/ash_ptr_hack.c
target thumb C: busybox <= external/busybox/shell/math.c
target thumb C: busybox <= external/busybox/shell/random.c
target thumb C: busybox <= external/busybox/shell/shell_common.c
target thumb C: busybox <= external/busybox/util-linux/blkid.c
target thumb C: busybox <= external/busybox/util-linux/blockdev.c
target thumb C: busybox <= external/busybox/util-linux/dmesg.c
target thumb C: busybox <= external/busybox/util-linux/fdisk.c
target thumb C: busybox <= external/busybox/util-linux/flock.c
target thumb C: busybox <= external/busybox/util-linux/freeramdisk.c
target thumb C: busybox <= external/busybox/util-linux/fstrim.c
target thumb C: busybox <= external/busybox/util-linux/getopt.c
target thumb C: busybox <= external/busybox/util-linux/hexdump.c
target thumb C: busybox <= external/busybox/util-linux/losetup.c
target thumb C: busybox <= external/busybox/util-linux/lspci.c
target thumb C: busybox <= external/busybox/util-linux/lsusb.c
target thumb C: busybox <= external/busybox/util-linux/mkfs_ext2.c
target thumb C: busybox <= external/busybox/util-linux/mkfs_vfat.c
target thumb C: busybox <= external/busybox/util-linux/mkswap.c
target thumb C: busybox <= external/busybox/util-linux/more.c
target thumb C: busybox <= external/busybox/util-linux/mount.c
target thumb C: busybox <= external/busybox/util-linux/rdev.c
target thumb C: busybox <= external/busybox/util-linux/rev.c
target thumb C: busybox <= external/busybox/util-linux/swaponoff.c
target thumb C: busybox <= external/busybox/util-linux/umount.c
target thumb C: busybox <= external/busybox/util-linux/volume_id/get_devname.c
target thumb C: busybox <= external/busybox/util-linux/volume_id/volume_id.c
external/busybox/util-linux/volume_id/get_devname.c: In function 'add_to_uuid_cache':
external/busybox/util-linux/volume_id/get_devname.c:244:8: warning: 'uuid' is used uninitialized in this function [-Wuninitialized]
target thumb C: busybox <= external/busybox/util-linux/volume_id/util.c
target thumb C: busybox <= external/busybox/util-linux/volume_id/ext.c
target thumb C: busybox <= external/busybox/util-linux/volume_id/fat.c
target thumb C: busybox <= external/busybox/util-linux/volume_id/iso9660.c
external/busybox/shell/ash.c: In function 'evaltree':
external/busybox/shell/ash.c:8363:22: warning: argument 'n' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
external/busybox/shell/ash.c: In function 'readtoken1':
external/busybox/shell/ash.c:11126:11: warning: variable 'quotef' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
external/busybox/shell/ash.c:11127:11: warning: variable 'dblquote' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
external/busybox/shell/ash.c:11128:11: warning: variable 'oldstyle' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
external/busybox/shell/ash.c:11129:11: warning: variable 'prevsyntax' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
external/busybox/shell/ash.c:11133:6: warning: variable 'varnest' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
external/busybox/shell/ash.c:11134:6: warning: variable 'arinest' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
external/busybox/shell/ash.c:11135:6: warning: variable 'parenlevel' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
external/busybox/shell/ash.c:11136:6: warning: variable 'dqvarnest' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
external/busybox/shell/ash.c:11138:11: warning: variable 'bash_dollar_squote' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
external/busybox/shell/ash.c:11118:23: warning: argument 'syntax' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
external/busybox/shell/ash.c: In function 'exitshell':
external/busybox/shell/ash.c:12949:6: warning: variable 'status' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
target thumb C: busybox <= external/busybox/util-linux/volume_id/ntfs.c
target thumb C: busybox <= external/busybox/util-linux/volume_id/linux_swap.c
target thumb C: busybox <= external/busybox/util-linux/volume_id/exfat.c
target thumb C: busybox <= external/busybox/util-linux/volume_id/squashfs.c
target thumb C: busybox <= external/busybox/libbb/android.c
target thumb C: busybox <= external/busybox/android/libc/__set_errno.c
target StaticLib: libclearsilverregex (out/target/product/mako/obj/STATIC_LIBRARIES/libclearsilverregex_intermediates/libclearsilverregex.a)
Export includes file: external/libncurses/Android.mk -- out/target/product/mako/obj/SHARED_LIBRARIES/libncurses_intermediates/export_includes
Import includes file: out/target/product/mako/obj/SHARED_LIBRARIES/libncurses_intermediates/import_includes
target StaticLib: libuclibcrpc (out/target/product/mako/obj/STATIC_LIBRARIES/libuclibcrpc_intermediates/libuclibcrpc.a)
Export includes file: external/nano/Android.mk -- out/target/product/mako/obj/EXECUTABLES/nano_intermediates/export_includes
Export includes file: external/bash/builtins/Android.mk -- out/target/product/mako/obj/STATIC_LIBRARIES/libbuiltins_intermediates/export_includes
Export includes file: external/bash/lib/glob/Android.mk -- out/target/product/mako/obj/STATIC_LIBRARIES/libglob_intermediates/export_includes
Export includes file: external/bash/lib/sh/Android.mk -- out/target/product/mako/obj/STATIC_LIBRARIES/libsh_intermediates/export_includes
Export includes file: external/bash/lib/tilde/Android.mk -- out/target/product/mako/obj/STATIC_LIBRARIES/libtilde_intermediates/export_includes
Export includes file: external/bash/lib/readline/Android.mk -- out/target/product/mako/obj/STATIC_LIBRARIES/libreadline_intermediates/export_includes
Export includes file: external/bash/lib/readline/Android.mk -- out/target/product/mako/obj/STATIC_LIBRARIES/libhistory_intermediates/export_includes
Import includes file: out/target/product/mako/obj/STATIC_LIBRARIES/libbuiltins_intermediates/import_includes
Import includes file: out/target/product/mako/obj/STATIC_LIBRARIES/libglob_intermediates/import_includes
Import includes file: out/target/product/mako/obj/STATIC_LIBRARIES/libsh_intermediates/import_includes
Import includes file: out/target/product/mako/obj/STATIC_LIBRARIES/libtilde_intermediates/import_includes
Import includes file: out/target/product/mako/obj/STATIC_LIBRARIES/libreadline_intermediates/import_includes
Import includes file: out/target/product/mako/obj/STATIC_LIBRARIES/libhistory_intermediates/import_includes
Export includes file: external/bash/Android.mk -- out/target/product/mako/obj/EXECUTABLES/bash_intermediates/export_includes
----- Making recovery image ------
target Executable: busybox (out/target/product/mako/obj/EXECUTABLES/busybox_intermediates/LINKED/busybox)
Import includes file: out/target/product/mako/obj/EXECUTABLES/nano_intermediates/import_includes
target thumb C: libncurses <= external/libncurses/ncurses/base/define_key.c
Copying baseline ramdisk...
target thumb C: libncurses <= external/libncurses/ncurses/base/key_defined.c
target thumb C: libncurses <= external/libncurses/ncurses/base/keybound.c
target thumb C: libncurses <= external/libncurses/ncurses/base/keyok.c
target thumb C: libncurses <= external/libncurses/ncurses/base/legacy_coding.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_addch.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_addstr.c
Modifying ramdisk contents...
cp: cannot stat ‘out/target/product/mako/root/init.recovery.*.rc’: No such file or directory
make: [out/target/product/mako/recovery.img] Error 1 (ignored)
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_beep.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_bkgd.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_box.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_chgat.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_clear.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_clearok.c
external/busybox/debianutils/mktemp.c:96: warning: warning: mktemp() possibly used unsafely; consider using mkstemp()
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_clrbot.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_clreol.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_color.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_colorset.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_delch.c
out/target/product/mako/recovery.img maxsize=23519232 blocksize=135168 total=7077888 reserve=270336
----- Made recovery image: out/target/product/mako/recovery.img --------
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_delwin.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_dft_fgbg.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_echo.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_endwin.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_erase.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_flash.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_freeall.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_getch.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_getstr.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_hline.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_immedok.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_inchstr.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_initscr.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_insch.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_insdel.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_insnstr.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_instr.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_isendwin.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_leaveok.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_mouse.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_move.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_mvwin.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_newterm.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_newwin.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_nl.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_overlay.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_pad.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_printw.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_redrawln.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_refresh.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_restart.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_scanw.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_screen.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_scroll.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_scrollok.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_scrreg.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_set_term.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_slk.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_slkatr_set.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_slkatrof.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_slkatron.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_slkatrset.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_slkattr.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_slkclear.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_slkcolor.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_slkinit.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_slklab.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_slkrefr.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_slkset.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_slktouch.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_touch.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_ungetch.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_vline.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_wattroff.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_wattron.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_winch.c
target thumb C: libncurses <= external/libncurses/ncurses/base/lib_window.c
target thumb C: libncurses <= external/libncurses/ncurses/base/memmove.c
target thumb C: libncurses <= external/libncurses/ncurses/base/nc_panel.c
target thumb C: libncurses <= external/libncurses/ncurses/base/resizeterm.c
target thumb C: libncurses <= external/libncurses/ncurses/base/safe_sprintf.c
target thumb C: libncurses <= external/libncurses/ncurses/base/tries.c
target thumb C: libncurses <= external/libncurses/ncurses/base/use_window.c
target thumb C: libncurses <= external/libncurses/ncurses/base/version.c
target thumb C: libncurses <= external/libncurses/ncurses/base/vsscanf.c
target thumb C: libncurses <= external/libncurses/ncurses/base/wresize.c
target thumb C: libncurses <= external/libncurses/ncurses/codes.c
target thumb C: libncurses <= external/libncurses/ncurses/comp_captab.c
target thumb C: libncurses <= external/libncurses/ncurses/expanded.c
target thumb C: libncurses <= external/libncurses/ncurses/fallback.c
target thumb C: libncurses <= external/libncurses/ncurses/lib_gen.c
target thumb C: libncurses <= external/libncurses/ncurses/lib_keyname.c
