streifenleopard
Stamm-User
- 42
ich verstehe die u.g. Anleitung nicht. Die ist aus dem Tingle Android Patcher. [TOOL] Tingle - Android patcher
Vor allem verstehe ich nicht, wie ich `python main.py` ausführen soll.
How to use
1. Make sure `Developer options` is enabled. This is hidden by default since sometime in Android 4.x, you can show it by going to `About phone` and tapping on the `Build number` 7 times in succession.
2. In the developer settings, find the setting for `Android debugging` and enable it.
3. Find the setting for `Root access` and make sure ADB has root access.
4. Connect your device via USB.
5. Now, on the computer, run `python main.py` (or `python3 main.py`).
6. Select the option 1 to allow the patcher to do everything automatically.
7. Reboot the device.
How to use
