Spo0cky ^^
Stop stop
Mach lieber wie berlino sagte, ist sicherer, bevor noch was schlimmes passiert, mir das mit dem patch nicht bewusst.Spo0cky ^^ schrieb:Stop stop
Das war ja meine Frage. Aber im Internet gibs nur die V30CBerlino schrieb:Dann braucht er also doch den Patch...allerdings für die 30J!
kein F kein J.Version 86:
- More compatiblity with ROMs that use a Resources subclass for e.g. theming, like most Huawei stock ROMs (*)
- Incorrectly compiled modules are now rejected, the warning which started to appear with v84 is now an error
- A bit of general cleanup and minor fixes
(*) In the Xposed logs, it would usually say "XyzResources doesn't extend XResources" in such cases.
If you had to select "Disable resource hooks" in Xposed Installer in the past, it's now worth to try again without this workaround.
On Huawei devices, Xposed should now work with and without their theming engine enabled.
Next step (planned for the next version): Official systemless Xposed for Marshmallow. I have already started working on that, but I don't have much time and making something robust takes a while.
Note that the systemless installation will require SuperSU 2.76 or higher. That might be considered a disadvantage compared to the unofficial versions, however I think that it's the better way. @Chainfire put a lot of effort into developing and testing a solution that works reliably on virtually every device. Whenever new devices and Android versions pop up, he's fast at making SuperSU compatible. I think it totally makes sense to build upon those achievements instead of maintaining a fork of them or even reinventing the wheel, which could in the worst case even cause conflicts. I'll rather spend that time focusing on Xposed development itself, not on dealing with all kinds of different bootloaders etc.
Schussel schrieb:Motorola X Play (XT 1562)
Soweit ich weiß, ist der Snapdragen 615 ein 64bit-Prozessor. Du müsstest also die zip flashen -> http://dl-xda.xposed.info/framework/sdk23/arm64/xposed-v86-sdk23-arm64.zipSchussel schrieb:Geflasht ist XPosed_v86_sdk23_arm.zip