target thumb C: libncurses <= external/libncurses/ncurses/names.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/access.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/add_tries.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/alloc_entry.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/alloc_ttype.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/captoinfo.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/comp_error.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/comp_expand.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/comp_hash.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/comp_parse.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/comp_scan.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/db_iterator.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/doalloc.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/entries.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/free_ttype.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/getenv_num.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/hashed_db.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/home_terminfo.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/init_keytry.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/lib_acs.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/lib_baudrate.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/lib_cur_term.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/lib_data.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/lib_has_cap.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/lib_kernel.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/lib_longname.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/lib_napms.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/lib_options.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/lib_print.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/lib_raw.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/lib_setup.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/lib_termcap.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/lib_termname.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/lib_tgoto.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/lib_ti.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/lib_tparm.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/lib_tputs.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/lib_ttyflags.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/name_match.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/parse_entry.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/read_entry.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/read_termcap.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/setbuf.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/strings.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/trim_sgr0.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/use_screen.c
target thumb C: libncurses <= external/libncurses/ncurses/tinfo/write_entry.c
target thumb C: libncurses <= external/libncurses/ncurses/trace/lib_trace.c
target thumb C: libncurses <= external/libncurses/ncurses/trace/varargs.c
target thumb C: libncurses <= external/libncurses/ncurses/trace/visbuf.c
target thumb C: libncurses <= external/libncurses/ncurses/tty/hardscroll.c
external/libncurses/ncurses/tinfo/write_entry.c: In function '_nc_write_entry':
external/libncurses/ncurses/tinfo/write_entry.c:372:22: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/libncurses/ncurses/tinfo/write_entry.c:410:23: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
target thumb C: libncurses <= external/libncurses/ncurses/tty/hashmap.c
target thumb C: libncurses <= external/libncurses/ncurses/tty/lib_mvcur.c
target thumb C: libncurses <= external/libncurses/ncurses/tty/lib_tstp.c
target thumb C: libncurses <= external/libncurses/ncurses/tty/lib_twait.c
target thumb C: libncurses <= external/libncurses/ncurses/tty/lib_vidattr.c
target thumb C: libncurses <= external/libncurses/ncurses/tty/tty_update.c
target thumb C: libncurses <= external/libncurses/ncurses/unctrl.c
Import includes file: out/target/product/mako/obj/EXECUTABLES/bash_intermediates/import_includes
target thumb C: libbuiltins <= external/bash/builtins/alias.c
target thumb C: libbuiltins <= external/bash/builtins/bashgetopt.c
target thumb C: libbuiltins <= external/bash/builtins/bind.c
target thumb C: libbuiltins <= external/bash/builtins/break.c
./break.def: In function 'break_builtin':
./break.def:77:7: warning: passing argument 2 of 'sh_erange' discards 'const' qualifier from pointer target type [enabled by default]
In file included from ./break.def:46:0:
external/bash/builtins/common.h:76:13: note: expected 'char *' but argument is of type 'const char *'
./break.def: In function 'continue_builtin':
./break.def:117:7: warning: passing argument 2 of 'sh_erange' discards 'const' qualifier from pointer target type [enabled by default]
target thumb C: libbuiltins <= external/bash/builtins/builtin.c
./bind.def: In function 'bind_builtin':
./bind.def:266:17: warning: 'cmd_seq' may be used uninitialized in this function [-Wmaybe-uninitialized]
target thumb C: libbuiltins <= external/bash/builtins/builtins.c
target thumb C: libbuiltins <= external/bash/builtins/caller.c
target thumb C: libbuiltins <= external/bash/builtins/cd.c
external/bash/builtins/builtins.c:247:3: warning: missing initializer [-Wmissing-field-initializers]
external/bash/builtins/builtins.c:247:3: warning: (near initialization for 'static_shell_builtins[74].handle') [-Wmissing-field-initializers]
target thumb C: libbuiltins <= external/bash/builtins/colon.c
target thumb C: libbuiltins <= external/bash/builtins/command.c
target thumb C: libbuiltins <= external/bash/builtins/common.c
./cd.def: In function 'cd_builtin':
./cd.def:244:7: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: libbuiltins <= external/bash/builtins/complete.c
target thumb C: libbuiltins <= external/bash/builtins/declare.c
target thumb C: libbuiltins <= external/bash/builtins/echo.c
./complete.def:132:1: warning: 'static' is not at beginning of declaration [-Wold-style-declaration]
target thumb C: libbuiltins <= external/bash/builtins/enable.c
./declare.def: In function 'declare_internal':
./declare.def:296:7: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: libbuiltins <= external/bash/builtins/eval.c
./echo.def: In function 'echo_builtin':
./echo.def:137:7: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: libbuiltins <= external/bash/builtins/evalfile.c
target thumb C: libbuiltins <= external/bash/builtins/evalstring.c
target thumb C: libbuiltins <= external/bash/builtins/exec.c
external/bash/builtins/evalfile.c: In function '_evalfile':
external/bash/builtins/evalfile.c:93:23: warning: variable 'bash_source_a' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
external/bash/builtins/evalfile.c:93:39: warning: variable 'bash_lineno_a' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
target thumb C: libbuiltins <= external/bash/builtins/exit.c
target thumb C: libbuiltins <= external/bash/builtins/fc.c
external/bash/builtins/evalstring.c: In function 'parse_and_execute':
external/bash/builtins/evalstring.c:260:4: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: libbuiltins <= external/bash/builtins/fg_bg.c
target thumb C: libbuiltins <= external/bash/builtins/getopt.c
./fg_bg.def: In function 'fg_bg':
./fg_bg.def:149:2: warning: passing argument 1 of 'sh_badjob' discards 'const' qualifier from pointer target type [enabled by default]
In file included from ./fg_bg.def:50:0:
external/bash/builtins/common.h:78:13: note: expected 'char *' but argument is of type 'const char *'
target thumb C: libbuiltins <= external/bash/builtins/getopts.c
external/bash/builtins/getopt.c: In function 'sh_getopt':
external/bash/builtins/getopt.c:182:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: libbuiltins <= external/bash/builtins/hash.c
./fc.def: In function 'fc_builtin':
./fc.def:349:7: warning: passing argument 2 of 'sh_erange' discards 'const' qualifier from pointer target type [enabled by default]
In file included from ./fc.def:82:0:
target thumb C: libbuiltins <= external/bash/builtins/help.c
target thumb C: libbuiltins <= external/bash/builtins/history.c
target thumb C: libbuiltins <= external/bash/builtins/jobs.c
target thumb C: libbuiltins <= external/bash/builtins/kill.c
./kill.def: In function 'kill_error':
./kill.def:263:7: warning: assignment discards 'const' qualifier from pointer target type [enabled by default]
target thumb C: libbuiltins <= external/bash/builtins/let.c
./jobs.def: In function 'disown_builtin':
./jobs.def:282:4: warning: passing argument 1 of 'sh_badjob' discards 'const' qualifier from pointer target type [enabled by default]
In file included from ./jobs.def:65:0:
target thumb C: libbuiltins <= external/bash/builtins/mapfile.c
./history.def: In function 'history_builtin':
./history.def:186:4: warning: passing argument 2 of 'sh_erange' discards 'const' qualifier from pointer target type [enabled by default]
In file included from ./history.def:80:0:
./history.def:186:14: warning: 'delete_arg' may be used uninitialized in this function [-Wmaybe-uninitialized]
target thumb C: libbuiltins <= external/bash/builtins/printf.c
target thumb C: libbuiltins <= external/bash/builtins/pushd.c
./mapfile.def: In function 'mapfile':
./mapfile.def:181:35: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
./mapfile.def:195:46: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
target thumb C: libbuiltins <= external/bash/builtins/read.c
./pushd.def: In function 'pushd_error':
./pushd.def:508:5: warning: passing argument 2 of 'sh_erange' discards 'const' qualifier from pointer target type [enabled by default]
In file included from ./pushd.def:138:0:
target thumb C: libbuiltins <= external/bash/builtins/return.c
target thumb C: libbuiltins <= external/bash/builtins/setattr.c
./read.def: In function 'read_builtin':
./read.def:160:21: warning: variable 'input_is_pipe' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
./read.def:160:53: warning: variable 'skip_ctlesc' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
./read.def:160:66: warning: variable 'skip_ctlnul' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
./read.def:161:7: warning: variable 'raw' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
./read.def:161:12: warning: variable 'edit' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
./read.def:161:18: warning: variable 'nchars' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
./read.def:161:62: warning: variable 'fd' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
./read.def:166:44: warning: variable 'ifs_chars' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
./read.def:166:65: warning: variable 'arrayname' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
./read.def:176:17: warning: variable 'itext' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
target thumb C: libbuiltins <= external/bash/builtins/set.c
./setattr.def: In function 'set_or_show_attributes':
./setattr.def:290:4: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
./setattr.def:301:5: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
./setattr.def: In function 'show_all_var_attributes':
./setattr.def:328:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
./setattr.def:331:7: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: libbuiltins <= external/bash/builtins/shift.c
./set.def: In function 'parse_shellopts':
./set.def:540:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
./set.def: In function 'set_builtin':
./set.def:649:4: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: libbuiltins <= external/bash/builtins/shopt.c
target thumb C: libbuiltins <= external/bash/builtins/source.c
./shift.def: In function 'shift_builtin':
./shift.def:71:7: warning: passing argument 2 of 'sh_erange' discards 'const' qualifier from pointer target type [enabled by default]
In file included from ./shift.def:36:0:
./shift.def:77:2: warning: passing argument 2 of 'sh_erange' discards 'const' qualifier from pointer target type [enabled by default]
target thumb C: libbuiltins <= external/bash/builtins/suspend.c
target thumb C: libbuiltins <= external/bash/builtins/test.c
./suspend.def: In function 'suspend_builtin':
./suspend.def:101:7: warning: passing argument 1 of 'sh_nojobs' discards 'const' qualifier from pointer target type [enabled by default]
In file included from ./suspend.def:54:0:
external/bash/builtins/common.h:80:13: note: expected 'char *' but argument is of type 'const char *'
target thumb C: libbuiltins <= external/bash/builtins/times.c
./shopt.def: In function 'parse_bashopts':
./shopt.def:682:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: libbuiltins <= external/bash/builtins/trap.c
target thumb C: libbuiltins <= external/bash/builtins/type.c
target thumb C: libbuiltins <= external/bash/builtins/ulimit.c
target thumb C: libbuiltins <= external/bash/builtins/umask.c
./type.def: In function 'describe_command':
./type.def:332:7: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: libbuiltins <= external/bash/builtins/wait.c
./ulimit.def: In function 'ulimit_internal':
./ulimit.def:453:4: warning: passing argument 2 of 'sh_erange' discards 'const' qualifier from pointer target type [enabled by default]
In file included from ./ulimit.def:87:0:
target thumb C: libglob <= external/bash/lib/glob/glob.c
target thumb C: libglob <= external/bash/lib/glob/smatch.c
./umask.def: In function 'umask_builtin':
./umask.def:118:8: warning: passing argument 2 of 'sh_erange' discards 'const' qualifier from pointer target type [enabled by default]
In file included from ./umask.def:61:0:
target thumb C: libglob <= external/bash/lib/glob/strmatch.c
target thumb C: libglob <= external/bash/lib/glob/xmbsrtowcs.c
external/bash/lib/glob/glob.c: In function 'glob_vector':
external/bash/lib/glob/glob.c:604:11: warning: 'isdir' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/bash/lib/glob/glob.c:432:26: note: 'isdir' was declared here
external/bash/lib/glob/glob.c:609:14: warning: 'subdir' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/bash/lib/glob/glob.c:430:36: note: 'subdir' was declared here
target thumb C: libglob <= external/bash/lib/glob/gmisc.c
target thumb C: libsh <= external/bash/lib/sh/clktck.c
target thumb C: libsh <= external/bash/lib/sh/clock.c
external/bash/lib/glob/gmisc.c: In function 'wmatchlen':
external/bash/lib/glob/gmisc.c:87:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/lib/glob/gmisc.c: In function 'umatchlen':
external/bash/lib/glob/gmisc.c:223:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: libsh <= external/bash/lib/sh/getenv.c
target thumb C: libsh <= external/bash/lib/sh/oslib.c
target thumb C: libsh <= external/bash/lib/sh/setlinebuf.c
target thumb C: libsh <= external/bash/lib/sh/strnlen.c
target thumb C: libsh <= external/bash/lib/sh/itos.c
target thumb C: libsh <= external/bash/lib/sh/zread.c
external/bash/lib/glob/smatch.c: In function 'is_cclass':
external/bash/lib/glob/smatch.c:142:17: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
In file included from external/bash/lib/glob/smatch.c:228:0:
external/bash/lib/glob/sm_loop.c: In function 'brackmatch':
external/bash/lib/glob/sm_loop.c:305:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/lib/glob/sm_loop.c: In function 'patscan':
external/bash/lib/glob/sm_loop.c:533:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/lib/glob/sm_loop.c: In function 'extmatch':
external/bash/lib/glob/sm_loop.c:731:8: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
In file included from external/bash/lib/glob/smatch.c:356:0:
external/bash/lib/glob/sm_loop.c: In function 'brackmatch_wc':
external/bash/lib/glob/sm_loop.c:363:15: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/lib/glob/sm_loop.c: In function 'patscan_wc':
external/bash/lib/glob/sm_loop.c: In function 'extmatch_wc':
target thumb C: libsh <= external/bash/lib/sh/zwrite.c
target thumb C: libsh <= external/bash/lib/sh/shtty.c
target thumb C: libsh <= external/bash/lib/sh/shmatch.c
target thumb C: libsh <= external/bash/lib/sh/eaccess.c
external/bash/lib/sh/shmatch.c: In function 'sh_regmatch':
external/bash/lib/sh/shmatch.c:100:39: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
target thumb C: libsh <= external/bash/lib/sh/netconn.c
target thumb C: libsh <= external/bash/lib/sh/netopen.c
target thumb C: libsh <= external/bash/lib/sh/timeval.c
target thumb C: libsh <= external/bash/lib/sh/makepath.c
external/bash/lib/sh/netopen.c: In function 'netopen':
external/bash/lib/sh/netopen.c:216:7: warning: 's' may be used uninitialized in this function [-Wmaybe-uninitialized]
target thumb C: libsh <= external/bash/lib/sh/pathcanon.c
target thumb C: libsh <= external/bash/lib/sh/pathphys.c
external/bash/lib/sh/makepath.c: In function 'sh_makepath':
external/bash/lib/sh/makepath.c:97:12: warning: suggest parentheses around '&&' within '||' [-Wparentheses]
external/bash/lib/sh/makepath.c:123:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: libsh <= external/bash/lib/sh/tmpfile.c
external/bash/lib/sh/pathcanon.c: In function 'sh_canonpath':
external/bash/lib/sh/pathcanon.c:117:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: libsh <= external/bash/lib/sh/stringlist.c
target thumb C: libsh <= external/bash/lib/sh/stringvec.c
target thumb C: libsh <= external/bash/lib/sh/spell.c
target thumb C: libsh <= external/bash/lib/sh/shquote.c
external/bash/lib/sh/spell.c: In function 'spname':
external/bash/lib/sh/spell.c:98:7: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: libsh <= external/bash/lib/sh/strtrans.c
target thumb C: libsh <= external/bash/lib/sh/snprintf.c
target thumb C: libsh <= external/bash/lib/sh/mailstat.c
target thumb C: libsh <= external/bash/lib/sh/fmtulong.c
external/bash/lib/sh/strtrans.c: In function 'ansic_shouldquote':
external/bash/lib/sh/strtrans.c:280:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: libsh <= external/bash/lib/sh/fmtullong.c
external/bash/lib/sh/mailstat.c: In function 'mailstat':
external/bash/lib/sh/mailstat.c:144:62: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/lib/sh/mailstat.c:146:24: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
target thumb C: libsh <= external/bash/lib/sh/fmtumax.c
target thumb C: libsh <= external/bash/lib/sh/zcatfd.c
target thumb C: libsh <= external/bash/lib/sh/zmapfd.c
target thumb C: libsh <= external/bash/lib/sh/winsize.c
target thumb C: libsh <= external/bash/lib/sh/wcsdup.c
target thumb C: libsh <= external/bash/lib/sh/fpurge.c
target thumb C: libsh <= external/bash/lib/sh/zgetline.c
target thumb C: libsh <= external/bash/lib/sh/mbscmp.c
external/bash/lib/sh/zgetline.c: In function 'zgetline':
external/bash/lib/sh/zgetline.c:87:18: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
target thumb C: libsh <= external/bash/lib/sh/uconvert.c
target thumb C: libsh <= external/bash/lib/sh/ufuncs.c
target thumb C: libsh <= external/bash/lib/sh/casemod.c
target thumb C: libsh <= external/bash/lib/sh/fdprintf.c
target thumb C: libsh <= external/bash/lib/sh/input_avail.c
external/bash/lib/sh/casemod.c: In function 'sh_modcase':
external/bash/lib/sh/casemod.c:211:57: warning: signed and unsigned type in conditional expression [-Wsign-compare]
external/bash/lib/sh/casemod.c:212:57: warning: signed and unsigned type in conditional expression [-Wsign-compare]
external/bash/lib/sh/casemod.c:230:58: warning: signed and unsigned type in conditional expression [-Wsign-compare]
external/bash/lib/sh/casemod.c:231:58: warning: signed and unsigned type in conditional expression [-Wsign-compare]
target thumb C: libsh <= external/bash/lib/sh/mbscasecmp.c
target thumb C: libsh <= external/bash/lib/sh/fnxform.c
target thumb C: libsh <= external/bash/lib/sh/mbschr.c
target thumb C: libsh <= external/bash/lib/sh/shmbchar.c
target thumb C: libsh <= external/bash/lib/sh/unicode.c
target thumb C: libtilde <= external/bash/lib/tilde/tilde.c
target thumb C: libhistory <= external/bash/lib/readline/history.c
target thumb C: libhistory <= external/bash/lib/readline/histexpand.c
external/bash/lib/tilde/tilde.c: In function 'tilde_expand':
external/bash/lib/tilde/tilde.c:199:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: libhistory <= external/bash/lib/readline/histfile.c
target thumb C: libhistory <= external/bash/lib/readline/histsearch.c
target thumb C: libhistory <= external/bash/lib/readline/shell.c
target thumb C: libhistory <= external/bash/lib/readline/savestring.c
target thumb C: libhistory <= external/bash/lib/readline/mbutil.c
target thumb C: libhistory <= external/bash/lib/readline/xmalloc.c
target thumb C: libreadline <= external/bash/lib/readline/readline.c
target thumb C: libreadline <= external/bash/lib/readline/vi_mode.c
external/bash/lib/readline/histexpand.c: In function 'get_history_event':
external/bash/lib/readline/histexpand.c:207:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: libreadline <= external/bash/lib/readline/funmap.c
target thumb C: libreadline <= external/bash/lib/readline/keymaps.c
target thumb C: libreadline <= external/bash/lib/readline/parens.c
target thumb C: libreadline <= external/bash/lib/readline/search.c
target thumb C: libreadline <= external/bash/lib/readline/rltty.c
external/bash/lib/readline/search.c: In function '_rl_nsearch_init':
external/bash/lib/readline/search.c:213:3: warning: too many arguments for format [-Wformat-extra-args]
target thumb C: libreadline <= external/bash/lib/readline/complete.c
target thumb C: libreadline <= external/bash/lib/readline/bind.c
target thumb C: libreadline <= external/bash/lib/readline/isearch.c
target thumb C: libreadline <= external/bash/lib/readline/display.c
external/bash/lib/readline/bind.c: In function 'rl_translate_keyseq':
external/bash/lib/readline/bind.c:451:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/lib/readline/bind.c: In function 'rl_function_of_keyseq':
external/bash/lib/readline/bind.c:710:7: warning: comparison is always true due to limited range of data type [-Wtype-limits]
external/bash/lib/readline/bind.c: In function 'rl_parse_and_bind':
external/bash/lib/readline/bind.c:1197:7: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/lib/readline/bind.c:1288:7: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/lib/readline/bind.c: In function 'rl_function_dumper':
external/bash/lib/readline/bind.c:2117:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: libreadline <= external/bash/lib/readline/signals.c
external/bash/lib/readline/complete.c: In function '_rl_find_completion_word':
external/bash/lib/readline/complete.c:984:7: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/lib/readline/complete.c: In function 'rl_completion_matches':
external/bash/lib/readline/complete.c:1992:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/lib/readline/complete.c: In function 'rl_filename_completion_function':
external/bash/lib/readline/complete.c:2266:43: warning: signed and unsigned type in conditional expression [-Wsign-compare]
external/bash/lib/readline/complete.c:2347:8: warning: 'convfn' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/bash/lib/readline/complete.c:2146:25: note: 'convfn' was declared here
external/bash/lib/readline/complete.c:2346:10: warning: 'dentry' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/bash/lib/readline/complete.c:2146:16: note: 'dentry' was declared here
external/bash/lib/readline/complete.c: In function 'rl_complete_internal':
external/bash/lib/readline/complete.c:1886:7: warning: 'tlen' may be used uninitialized in this function [-Wmaybe-uninitialized]
target thumb C: libreadline <= external/bash/lib/readline/util.c
target thumb C: libreadline <= external/bash/lib/readline/kill.c
external/bash/lib/readline/util.c: In function '_rl_tropen':
external/bash/lib/readline/util.c:510:3: warning: format '%ld' expects argument of type 'long int', but argument 3 has type 'pid_t' [-Wformat]
target thumb C: libreadline <= external/bash/lib/readline/undo.c
external/bash/lib/readline/undo.c: In function '_rl_fix_last_undo_of_type':
external/bash/lib/readline/undo.c:243:20: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
target thumb C: libreadline <= external/bash/lib/readline/macro.c
target thumb C: libreadline <= external/bash/lib/readline/input.c
target thumb C: libreadline <= external/bash/lib/readline/callback.c
external/bash/lib/readline/display.c: In function 'expand_prompt':
external/bash/lib/readline/display.c:269:18: warning: signed and unsigned type in conditional expression [-Wsign-compare]
external/bash/lib/readline/display.c: In function 'rl_redisplay':
external/bash/lib/readline/display.c:877:23: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/lib/readline/display.c:1047:50: warning: signed and unsigned type in conditional expression [-Wsign-compare]
external/bash/lib/readline/display.c: In function 'rl_character_len':
external/bash/lib/readline/display.c:2105:3: warning: comparison is always true due to limited range of data type [-Wtype-limits]
target thumb C: libreadline <= external/bash/lib/readline/terminal.c
external/bash/lib/readline/input.c: In function 'rl_read_key':
external/bash/lib/readline/input.c:424:7: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: libreadline <= external/bash/lib/readline/text.c
target thumb C: libreadline <= external/bash/lib/readline/nls.c
target thumb C: libreadline <= external/bash/lib/readline/misc.c
external/bash/lib/readline/terminal.c: In function 'get_term_capabilities':
external/bash/lib/readline/terminal.c:414:17: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/lib/readline/terminal.c: In function 'rl_get_termcap':
external/bash/lib/readline/terminal.c:579:17: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
target thumb C: libreadline <= external/bash/lib/readline/history.c
external/bash/lib/readline/misc.c: In function '_rl_revert_all_lines':
external/bash/lib/readline/misc.c:456:7: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: libreadline <= external/bash/lib/readline/histexpand.c
target thumb C: libreadline <= external/bash/lib/readline/histfile.c
target thumb C: libreadline <= external/bash/lib/readline/histsearch.c
target thumb C: libreadline <= external/bash/lib/readline/shell.c
target thumb C: libreadline <= external/bash/lib/readline/savestring.c
target thumb C: libreadline <= external/bash/lib/readline/mbutil.c
target thumb C: libreadline <= external/bash/lib/readline/tilde.c
external/bash/lib/readline/tilde.c: In function 'tilde_expand':
external/bash/lib/readline/tilde.c:199:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: libreadline <= external/bash/lib/readline/xmalloc.c
target thumb C: libreadline <= external/bash/lib/readline/compat.c
Construct recovery from boot
mkdir -p out/target/product/mako/obj/PACKAGING/recovery_patch_intermediates/
PATH=out/host/linux-x86/bin:$PATH out/host/linux-x86/bin/imgdiff out/target/product/mako/boot.img out/target/product/mako/recovery.img out/target/product/mako/obj/PACKAGING/recovery_patch_intermediates/recovery_from_boot.p
target Symbolic: busybox (out/target/product/mako/symbols/system/xbin/busybox)
target thumb C: nano <= external/nano/src/browser.c
target thumb C: nano <= external/nano/src/chars.c
target thumb C: nano <= external/nano/src/color.c
external/nano/src/chars.c: In function 'move_mbleft':
external/nano/src/chars.c:485:15: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
target thumb C: nano <= external/nano/src/cut.c
target thumb C: nano <= external/nano/src/files.c
target thumb C: nano <= external/nano/src/global.c
failed to reconstruct target deflate chunk 1 [(null)]; treating as normal
target thumb C: nano <= external/nano/src/help.c
chunk 0: type 0 start 0 len 6017034
chunk 1: type 2 start 6017034 len 905216
chunk 2: type 0 start 6517464 len 1320
Construct patches for 3 chunks...
target thumb C: nano <= external/nano/src/move.c
target thumb C: nano <= external/nano/src/nano.c
target thumb C: nano <= external/nano/src/prompt.c
external/nano/src/prompt.c: In function 'get_statusbar_page_start':
external/nano/src/prompt.c:831:39: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
target thumb C: nano <= external/nano/src/rcfile.c
external/nano/src/nano.c: In function 'do_output':
external/nano/src/nano.c:1997:61: warning: 'orig_lenpt' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/nano/src/nano.c:1909:25: note: 'orig_lenpt' was declared here
target thumb C: nano <= external/nano/src/search.c
external/nano/src/rcfile.c: In function 'check_bad_binding':
external/nano/src/rcfile.c:370:21: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/rcfile.c: In function 'parse_keybinding':
external/nano/src/rcfile.c:392:19: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/rcfile.c: In function 'parse_unbinding':
external/nano/src/rcfile.c:489:19: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/rcfile.c: In function 'parse_rcfile':
external/nano/src/rcfile.c:897:5: warning: implicit declaration of function 'ngetline' [-Wimplicit-function-declaration]
target thumb C: nano <= external/nano/src/text.c
external/nano/src/text.c: In function 'do_wrap':
external/nano/src/text.c:1223:38: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/text.c:1316:29: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/text.c: In function 'break_line':
external/nano/src/text.c:1369:34: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/text.c:1389:14: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
target thumb C: nano <= external/nano/src/utils.c
external/nano/src/search.c: In function 'search_init':
external/nano/src/search.c:170:26: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/search.c: In function 'findnextstr':
external/nano/src/search.c:332:45: warning: signed and unsigned type in conditional expression [-Wsign-compare]
external/nano/src/search.c: In function 'replace_regexp':
external/nano/src/search.c:609:46: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
target thumb C: nano <= external/nano/src/winio.c
external/nano/src/utils.c: In function 'ngetdelim':
external/nano/src/utils.c:235:48: warning: signed and unsigned type in conditional expression [-Wsign-compare]
external/nano/src/utils.c: In function 'get_page_start':
external/nano/src/utils.c:462:31: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/utils.c: In function 'strnlenpt':
external/nano/src/utils.c:521:13: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
target SharedLib: libncurses (out/target/product/mako/obj/SHARED_LIBRARIES/libncurses_intermediates/LINKED/libncurses.so)
target thumb C: bash <= external/bash/shell.c
external/nano/src/winio.c: In function 'titlebar':
external/nano/src/winio.c:2128:13: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/winio.c:2156:31: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/winio.c:2176:41: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/winio.c:2185:15: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/winio.c:2197:30: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/winio.c:2237:15: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/winio.c: In function 'edit_draw':
external/nano/src/winio.c:2548:33: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/winio.c:2549:21: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/winio.c:2550:32: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/winio.c:2653:19: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/winio.c:2677:24: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/winio.c:2681:34: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/winio.c:2689:32: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/winio.c:2706:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/nano/src/winio.c: In function 'update_line':
external/nano/src/winio.c:2887:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
target thumb C: bash <= external/bash/eval.c
external/bash/shell.c: In function 'parse_shell_options':
external/bash/shell.c:834:7: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/shell.c: In function 'get_current_user_info':
external/bash/shell.c:1652:27: warning: assignment discards 'const' qualifier from pointer target type [enabled by default]
external/bash/shell.c: In function 'main':
external/bash/shell.c:351:10: warning: argument 'argc' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
external/bash/shell.c:352:13: warning: argument 'argv' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
external/bash/shell.c:352:21: warning: argument 'env' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
target thumb C: bash <= external/bash/y.tab.c
external/bash/eval.c: In function 'reader_loop':
external/bash/eval.c:145:4: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: bash <= external/bash/general.c
external/bash/general.c: In function 'print_rlimtype':
external/bash/general.c:121:3: warning: comparison of unsigned expression < 0 is always false [-Wtype-limits]
external/bash/general.c: In function 'assignment':
external/bash/general.c:278:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: bash <= external/bash/make_cmd.c
external/bash/make_cmd.c: In function 'make_word_flags':
external/bash/make_cmd.c:121:12: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/make_cmd.c: In function 'make_here_document':
external/bash/make_cmd.c:614:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: bash <= external/bash/print_cmd.c
external/bash/print_cmd.c: In function 'make_command_string_internal':
external/bash/print_cmd.c:167:5: warning: zero-length gnu_printf format string [-Wformat-zero-length]
external/bash/print_cmd.c: In function 'indirection_level_string':
external/bash/print_cmd.c:438:71: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/print_cmd.c:438:105: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
target thumb C: bash <= external/bash/dispose_cmd.c
target thumb C: bash <= external/bash/execute_cmd.c
patch 0 is 212 bytes (of 6017034)
/Users/chet/src/bash/src/parse.y: In function 'cond_error':
/Users/chet/src/bash/src/parse.y:4028:7: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
/Users/chet/src/bash/src/parse.y: In function 'cond_term':
/Users/chet/src/bash/src/parse.y:4110:4: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
/Users/chet/src/bash/src/parse.y:4142:4: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
/Users/chet/src/bash/src/parse.y:4192:4: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
/Users/chet/src/bash/src/parse.y:4218:4: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
/Users/chet/src/bash/src/parse.y:4236:7: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
/Users/chet/src/bash/src/parse.y: In function 'decode_prompt_string':
/Users/chet/src/bash/src/parse.y:5068:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
/Users/chet/src/bash/src/parse.y: In function 'error_token_from_token':
/Users/chet/src/bash/src/parse.y:5445:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
/Users/chet/src/bash/src/parse.y:5448:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
/Users/chet/src/bash/src/parse.y: In function 'report_syntax_error':
/Users/chet/src/bash/src/parse.y:5594:11: warning: assignment discards 'const' qualifier from pointer target type [enabled by default]
/Users/chet/src/bash/src/parse.y:5151:11: warning: 'n' may be used uninitialized in this function [-Wmaybe-uninitialized]
/Users/chet/src/bash/src/parse.y: In function 'parse_comsub.constprop.9':
/Users/chet/src/bash/src/parse.y:3820:27: warning: 'nestret' may be used uninitialized in this function [-Wmaybe-uninitialized]
/Users/chet/src/bash/src/parse.y:3403:15: note: 'nestret' was declared here
/Users/chet/src/bash/src/parse.y:3468:79: warning: 'hdlen' may be used uninitialized in this function [-Wmaybe-uninitialized]
/Users/chet/src/bash/src/parse.y: In function 'parse_matched_pair':
/Users/chet/src/bash/src/parse.y:3378:27: warning: 'nestret' may be used uninitialized in this function [-Wmaybe-uninitialized]
target thumb C: bash <= external/bash/variables.c
patch 1 is 405180 bytes (of 500430)
patch 2 is 85 bytes (of 146535248)
chunk 0: normal ( 0, 6017034) 212
chunk 1: deflate ( 6017034, 1060769) 405180 (null)
chunk 2: raw ( 7077803, 85)
target thumb C: bash <= external/bash/copy_cmd.c
external/bash/execute_cmd.c: In function 'execute_command_internal':
external/bash/execute_cmd.c:984:3: warning: enumeration value 'cm_for' not handled in switch [-Wswitch]
external/bash/execute_cmd.c:984:3: warning: enumeration value 'cm_case' not handled in switch [-Wswitch]
external/bash/execute_cmd.c:984:3: warning: enumeration value 'cm_while' not handled in switch [-Wswitch]
external/bash/execute_cmd.c:984:3: warning: enumeration value 'cm_if' not handled in switch [-Wswitch]
external/bash/execute_cmd.c:984:3: warning: enumeration value 'cm_simple' not handled in switch [-Wswitch]
external/bash/execute_cmd.c:984:3: warning: enumeration value 'cm_select' not handled in switch [-Wswitch]
external/bash/execute_cmd.c:984:3: warning: enumeration value 'cm_connection' not handled in switch [-Wswitch]
external/bash/execute_cmd.c:984:3: warning: enumeration value 'cm_function_def' not handled in switch [-Wswitch]
external/bash/execute_cmd.c:984:3: warning: enumeration value 'cm_until' not handled in switch [-Wswitch]
external/bash/execute_cmd.c:984:3: warning: enumeration value 'cm_group' not handled in switch [-Wswitch]
external/bash/execute_cmd.c:984:3: warning: enumeration value 'cm_arith_for' not handled in switch [-Wswitch]
external/bash/execute_cmd.c:984:3: warning: enumeration value 'cm_subshell' not handled in switch [-Wswitch]
external/bash/execute_cmd.c:984:3: warning: enumeration value 'cm_coproc' not handled in switch [-Wswitch]
external/bash/execute_cmd.c: In function 'execute_in_subshell':
external/bash/execute_cmd.c:1507:5: warning: passing argument 1 of 'execute_command_internal' discards 'volatile' qualifier from pointer target type [enabled by default]
external/bash/execute_cmd.c:522:1: note: expected 'struct COMMAND *' but argument is of type 'volatile struct COMMAND *'
external/bash/execute_cmd.c: In function 'coproc_pidchk':
external/bash/execute_cmd.c:1905:1: warning: type of 'status' defaults to 'int' [-Wmissing-parameter-type]
external/bash/execute_cmd.c: In function 'displen':
external/bash/execute_cmd.c:2720:12: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/execute_cmd.c: In function 'execute_cond_node':
external/bash/execute_cmd.c:3376:5: warning: suggest parentheses around '&&' within '||' [-Wparentheses]
external/bash/execute_cmd.c: In function 'execute_function':
external/bash/execute_cmd.c:4243:3: warning: passing argument 1 of 'array_rshift' discards 'volatile' qualifier from pointer target type [enabled by default]
In file included from external/bash/variables.h:25:0,
from external/bash/shell.h:31,
from external/bash/execute_cmd.c:66:
external/bash/array.h:56:12: note: expected 'struct ARRAY *' but argument is of type 'volatile struct ARRAY *'
external/bash/execute_cmd.c:4245:3: warning: passing argument 1 of 'array_rshift' discards 'volatile' qualifier from pointer target type [enabled by default]
external/bash/execute_cmd.c:4320:3: warning: passing argument 1 of 'array_shift' discards 'volatile' qualifier from pointer target type [enabled by default]
external/bash/array.h:55:23: note: expected 'struct ARRAY *' but argument is of type 'volatile struct ARRAY *'
external/bash/execute_cmd.c:4321:3: warning: passing argument 1 of 'array_shift' discards 'volatile' qualifier from pointer target type [enabled by default]
external/bash/execute_cmd.c:4139:19: warning: variable 'bash_source_a' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
external/bash/execute_cmd.c:4140:19: warning: variable 'bash_lineno_a' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
external/bash/execute_cmd.c:1320:21: warning: variable 'tcom' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
target thumb C: bash <= external/bash/error.c
target thumb C: bash <= external/bash/expr.c
external/bash/error.c: In function 'command_errstr':
external/bash/error.c:431:3: warning: return discards 'const' qualifier from pointer target type [enabled by default]
target thumb C: bash <= external/bash/flags.c
target thumb C: bash <= external/bash/jobs.c
external/bash/variables.c: In function 'initialize_shell_variables':
external/bash/variables.c:318:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/variables.c:357:4: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/variables.c: In function 'var_lookup':
external/bash/variables.c:1755:5: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/variables.c: In function 'makunbound':
external/bash/variables.c:2733:5: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/variables.c: In function 'make_env_array_from_var_list':
external/bash/variables.c:3466:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/variables.c: In function 'pop_var_context':
external/bash/variables.c:3895:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/variables.c: In function 'sv_history_control':
external/bash/variables.c:4507:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/variables.c: In function 'flatten.isra.1':
external/bash/variables.c:2930:6: warning: assuming signed overflow does not occur when assuming that (X + c) >= X is always true [-Wstrict-overflow]
target thumb C: bash <= external/bash/subst.c
external/bash/expr.c:207:17: warning: conflicting types for built-in function 'exp2' [enabled by default]
external/bash/expr.c: In function 'expassign':
external/bash/expr.c:507:15: warning: 'lvalue' may be used uninitialized in this function [-Wmaybe-uninitialized]
target thumb C: bash <= external/bash/hashcmd.c
target thumb C: bash <= external/bash/hashlib.c
target thumb C: bash <= external/bash/mailcheck.c
external/bash/mailcheck.c: In function 'file_mod_date_changed':
external/bash/mailcheck.c:271:19: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/mailcheck.c: In function 'file_access_date_changed':
external/bash/mailcheck.c:292:19: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/mailcheck.c: In function 'remember_mail_dates':
external/bash/mailcheck.c:388:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/mailcheck.c: In function 'check_mail':
external/bash/mailcheck.c:433:12: warning: assignment discards 'const' qualifier from pointer target type [enabled by default]
external/bash/mailcheck.c:458:14: warning: assignment discards 'const' qualifier from pointer target type [enabled by default]
external/bash/mailcheck.c:462:4: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: bash <= external/bash/trap.c
external/bash/jobs.c: In function 'nohup_job':
external/bash/jobs.c:1068:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/jobs.c: In function 'printable_job_status':
external/bash/jobs.c:1459:8: warning: assignment discards 'const' qualifier from pointer target type [enabled by default]
external/bash/jobs.c:1464:7: warning: assignment discards 'const' qualifier from pointer target type [enabled by default]
external/bash/jobs.c:1472:10: warning: assignment discards 'const' qualifier from pointer target type [enabled by default]
external/bash/jobs.c:1491:7: warning: assignment discards 'const' qualifier from pointer target type [enabled by default]
target thumb C: bash <= external/bash/input.c
In file included from external/bash/trap.c:42:0:
external/bash/signames.h:42:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:42:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:43:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:43:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:44:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:44:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:45:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:45:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:46:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:46:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:47:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:47:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:48:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:48:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:49:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:49:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:50:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:50:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:51:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:51:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:52:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:52:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:53:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:53:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:54:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:54:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:55:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:55:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:56:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:56:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:57:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:57:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:58:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:58:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:59:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:59:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:60:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:60:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:61:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:61:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:62:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:62:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:63:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:63:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:64:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:64:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:65:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:65:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:66:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:66:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:67:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:67:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:68:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:68:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:69:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:69:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:70:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:70:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:71:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:71:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:72:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:72:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:73:5: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:73:5: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/signames.h:75:1: warning: excess elements in array initializer [enabled by default]
external/bash/signames.h:75:1: warning: (near initialization for 'signal_names') [enabled by default]
external/bash/trap.c: In function 'signal_name':
external/bash/trap.c:206:7: warning: assignment discards 'const' qualifier from pointer target type [enabled by default]
external/bash/trap.c: In function 'run_exit_trap':
external/bash/trap.c:707:28: warning: variable 'retval' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
target thumb C: bash <= external/bash/unwind_prot.c
target thumb C: bash <= external/bash/pathexp.c
external/bash/unwind_prot.c: In function 'unwind_frame_discard_internal':
external/bash/unwind_prot.c:247:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/unwind_prot.c: In function 'unwind_frame_run_internal':
external/bash/unwind_prot.c:282:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: bash <= external/bash/sig.c
external/bash/pathexp.c: In function 'unquoted_glob_pattern_p':
external/bash/pathexp.c:75:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/pathexp.c: In function 'quote_globbing_chars':
external/bash/pathexp.c:239:344: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/pathexp.c: In function 'setup_ignore_patterns':
external/bash/pathexp.c:498:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: bash <= external/bash/test.c
external/bash/sig.c: In function 'initialize_terminating_signals':
external/bash/sig.c:244:17: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/sig.c:246:17: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/sig.c: In function 'reset_terminating_signals':
external/bash/sig.c:339:17: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
target thumb C: bash <= external/bash/version.c
target thumb C: bash <= external/bash/alias.c
external/bash/test.c: In function 'beyond':
external/bash/test.c:146:3: warning: passing argument 1 of 'test_syntax_error' discards 'const' qualifier from pointer target type [enabled by default]
external/bash/test.c:132:1: note: expected 'char *' but argument is of type 'const char *'
external/bash/test.c: In function 'integer_expected_error':
external/bash/test.c:155:3: warning: passing argument 1 of 'test_syntax_error' discards 'const' qualifier from pointer target type [enabled by default]
external/bash/test.c: In function 'term':
external/bash/test.c:263:2: warning: passing argument 1 of 'test_syntax_error' discards 'const' qualifier from pointer target type [enabled by default]
external/bash/test.c:265:2: warning: passing argument 1 of 'test_syntax_error' discards 'const' qualifier from pointer target type [enabled by default]
external/bash/test.c:280:2: warning: passing argument 1 of 'test_syntax_error' discards 'const' qualifier from pointer target type [enabled by default]
external/bash/test.c: In function 'binary_operator':
external/bash/test.c:449:7: warning: passing argument 1 of 'test_syntax_error' discards 'const' qualifier from pointer target type [enabled by default]
external/bash/test.c: In function 'two_arguments':
external/bash/test.c:698:2: warning: passing argument 1 of 'test_syntax_error' discards 'const' qualifier from pointer target type [enabled by default]
external/bash/test.c:701:5: warning: passing argument 1 of 'test_syntax_error' discards 'const' qualifier from pointer target type [enabled by default]
external/bash/test.c: In function 'three_arguments':
external/bash/test.c:741:5: warning: passing argument 1 of 'test_syntax_error' discards 'const' qualifier from pointer target type [enabled by default]
external/bash/test.c: In function 'test_command':
external/bash/test.c:816:2: warning: passing argument 1 of 'test_syntax_error' discards 'const' qualifier from pointer target type [enabled by default]
external/bash/test.c:832:5: warning: passing argument 1 of 'test_syntax_error' discards 'const' qualifier from pointer target type [enabled by default]
external/bash/test.c:796:10: warning: argument 'margc' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
target thumb C: bash <= external/bash/array.c
target thumb C: bash <= external/bash/arrayfunc.c
target thumb C: bash <= external/bash/assoc.c
external/bash/subst.c: In function 'unquoted_member':
external/bash/subst.c:561:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/subst.c: In function 'unquoted_substring':
external/bash/subst.c:604:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/subst.c: In function 'string_extract':
external/bash/subst.c:713:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/subst.c: In function 'string_extract_double_quoted':
external/bash/subst.c:784:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/subst.c:818:376: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c: In function 'skip_double_quoted':
external/bash/subst.c:932:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/subst.c: In function 'string_extract_verbatim':
external/bash/subst.c:1068:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/subst.c:1104:13: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c: In function 'extract_dollar_brace_string':
external/bash/subst.c:1388:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/subst.c: In function 'de_backslash':
external/bash/subst.c:1533:12: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c: In function 'skip_matched_pair':
external/bash/subst.c:1599:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/subst.c: In function 'skip_to_delim':
external/bash/subst.c:1707:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/subst.c: In function 'do_assignment_internal':
external/bash/subst.c:2791:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/subst.c: In function 'quote_escapes':
external/bash/subst.c:3446:344: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c: In function 'dequote_escapes':
external/bash/subst.c:3511:344: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c: In function 'quote_string':
external/bash/subst.c:3570:356: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c: In function 'dequote_string':
external/bash/subst.c:3612:344: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c: In function 'remove_quoted_nulls':
external/bash/subst.c:3695:12: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c:3704:10: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c: In function 'remove_wpattern':
external/bash/subst.c:3878:3: warning: implicit declaration of function 'wcsdup' [-Wimplicit-function-declaration]
external/bash/subst.c:3878:3: warning: return makes pointer from integer without a cast [enabled by default]
external/bash/subst.c:3885:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c:3891:3: warning: return makes pointer from integer without a cast [enabled by default]
external/bash/subst.c:3898:23: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c:3903:7: warning: assignment makes pointer from integer without a cast [enabled by default]
external/bash/subst.c:3916:7: warning: assignment makes pointer from integer without a cast [enabled by default]
external/bash/subst.c: In function 'match_wpattern':
external/bash/subst.c:4196:21: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c:4208:36: warning: signed and unsigned type in conditional expression [-Wsign-compare]
external/bash/subst.c:4209:15: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c:4242:39: warning: signed and unsigned type in conditional expression [-Wsign-compare]
external/bash/subst.c:4267:50: warning: signed and unsigned type in conditional expression [-Wsign-compare]
external/bash/subst.c:4267:61: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c: In function 'parameter_brace_expand_word':
external/bash/subst.c:5685:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/subst.c: In function 'pat_subst':
external/bash/subst.c:6506:105: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c:6506:213: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c: In function 'parameter_brace_expand':
external/bash/subst.c:6975:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/subst.c:6985:7: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/subst.c: In function 'expand_word_internal':
external/bash/subst.c:7951:414: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c:8196:440: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c:8200:438: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c:8210:440: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c:8442:415: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c:8454:406: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/subst.c: In function 'string_quote_removal':
external/bash/subst.c:8603:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/subst.c: In function 'brace_expand_word_list':
external/bash/subst.c:9109:4: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/subst.c: In function 'command_substitute':
external/bash/subst.c:5163:16: warning: 'bufp' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/bash/subst.c:5140:29: note: 'bufp' was declared here
external/bash/subst.c:5251:42: warning: variable 'pflags' might be clobbered by 'longjmp' or 'vfork' [-Wclobbered]
external/bash/subst.c: In function 'word_list_split':
external/bash/subst.c:8792:12: warning: 'e' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/bash/subst.c:7260:32: warning: 'temp' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/bash/subst.c:7241:32: warning: 'temp' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/bash/subst.c:6363:7: warning: 'e2' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/bash/subst.c:6298:16: note: 'e2' was declared here
external/bash/subst.c:6110:9: warning: 'a' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/bash/subst.c:6050:9: note: 'a' was declared here
external/bash/subst.c:6110:9: warning: 'h' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/bash/subst.c:6051:14: note: 'h' was declared here
external/bash/subst.c:5924:22: warning: 't' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/bash/subst.c:5889:9: note: 't' was declared here
external/bash/subst.c:6797:11: warning: 'modspec' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/bash/subst.c:6919:34: note: 'modspec' was declared here
target thumb C: bash <= external/bash/braces.c
target thumb C: bash <= external/bash/bracecomp.c
external/bash/arrayfunc.c: In function 'quote_assign':
external/bash/arrayfunc.c:595:344: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
external/bash/arrayfunc.c: In function 'array_value_internal':
external/bash/arrayfunc.c:968:9: warning: 'akey' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/bash/arrayfunc.c:874:9: note: 'akey' was declared here
external/bash/arrayfunc.c:971:9: warning: 'ind' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/bash/arrayfunc.c:873:14: note: 'ind' was declared here
target thumb C: bash <= external/bash/bashhist.c
target thumb C: bash <= external/bash/bashline.c
external/bash/braces.c: In function 'brace_gobbler':
external/bash/braces.c:504:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/braces.c: In function 'brace_expand':
external/bash/braces.c:353:46: warning: 'tr' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/bash/braces.c:370:16: note: 'tr' was declared here
target thumb C: bash <= external/bash/list.c
external/bash/bashhist.c: In function 'hc_erasedups':
external/bash/bashhist.c:631:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: bash <= external/bash/stringlib.c
target thumb C: bash <= external/bash/locale.c
target thumb C: bash <= external/bash/findcmd.c
external/bash/locale.c: In function 'localetrans':
external/bash/locale.c:385:16: warning: assignment discards 'const' qualifier from pointer target type [enabled by default]
target thumb C: bash <= external/bash/redir.c
external/bash/findcmd.c: In function '_find_user_command_internal':
external/bash/findcmd.c:238:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
target thumb C: bash <= external/bash/pcomplete.c
external/bash/redir.c: In function 'redirection_error':
external/bash/redir.c:122:14: warning: assignment discards 'const' qualifier from pointer target type [enabled by default]
external/bash/redir.c: In function 'do_redirection_internal':
external/bash/redir.c:712:4: warning: enumeration value 'r_output_direction' not handled in switch [-Wswitch]
external/bash/redir.c:712:4: warning: enumeration value 'r_input_direction' not handled in switch [-Wswitch]
external/bash/redir.c:712:4: warning: enumeration value 'r_inputa_direction' not handled in switch [-Wswitch]
external/bash/redir.c:712:4: warning: enumeration value 'r_appending_to' not handled in switch [-Wswitch]
external/bash/redir.c:712:4: warning: enumeration value 'r_reading_until' not handled in switch [-Wswitch]
external/bash/redir.c:712:4: warning: enumeration value 'r_reading_string' not handled in switch [-Wswitch]
external/bash/redir.c:712:4: warning: enumeration value 'r_duplicating_input' not handled in switch [-Wswitch]
external/bash/redir.c:712:4: warning: enumeration value 'r_duplicating_output' not handled in switch [-Wswitch]
external/bash/redir.c:712:4: warning: enumeration value 'r_deblank_reading_until' not handled in switch [-Wswitch]
external/bash/redir.c:712:4: warning: enumeration value 'r_close_this' not handled in switch [-Wswitch]
external/bash/redir.c:712:4: warning: enumeration value 'r_err_and_out' not handled in switch [-Wswitch]
external/bash/redir.c:712:4: warning: enumeration value 'r_input_output' not handled in switch [-Wswitch]
external/bash/redir.c:712:4: warning: enumeration value 'r_output_force' not handled in switch [-Wswitch]
external/bash/redir.c:712:4: warning: enumeration value 'r_move_input' not handled in switch [-Wswitch]
external/bash/redir.c:712:4: warning: enumeration value 'r_move_output' not handled in switch [-Wswitch]
external/bash/redir.c:712:4: warning: enumeration value 'r_append_err_and_out' not handled in switch [-Wswitch]
external/bash/redir.c:772:3: warning: enumeration value 'r_move_input_word' not handled in switch [-Wswitch]
external/bash/redir.c:772:3: warning: enumeration value 'r_move_output_word' not handled in switch [-Wswitch]
external/bash/redir.c: In function 'stdin_redirection':
external/bash/redir.c:1234:3: warning: enumeration value 'r_move_input' not handled in switch [-Wswitch]
external/bash/redir.c:1234:3: warning: enumeration value 'r_move_output' not handled in switch [-Wswitch]
external/bash/redir.c:1234:3: warning: enumeration value 'r_move_input_word' not handled in switch [-Wswitch]
external/bash/redir.c:1234:3: warning: enumeration value 'r_move_output_word' not handled in switch [-Wswitch]
external/bash/redir.c:789:20: warning: 'oflags' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/bash/redir.c:744:23: warning: 'new_redirect' may be used uninitialized in this function [-Wmaybe-uninitialized]
external/bash/redir.c:166:35: warning: 'oflags' may be used uninitialized in this function [-Wmaybe-uninitialized]
target thumb C: bash <= external/bash/pcomplib.c
target thumb C: bash <= external/bash/syntax.c
target thumb C: bash <= external/bash/xmalloc.c
external/bash/bashline.c: In function 'snarf_hosts_from_file':
external/bash/bashline.c:687:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/bashline.c: In function 'command_word_completion_function':
external/bash/bashline.c:1720:7: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/bashline.c: In function 'bash_servicename_completion_function':
external/bash/bashline.c:2083:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/bashline.c: In function 'bash_dequote_filename':
external/bash/bashline.c:3299:4: warning: array subscript has type 'char' [-Wchar-subscripts]
external/bash/bashline.c: In function 'isolate_sequence':
external/bash/bashline.c:3595:3: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
external/bash/bashline.c: In function '_ignore_completion_names':
external/bash/bashline.c:2511:7: warning: 'oldnames' may be used uninitialized in this function [-Wmaybe-uninitialized]
target StaticLib: libbuiltins (out/target/product/mako/obj/STATIC_LIBRARIES/libbuiltins_intermediates/libbuiltins.a)
target StaticLib: libglob (out/target/product/mako/obj/STATIC_LIBRARIES/libglob_intermediates/libglob.a)
target StaticLib: libsh (out/target/product/mako/obj/STATIC_LIBRARIES/libsh_intermediates/libsh.a)
target StaticLib: libtilde (out/target/product/mako/obj/STATIC_LIBRARIES/libtilde_intermediates/libtilde.a)
target StaticLib: libhistory (out/target/product/mako/obj/STATIC_LIBRARIES/libhistory_intermediates/libhistory.a)
target Strip: busybox (out/target/product/mako/obj/EXECUTABLES/busybox_intermediates/busybox)
target StaticLib: libreadline (out/target/product/mako/obj/STATIC_LIBRARIES/libreadline_intermediates/libreadline.a)
external/bash/pcomplete.c:149:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:149:1: warning: (near initialization for 'it_aliases.genlist') [-Wmissing-field-initializers]
external/bash/pcomplete.c:150:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:150:1: warning: (near initialization for 'it_arrayvars.genlist') [-Wmissing-field-initializers]
external/bash/pcomplete.c:151:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:151:1: warning: (near initialization for 'it_bindings.genlist') [-Wmissing-field-initializers]
external/bash/pcomplete.c:152:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:152:1: warning: (near initialization for 'it_builtins.genlist') [-Wmissing-field-initializers]
external/bash/pcomplete.c:153:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:153:1: warning: (near initialization for 'it_commands.list_getter') [-Wmissing-field-initializers]
external/bash/pcomplete.c:154:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:154:1: warning: (near initialization for 'it_directories.list_getter') [-Wmissing-field-initializers]
external/bash/pcomplete.c:155:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:155:1: warning: (near initialization for 'it_disabled.genlist') [-Wmissing-field-initializers]
external/bash/pcomplete.c:156:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:156:1: warning: (near initialization for 'it_enabled.genlist') [-Wmissing-field-initializers]
external/bash/pcomplete.c:157:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:157:1: warning: (near initialization for 'it_exports.genlist') [-Wmissing-field-initializers]
external/bash/pcomplete.c:158:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:158:1: warning: (near initialization for 'it_files.list_getter') [-Wmissing-field-initializers]
external/bash/pcomplete.c:159:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:159:1: warning: (near initialization for 'it_functions.genlist') [-Wmissing-field-initializers]
external/bash/pcomplete.c:160:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:160:1: warning: (near initialization for 'it_hostnames.genlist') [-Wmissing-field-initializers]
external/bash/pcomplete.c:161:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:161:1: warning: (near initialization for 'it_groups.list_getter') [-Wmissing-field-initializers]
external/bash/pcomplete.c:162:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:162:1: warning: (near initialization for 'it_jobs.genlist') [-Wmissing-field-initializers]
external/bash/pcomplete.c:163:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:163:1: warning: (near initialization for 'it_keywords.genlist') [-Wmissing-field-initializers]
external/bash/pcomplete.c:164:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:164:1: warning: (near initialization for 'it_running.genlist') [-Wmissing-field-initializers]
external/bash/pcomplete.c:165:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:165:1: warning: (near initialization for 'it_services.list_getter') [-Wmissing-field-initializers]
external/bash/pcomplete.c:166:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:166:1: warning: (near initialization for 'it_setopts.genlist') [-Wmissing-field-initializers]
external/bash/pcomplete.c:167:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:167:1: warning: (near initialization for 'it_shopts.genlist') [-Wmissing-field-initializers]
external/bash/pcomplete.c:168:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:168:1: warning: (near initialization for 'it_signals.genlist') [-Wmissing-field-initializers]
external/bash/pcomplete.c:169:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:169:1: warning: (near initialization for 'it_stopped.genlist') [-Wmissing-field-initializers]
external/bash/pcomplete.c:170:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:170:1: warning: (near initialization for 'it_users.list_getter') [-Wmissing-field-initializers]
external/bash/pcomplete.c:171:1: warning: missing initializer [-Wmissing-field-initializers]
external/bash/pcomplete.c:171:1: warning: (near initialization for 'it_variables.genlist') [-Wmissing-field-initializers]
target Symbolic: libncurses (out/target/product/mako/symbols/system/lib/libncurses.so)
target Strip: libncurses (out/target/product/mako/obj/lib/libncurses.so)
target Executable: nano (out/target/product/mako/obj/EXECUTABLES/nano_intermediates/LINKED/nano)
Install: out/target/product/mako/system/lib/libncurses.so
target Executable: bash (out/target/product/mako/obj/EXECUTABLES/bash_intermediates/LINKED/bash)
Install: out/target/product/mako/system/xbin/busybox
Symlink: out/target/product/mako/system/xbin/[ -> busybox
Symlink: out/target/product/mako/system/xbin/[[ -> busybox
Symlink: out/target/product/mako/system/xbin/adjtimex -> busybox
Symlink: out/target/product/mako/system/xbin/arp -> busybox
Symlink: out/target/product/mako/system/xbin/ash -> busybox
Symlink: out/target/product/mako/system/xbin/awk -> busybox
Symlink: out/target/product/mako/system/xbin/base64 -> busybox
Symlink: out/target/product/mako/system/xbin/basename -> busybox
Symlink: out/target/product/mako/system/xbin/bbconfig -> busybox
Symlink: out/target/product/mako/system/xbin/blkid -> busybox
Symlink: out/target/product/mako/system/xbin/blockdev -> busybox
Symlink: out/target/product/mako/system/xbin/brctl -> busybox
Symlink: out/target/product/mako/system/xbin/bunzip2 -> busybox
Symlink: out/target/product/mako/system/xbin/bzcat -> busybox
Symlink: out/target/product/mako/system/xbin/bzip2 -> busybox
Symlink: out/target/product/mako/system/xbin/cal -> busybox
Symlink: out/target/product/mako/system/xbin/cat -> busybox
Symlink: out/target/product/mako/system/xbin/catv -> busybox
Symlink: out/target/product/mako/system/xbin/chattr -> busybox
Symlink: out/target/product/mako/system/xbin/chgrp -> busybox
Symlink: out/target/product/mako/system/xbin/chmod -> busybox
Symlink: out/target/product/mako/system/xbin/chown -> busybox
Symlink: out/target/product/mako/system/xbin/chroot -> busybox
Symlink: out/target/product/mako/system/xbin/clear -> busybox
Symlink: out/target/product/mako/system/xbin/cmp -> busybox
Symlink: out/target/product/mako/system/xbin/comm -> busybox
Symlink: out/target/product/mako/system/xbin/cp -> busybox
Symlink: out/target/product/mako/system/xbin/cpio -> busybox
Symlink: out/target/product/mako/system/xbin/crond -> busybox
Symlink: out/target/product/mako/system/xbin/crontab -> busybox
Symlink: out/target/product/mako/system/xbin/date -> busybox
Symlink: out/target/product/mako/system/xbin/cut -> busybox
Symlink: out/target/product/mako/system/xbin/dc -> busybox
Symlink: out/target/product/mako/system/xbin/dd -> busybox
Symlink: out/target/product/mako/system/xbin/depmod -> busybox
Symlink: out/target/product/mako/system/xbin/devmem -> busybox
Symlink: out/target/product/mako/system/xbin/df -> busybox
Symlink: out/target/product/mako/system/xbin/diff -> busybox
Symlink: out/target/product/mako/system/xbin/dirname -> busybox
Symlink: out/target/product/mako/system/xbin/dmesg -> busybox
Symlink: out/target/product/mako/system/xbin/dnsd -> busybox
Symlink: out/target/product/mako/system/xbin/dos2unix -> busybox
Symlink: out/target/product/mako/system/xbin/du -> busybox
Symlink: out/target/product/mako/system/xbin/echo -> busybox
Symlink: out/target/product/mako/system/xbin/ed -> busybox
Symlink: out/target/product/mako/system/xbin/egrep -> busybox
Symlink: out/target/product/mako/system/xbin/env -> busybox
Symlink: out/target/product/mako/system/xbin/expand -> busybox
Symlink: out/target/product/mako/system/xbin/expr -> busybox
Symlink: out/target/product/mako/system/xbin/false -> busybox
Symlink: out/target/product/mako/system/xbin/fbsplash -> busybox
Symlink: out/target/product/mako/system/xbin/fdisk -> busybox
Symlink: out/target/product/mako/system/xbin/fgrep -> busybox
Symlink: out/target/product/mako/system/xbin/find -> busybox
Symlink: out/target/product/mako/system/xbin/flash_lock -> busybox
Symlink: out/target/product/mako/system/xbin/flash_unlock -> busybox
Symlink: out/target/product/mako/system/xbin/flashcp -> busybox
Symlink: out/target/product/mako/system/xbin/flock -> busybox
Symlink: out/target/product/mako/system/xbin/fold -> busybox
Symlink: out/target/product/mako/system/xbin/free -> busybox
Symlink: out/target/product/mako/system/xbin/freeramdisk -> busybox
Symlink: out/target/product/mako/system/xbin/fstrim -> busybox
Symlink: out/target/product/mako/system/xbin/fsync -> busybox
Symlink: out/target/product/mako/system/xbin/ftpget -> busybox
Symlink: out/target/product/mako/system/xbin/ftpput -> busybox
Symlink: out/target/product/mako/system/xbin/fuser -> busybox
Symlink: out/target/product/mako/system/xbin/getopt -> busybox
Symlink: out/target/product/mako/system/xbin/grep -> busybox
Symlink: out/target/product/mako/system/xbin/groups -> busybox
Symlink: out/target/product/mako/system/xbin/gunzip -> busybox
Symlink: out/target/product/mako/system/xbin/gzip -> busybox
Symlink: out/target/product/mako/system/xbin/halt -> busybox
Symlink: out/target/product/mako/system/xbin/head -> busybox
Symlink: out/target/product/mako/system/xbin/hexdump -> busybox
Symlink: out/target/product/mako/system/xbin/id -> busybox
Symlink: out/target/product/mako/system/xbin/ifconfig -> busybox
Symlink: out/target/product/mako/system/xbin/inetd -> busybox
Symlink: out/target/product/mako/system/xbin/insmod -> busybox
Symlink: out/target/product/mako/system/xbin/install -> busybox
Symlink: out/target/product/mako/system/xbin/ionice -> busybox
Symlink: out/target/product/mako/system/xbin/iostat -> busybox
Symlink: out/target/product/mako/system/xbin/ip -> busybox
Symlink: out/target/product/mako/system/xbin/kill -> busybox
Symlink: out/target/product/mako/system/xbin/killall -> busybox
Symlink: out/target/product/mako/system/xbin/killall5 -> busybox
Symlink: out/target/product/mako/system/xbin/less -> busybox
Symlink: out/target/product/mako/system/xbin/ln -> busybox
Symlink: out/target/product/mako/system/xbin/losetup -> busybox
Symlink: out/target/product/mako/system/xbin/ls -> busybox
Symlink: out/target/product/mako/system/xbin/lsattr -> busybox
Symlink: out/target/product/mako/system/xbin/lsmod -> busybox
Symlink: out/target/product/mako/system/xbin/lsusb -> busybox
Symlink: out/target/product/mako/system/xbin/lzcat -> busybox
Symlink: out/target/product/mako/system/xbin/lzma -> busybox
Symlink: out/target/product/mako/system/xbin/lzop -> busybox
Symlink: out/target/product/mako/system/xbin/lzopcat -> busybox
Symlink: out/target/product/mako/system/xbin/man -> busybox
Symlink: out/target/product/mako/system/xbin/md5sum -> busybox
Symlink: out/target/product/mako/system/xbin/mesg -> busybox
Symlink: out/target/product/mako/system/xbin/mkdir -> busybox
Symlink: out/target/product/mako/system/xbin/mke2fs -> busybox
Symlink: out/target/product/mako/system/xbin/mkfifo -> busybox
Symlink: out/target/product/mako/system/xbin/mkfs.ext2 -> busybox
Symlink: out/target/product/mako/system/xbin/mkfs.vfat -> busybox
Symlink: out/target/product/mako/system/xbin/mknod -> busybox
Symlink: out/target/product/mako/system/xbin/mkswap -> busybox
Symlink: out/target/product/mako/system/xbin/mktemp -> busybox
Symlink: out/target/product/mako/system/xbin/modinfo -> busybox
Symlink: out/target/product/mako/system/xbin/modprobe -> busybox
Symlink: out/target/product/mako/system/xbin/more -> busybox
Symlink: out/target/product/mako/system/xbin/mount -> busybox
Symlink: out/target/product/mako/system/xbin/mountpoint -> busybox
Symlink: out/target/product/mako/system/xbin/mpstat -> busybox
Symlink: out/target/product/mako/system/xbin/mv -> busybox
Symlink: out/target/product/mako/system/xbin/nanddump -> busybox
Symlink: out/target/product/mako/system/xbin/nandwrite -> busybox
target Symbolic: nano (out/target/product/mako/symbols/system/xbin/nano)
Symlink: out/target/product/mako/system/xbin/nbd-client -> busybox
Symlink: out/target/product/mako/system/xbin/netstat -> busybox
Symlink: out/target/product/mako/system/xbin/nice -> busybox
Symlink: out/target/product/mako/system/xbin/nohup -> busybox
Symlink: out/target/product/mako/system/xbin/nslookup -> busybox
Symlink: out/target/product/mako/system/xbin/ntpd -> busybox
Symlink: out/target/product/mako/system/xbin/od -> busybox
Symlink: out/target/product/mako/system/xbin/patch -> busybox
Symlink: out/target/product/mako/system/xbin/pgrep -> busybox
Symlink: out/target/product/mako/system/xbin/pidof -> busybox
Symlink: out/target/product/mako/system/xbin/ping -> busybox
Symlink: out/target/product/mako/system/xbin/pipe_progress -> busybox
Symlink: out/target/product/mako/system/xbin/pkill -> busybox
Symlink: out/target/product/mako/system/xbin/pmap -> busybox
Symlink: out/target/product/mako/system/xbin/poweroff -> busybox
Symlink: out/target/product/mako/system/xbin/printenv -> busybox
Symlink: out/target/product/mako/system/xbin/printf -> busybox
Symlink: out/target/product/mako/system/xbin/ps -> busybox
Symlink: out/target/product/mako/system/xbin/pstree -> busybox
Symlink: out/target/product/mako/system/xbin/pwd -> busybox
Symlink: out/target/product/mako/system/xbin/pwdx -> busybox
Symlink: out/target/product/mako/system/xbin/rdev -> busybox
Symlink: out/target/product/mako/system/xbin/readlink -> busybox
Symlink: out/target/product/mako/system/xbin/realpath -> busybox
Symlink: out/target/product/mako/system/xbin/renice -> busybox
Symlink: out/target/product/mako/system/xbin/reset -> busybox
Symlink: out/target/product/mako/system/xbin/resize -> busybox
Symlink: out/target/product/mako/system/xbin/rev -> busybox
Symlink: out/target/product/mako/system/xbin/rm -> busybox
Symlink: out/target/product/mako/system/xbin/rmdir -> busybox
Symlink: out/target/product/mako/system/xbin/rmmod -> busybox
Symlink: out/target/product/mako/system/xbin/route -> busybox
Symlink: out/target/product/mako/system/xbin/run-parts -> busybox
Symlink: out/target/product/mako/system/xbin/rx -> busybox
Symlink: out/target/product/mako/system/xbin/sed -> busybox
Symlink: out/target/product/mako/system/xbin/seq -> busybox
Symlink: out/target/product/mako/system/xbin/setconsole -> busybox
Symlink: out/target/product/mako/system/xbin/setserial -> busybox
Symlink: out/target/product/mako/system/xbin/setsid -> busybox
Symlink: out/target/product/mako/system/xbin/sh -> busybox
Symlink: out/target/product/mako/system/xbin/sha1sum -> busybox
Symlink: out/target/product/mako/system/xbin/sha256sum -> busybox
Symlink: out/target/product/mako/system/xbin/sha3sum -> busybox
Symlink: out/target/product/mako/system/xbin/sha512sum -> busybox
Symlink: out/target/product/mako/system/xbin/sleep -> busybox
Symlink: out/target/product/mako/system/xbin/sort -> busybox
Symlink: out/target/product/mako/system/xbin/split -> busybox
Symlink: out/target/product/mako/system/xbin/stat -> busybox
Symlink: out/target/product/mako/system/xbin/strings -> busybox
Symlink: out/target/product/mako/system/xbin/stty -> busybox
Symlink: out/target/product/mako/system/xbin/sum -> busybox
Symlink: out/target/product/mako/system/xbin/swapoff -> busybox
Symlink: out/target/product/mako/system/xbin/swapon -> busybox
Symlink: out/target/product/mako/system/xbin/sync -> busybox
Symlink: out/target/product/mako/system/xbin/sysctl -> busybox
Symlink: out/target/product/mako/system/xbin/tac -> busybox
Symlink: out/target/product/mako/system/xbin/tail -> busybox
Symlink: out/target/product/mako/system/xbin/tar -> busybox
Symlink: out/target/product/mako/system/xbin/taskset -> busybox
Symlink: out/target/product/mako/system/xbin/tee -> busybox
Symlink: out/target/product/mako/system/xbin/telnet -> busybox
Symlink: out/target/product/mako/system/xbin/test -> busybox
Symlink: out/target/product/mako/system/xbin/telnetd -> busybox
Symlink: out/target/product/mako/system/xbin/tftp -> busybox
Symlink: out/target/product/mako/system/xbin/tftpd -> busybox
Symlink: out/target/product/mako/system/xbin/time -> busybox
Symlink: out/target/product/mako/system/xbin/timeout -> busybox
Symlink: out/target/product/mako/system/xbin/top -> busybox
Symlink: out/target/product/mako/system/xbin/touch -> busybox
Symlink: out/target/product/mako/system/xbin/tr -> busybox
Symlink: out/target/product/mako/system/xbin/traceroute -> busybox
Symlink: out/target/product/mako/system/xbin/true -> busybox
Symlink: out/target/product/mako/system/xbin/ttysize -> busybox
Symlink: out/target/product/mako/system/xbin/tune2fs -> busybox
Symlink: out/target/product/mako/system/xbin/umount -> busybox
Symlink: out/target/product/mako/system/xbin/uname -> busybox
Symlink: out/target/product/mako/system/xbin/uncompress -> busybox
Symlink: out/target/product/mako/system/xbin/unexpand -> busybox
Symlink: out/target/product/mako/system/xbin/uniq -> busybox
Symlink: out/target/product/mako/system/xbin/unix2dos -> busybox
Symlink: out/target/product/mako/system/xbin/unlzma -> busybox
Symlink: out/target/product/mako/system/xbin/unlzop -> busybox
Symlink: out/target/product/mako/system/xbin/unxz -> busybox
Symlink: out/target/product/mako/system/xbin/unzip -> busybox
Symlink: out/target/product/mako/system/xbin/uptime -> busybox
Symlink: out/target/product/mako/system/xbin/usleep -> busybox
Symlink: out/target/product/mako/system/xbin/uudecode -> busybox
Symlink: out/target/product/mako/system/xbin/uuencode -> busybox
Symlink: out/target/product/mako/system/xbin/vi -> busybox
Symlink: out/target/product/mako/system/xbin/watch -> busybox
Symlink: out/target/product/mako/system/xbin/wc -> busybox
Symlink: out/target/product/mako/system/xbin/wget -> busybox
Symlink: out/target/product/mako/system/xbin/which -> busybox
Symlink: out/target/product/mako/system/xbin/whoami -> busybox
Symlink: out/target/product/mako/system/xbin/xargs -> busybox
Symlink: out/target/product/mako/system/xbin/xz -> busybox
Symlink: out/target/product/mako/system/xbin/xzcat -> busybox
Symlink: out/target/product/mako/system/xbin/yes -> busybox
Symlink: out/target/product/mako/system/xbin/zcat -> busybox
target Symbolic: bash (out/target/product/mako/symbols/system/xbin/bash)
target Strip: nano (out/target/product/mako/obj/EXECUTABLES/nano_intermediates/nano)
Install: out/target/product/mako/system/xbin/nano
target Strip: bash (out/target/product/mako/obj/EXECUTABLES/bash_intermediates/bash)
Install: external/nano/etc/asm.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/awk.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/c.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/cmake.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/css.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/fortran.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/groff.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/html.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/java.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/makefile.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/nanorc.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/objc.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/ocaml.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/patch.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/perl.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/php.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/python.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/ruby.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/sh.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/tcl.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/tex.nanorc -> out/target/product/mako/system/etc/nano/
Install: external/nano/etc/xml.nanorc -> out/target/product/mako/system/etc/nano/
Install: out/target/product/mako/system/xbin/bash
Install: external/bash/etc/bash_logout -> out/target/product/mako/system/etc/bash/
Install: external/bash/etc/bashrc -> out/target/product/mako/system/etc/bash/
build/tools/generate-notice-files.py out/target/product/mako/obj/NOTICE.txt out/target/product/mako/obj/NOTICE.html "Notices for files contained in the filesystem images in this directory:" out/target/product/mako/obj/NOTICE_FILES/src
Combining NOTICE files into HTML
Combining NOTICE files into text
Installed file list: out/target/product/mako/installed-files.txt
Target system fs image: out/target/product/mako/obj/PACKAGING/systemimage_intermediates/system.img
Running: mkuserimg.sh -s out/target/product/mako/system out/target/product/mako/obj/PACKAGING/systemimage_intermediates/system.img ext4 system 880803840 out/target/product/mako/root/file_contexts
+ echo 'in mkuserimg.sh PATH=out/host/linux-x86/bin/:/usr/lib/jvm/java-6-sun/bin:/home/mv/Dokumente/Projekt/AOSP-4.4/Projekt/out/host/linux-x86/bin:/home/mv/Dokumente/Projekt/AOSP-4.4/Projekt/prebuilts/gcc/linux-x86/arm/arm-linux-androideabi-4.7/bin:/home/mv/Dokumente/Projekt/AOSP-4.4/Projekt/prebuilts/gcc/linux-x86/arm/arm-eabi-4.7/bin:/home/mv/Dokumente/Projekt/AOSP-4.4/Projekt/prebuilts/gcc/linux-x86/mips/mipsel-linux-android-4.7/bin:/home/mv/Dokumente/Projekt/AOSP-4.4/Projekt/development/emulator/qtools:/home/mv/Dokumente/Projekt/AOSP-4.4/Projekt/prebuilts/gcc/linux-x86/arm/arm-linux-androideabi-4.7/bin:/home/mv/Dokumente/Projekt/AOSP-4.4/Projekt/prebuilts/gcc/linux-x86/arm/arm-eabi-4.7/bin:/home/mv/Dokumente/Projekt/AOSP-4.4/Projekt/development/scripts:/home/mv/Dokumente/Projekt/AOSP-4.4/Projekt/prebuilts/devtools/tools:/home/mv/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/home/mv/android-sdk-linux/platform-tools:/home/mv/android-sdk-linux/tools:/home/mv/android-sdk-linux/APK-Multi-Tool/other:/home/mv/bin:/usr/lib/jvm/java-6-oracle/bin'
+ ENABLE_SPARSE_IMAGE=
+ '[' -s = -s ']'
+ ENABLE_SPARSE_IMAGE=-s
+ shift
+ '[' 6 -ne 5 -a 6 -ne 6 ']'
+ SRC_DIR=out/target/product/mako/system
+ '[' '!' -d out/target/product/mako/system ']'
+ OUTPUT_FILE=out/target/product/mako/obj/PACKAGING/systemimage_intermediates/system.img
+ EXT_VARIANT=ext4
+ MOUNT_POINT=system
+ SIZE=880803840
+ FC=out/target/product/mako/root/file_contexts
+ case $EXT_VARIANT in
+ '[' -z system ']'
+ '[' -z 880803840 ']'
+ '[' -n out/target/product/mako/root/file_contexts ']'
+ FCOPT='-S out/target/product/mako/root/file_contexts'
+ MAKE_EXT4FS_CMD='make_ext4fs -s -S out/target/product/mako/root/file_contexts -l 880803840 -a system out/target/product/mako/obj/PACKAGING/systemimage_intermediates/system.img out/target/product/mako/system'
+ echo make_ext4fs -s -S out/target/product/mako/root/file_contexts -l 880803840 -a system out/target/product/mako/obj/PACKAGING/systemimage_intermediates/system.img out/target/product/mako/system
+ make_ext4fs -s -S out/target/product/mako/root/file_contexts -l 880803840 -a system out/target/product/mako/obj/PACKAGING/systemimage_intermediates/system.img out/target/product/mako/system
Creating filesystem with parameters:
Block size: 4096
Blocks per group: 32768
Inodes per group: 7680
Inode size: 256
Journal blocks: 3360
Label:
Blocks: 215040
Block groups: 7
Reserved block group size: 55
Created filesystem with 1502/53760 inodes and 62913/215040 blocks
+ '[' 0 -ne 0 ']'
Install system fs image: out/target/product/mako/system.img
out/target/product/mako/system.img+out/target/product/mako/obj/PACKAGING/recovery_patch_intermediates/recovery_from_boot.p maxsize=899137536 blocksize=135168 total=245639705 reserve=9191424
Package target files: out/target/product/mako/obj/PACKAGING/target_files_intermediates/aosp_mako-target_files-eng.mv.zip
Package OTA: out/target/product/mako/aosp_mako_mv-ota-eng.mv-20131126.zip
unzipping target target-files...
running: unzip -o -q out/target/product/mako/obj/PACKAGING/target_files_intermediates/aosp_mako-target_files-eng.mv.zip -d /tmp/targetfiles-ZKxivC
--- target info ---
blocksize = (int) 131072
boot_size = (int) 23068672
build.prop = (dict) {'dalvik.vm.heapsize': '512m', 'ro.build.display.id': 'aosp_mako-userdebug 4.4 KRT16S eng.mv.20131126.102730 test-keys', 'ro.wifi.channels': '', 'persist.audio.handset.mic': 'dmic', 'ro.setupwizard.enterprise_mode': '1', 'persist.audio.fluence.mode': 'endfire', 'ro.build.characteristics': 'nosdcard', 'ro.config.ringtone': 'analog_3.ogg', 'ro.url.legal': 'http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html', 'dalvik.vm.heaptargetutilization': '0.75', 'ro.build.product': 'mako', 'wifi.supplicant_scan_interval': '15', 'persist.audio.fluence.voicecall': 'true', 'ro.build.host': 'mv-Aspire-5755G', 'ro.product.name': 'occam', 'ro.com.android.dataroaming': 'false', 'ro.build.id': 'KRT16S', 'telephony.lteOnCdmaDevice': '0', 'keyguard.no_require_sim': 'true', 'persist.hwc.mdpcomp.enable': 'true', 'ro.carrier': 'unknown', 'persist.sys.dalvik.vm.lib': 'libdvm.so', 'ro.build.version.incremental': 'eng.mv.20131126.102730', 'ro.product.board': 'MAKO', 'ro.com.google.clientidbase': 'android-google', 'ro.build.tags': 'test-keys', 'persist.audio.dualmic.config': 'endfire', 'ro.qc.sensors.wl_dis': 'true', 'ro.sf.lcd_density': '320', 'ro.build.version.sdk': '19', 'ro.build.date': 'Di 26. Nov 10:28:22 CET 2013', 'ro.com.android.dateformat': 'MM-dd-yyyy', 'persist.audio.lowlatency.rec': 'false', 'dalvik.vm.heapmaxfree': '8m', 'ro.board.platform': 'msm8960', 'dalvik.vm.stack-trace-file': '/data/anr/traces.txt', 'ro.telephony.call_ring.multiple': '0', 'ro.build.fingerprint': 'google/occam/mako:4.4/KRT16O/907817:user/release-keys', 'ro.build.date.utc': '1385458102', 'ro.product.cpu.abi2': 'armeabi', 'ro.product.manufacturer': 'LGE', 'dalvik.vm.heapminfree': '2m', 'ro.build.user': 'mv', 'ro.product.locale.language': 'de', 'ro.qualcomm.bt.hci_transport': 'smd', 'ro.qualcomm.sensors.smd': 'true', 'drm.service.enabled': 'true', 'ro.product.device': 'mako', 'dalvik.vm.lockprof.threshold': '500', 'ro.build.description': 'occam-user 4.4 KRT16O 907817 release-keys', 'dalvik.vm.dexopt-flags': 'm=y', 'dalvik.vm.heapgrowthlimit': '192m', 'ro.product.locale.region': 'DE', 'ro.product.cpu.abi': 'armeabi-v7a', 'ro.product.brand': 'google', 'wifi.interface': 'wlan0', 'ro.build.version.release': '4.4', 'debug.egl.recordable.rgba8888': '1', 'ro.build.version.codename': 'REL', 'ro.com.android.wifi-watchlist': 'GoogleGuest', 'persist.audio.handset.mic.type': 'digital', 'persist.radio.apm_sim_not_pwdn': '1', 'ro.url.legal.android_privacy': 'http://www.google.com/intl/%s/mobile/android/basic/privacy.html', 'ro.build.type': 'userdebug', 'ro.product.model': 'Nexus 4', 'ro.config.alarm_alert': 'Alarm_Classic.ogg', 'ro.opengles.version': '196608', 'ro.config.notification_sound': 'Shaula.ogg', 'net.bt.name': 'Android', 'dalvik.vm.heapstartsize': '8m', 'media.aac_51_output_enabled': 'true', 'af.resampler.quality': '4'}
default_system_dev_certificate = (str) build/target/product/security/testkey
extfs_sparse_flag = (str) -s
fs_type = (str) ext4
fstab = (dict) {'/radio': <common.Partition object at 0xec0b90>, '/cache': <common.Partition object at 0xec0910>, '/data': <common.Partition object at 0xec0950>, '/system': <common.Partition object at 0xec08d0>, '/aboot': <common.Partition object at 0xec0d10>, '/rpm': <common.Partition object at 0xec0cd0>, '/persist': <common.Partition object at 0xec0a50>, '/tz': <common.Partition object at 0xec0c90>, '/recovery': <common.Partition object at 0xec0b10>, '/firmware': <common.Partition object at 0xec0a90>, '/sbl1': <common.Partition object at 0xec0bd0>, '/sbl3': <common.Partition object at 0xec0c50>, '/sbl2': <common.Partition object at 0xec0c10>, '/boot': <common.Partition object at 0xec0ad0>, '/misc': <common.Partition object at 0xec0b50>}
fstab_version = (int) 2
mkbootimg_args = (str) --ramdisk_offset 0x01600000
recovery_api_version = (int) 3
recovery_size = (int) 23068672
selinux_fc = (str) /tmp/targetfiles-ZKxivC/BOOT/RAMDISK/file_contexts
system_size = (int) 880803840
tool_extensions = (str) device/lge/mako
use_set_metadata = (str) 1
userdata_size = (int) 6189744128
using device-specific extensions in device/lge/mako
building image from target_files BOOT...
running: mkbootfs -f /tmp/targetfiles-ZKxivC/META/boot_filesystem_config.txt /tmp/targetfiles-ZKxivC/BOOT/RAMDISK
running: minigzip
running: mkbootimg --kernel /tmp/targetfiles-ZKxivC/BOOT/kernel --cmdline console=ttyHSL0,115200,n8 androidboot.hardware=mako lpj=67677 user_debug=31 --base 0x80200000 --pagesize 2048 --ramdisk_offset 0x01600000 --ramdisk /tmp/tmpQiOLoy --output /tmp/tmpogrUtL
boot size (6518784) is 28.26% of limit (23068672)
no bootloader.img in target_files; skipping install
no radio.img in target_files; skipping install
running: openssl pkcs8 -in build/target/product/security/testkey.pk8 -inform DER -nocrypt
running: java -Xmx2048m -jar out/host/linux-x86/framework/signapk.jar -w build/target/product/security/testkey.x509.pem build/target/product/security/testkey.pk8 /tmp/tmpdiW1A9 out/target/product/mako/aosp_mako_mv-ota-eng.mv-20131126.zip
done.
Build completed in 3 minute(s) and 47 seconds.
von daher würde ich sagen mpdecision wird nicht "mitgebaut", keine ahnung warum, musst mal schaun (hab auch keine ahnung ob mpdecision beim n7 mit rein soll oder nicht, hab keins, denke aber schon).
achja die Änderung kannst (oder solltest bzw. musst mal schaun ob in full-flo was drin ist was du brauchst, denke schon) du wieder rausnehmen, in device/asus/flo/full_flo.mk ist ja $(call inherit-product-if-exists, vendor/asus/flo/flo-vendor.mk)
DerOhneNick
DerOhneNick
DerOhneNick
nudels
nudels
nudels
MB526
MB526
