[ROM] CyanogenMod 10 (für Elf II, Aurora II, Crystal & Fire)
  • 143 Antworten
id.goPLAY
id.goPLAY
CyanogenMod 10 (JB 4.1.2) für Elf II, Aurora II, Crystal & Fire
Features
  • UbiFS (like stock roms)
  • Bluetooth USB dongle Unterstützung
  • USB GPS Unterstützung (cp210x and pl2303)
  • Xbox 360 gamepad Unterstützung (xpad)
  • PS3 USB gamepad Unterstützung (hid-sony)
  • Generic/Chinese (Pantherlord/GreenAsia) gamepads Unterstützung (hid-pl and hid-gaff)
  • OpenVPN Unterstützung (tun)
  • Veno Regelalgorithmus
Installationsanweisungen
Vor dem Flashen der CM10 ROMs, "wipe media partition" mit Stock Recovery ausführen und dann die Anleitung befolgen:
  1. Entpacke die CWM ZIP datei auf die externe SD card
  2. Kopiere CM10, GAPPS and A2-compatibility.zip auf deine externe SD card
  3. Gehe in CWM recovery modus (drücke Power und Volume -)
  4. Mache einen Wipe Data/Factory reset
  5. Gehe zu Install zip from SD card und instaliere erst die CM10 ROM datei
  6. Als zweites die GApps-JB-XXXXXXXX-signed-ubifs.zip
  7. Und am ende die Compatibility.zip datei
  8. Restart
Download
Compatibility zip (Updated 2012-11-10)
Changelog 2012-11-17
  • Other minor stuff
  • Updated upstream sources
Changelog 2012-11-10
  • Added reboot to recovery (you must have flashed CWM to the NAND or it will boot to stock recovery)
  • Aurora-II / Elf-II: new compatibility zip (fixes stuck g sensor for people that had problems)
  • Other minor stuff
Changelog 2012-11-03
  • Fixed Netflix 2.x compatibility
  • Potential fix for the few games that were still having a choppy/stuttering audio
  • Aurora-II / Elf-II: fixed unresponsive WiFi when the screen was turned off
  • Other minor stuff
Changelog 2012-10-28
  • Updated compatibility zips for Elf, Aurora and Crystal
  • Re-inserted missing file that broke wifi
  • Increased amplayer buffer; flash videos using latest apk work decently and in hw mode. Sometimes you may not hear audio but toggling fullscreen mode will fix it.
  • Other minor stuff
Known bugs
  • Post to report
FAQs
  • I suggest you to change Trebuchet's rows/columns number to 4/5 to avoid launcher's FC.
  • Install a different launcher like apex, nova etc from google play.
Screenshot's
Reaktionen: Ghosu, dicker99, 1of16 und 3 andere
Hat schon jemand billig-USB Gamepads getestet? Habe keine Lust mir extra nen PS3/XBox COntroller zuzulegen.
hi,
ich habe vor mir ein fire zuzulegen und diese rom zu installieren...dort stehen 2 versionen (tm, qm), und dann noch die versionsnummer....funktioniert es also nur mit einem tm v1.2, und nicht mit einem tm v1.1? und wenn ja wie bekomme ich die versionsnummer, am besten noch vor dem kauf, heraus? Und läuft das auch auf dem flame (gibt es da einen unterschied zum fire)?
Kann ich die ELF2-ROMs auch für mein normales ELF benutzen?
EDIT:
Gibt übrigens ein Update von heute
hellobello schrieb:
Das wuerde in der 2012-10-28 version gefixt. Man braucht den WiFi Fix nicht mehr.
Der ursprüngliche Beitrag von 08:25 Uhr wurde um 08:29 Uhr ergänzt:
EDIT:
Glaube nicht, da Elf I SigneCore ist und Elf II DualCore... Guck mal hier.
Der ursprüngliche Beitrag von 08:29 Uhr wurde um 08:31 Uhr ergänzt:
First post update'd
2012-10-28
* Updated compatibility zips for Elf, Aurora and Crystal
* Re-inserted missing file that broke wifi
* Increased amplayer buffer; flash videos using latest apk work decently and in hw mode. Sometimes you may not hear audio but toggling fullscreen mode will fix it.
* Other minor stuff
* Updated upstream sources
Rom - Gapps (2012-10-11)
Compatibility zip
* ELF-II v1.3
* Aurora-II v2.4 (if you have troubles you can always use v1.3.1 as fallback)
* Crystal v1.5 (like Aurora's users, if you have troubles use v1.0 as fallback)
Reaktionen: Bundy
cannabis schrieb:
hi,
Die Roms sind mehr oder weniger universell, können daher auch nicht beliebig weit auf hardwareseitige Unterschiede zwischen den Tabletts eingehen, dafür gibt es nun mal individuelle Kernel (plus ein paar andere Dateien), die per "compatibility zip" verteilt werden.
Es gibt beim Fire (/Flame/Fuego/Burning) "nur" QM und TM - zwei verschiedene Screens, die auch verschiedene Treiber benötigen (und auf den falschen ziemlich allergisch reagieren, genauso wie auf den mit der Rom ausgelieferten Elf-II-Kernel!).
Welcher Screen verbaut ist, steht in der original installierten Rom (leider nirgendwo anders, AFAICT). Aufschreiben und merken.
Die Versionsnummern gehören zum Update - wenn in 1.1 noch irgendwelche Sachen nicht passen, dann kommt eben eine 1.2 raus usw.
Welche Updates zu welcher Rom passen, steht jeweils im Announcement - wenn dort die "compatibility zip" nicht aufgeführt ist, _muss_ man die letzte vor der Rom veröffentlichte nehmen (weil der Elf-II-Kernel nicht zur Fire-Hardware passt) und _vor_ dem Reboot installieren.
(Steht das nirgends?)
Reaktionen: id.goPLAY
das einzige was mich am rom stört ist das keine memory sticks funktionieren
hoffe das wird noch nachgebessert
ansonsten echt top
so kann ich mich doch noch freuen das fire gekauft zu haben
meinen post oben kann ich nicht mehr bearbeiten zwecks wifi fix
update
Ausrichtung des Sperrbildschirm funktioniert nicht richtig
Mann kann nur auf x grad einstellen beim Menue ....Display dann ist der Sperrbildschirm gleich mit dem TabletUi aber sobalt man merhre ausrichtungsmöglichkeiten aktiviert sind es immer 90 Grad
stört irgendwie
@hello: mal StickMount ausprobiert?
Reaktionen: hellobello
danke funktioniert
wäre aber schön wenn es ohne app funktionieren würde so wie bei den ainol roms
@steve8x8:
Das war mal so.
CT liefert inzwischen das Rom komplett ohne Kernel aus und auch Elf II Besitzer müssen jetzt eine Compatibility Zip installieren.
Hallo zusammen habe vor kurzem mein Aurora II erhalten und möchte CM 10 drauf machen, habe zwar Ahnung von PC und Software (meine jetzt nicht MS office :laugh:) aber Android ist Neuland für mich. Daher brauche ich Eure Hilfe, wie in der Anleitung geschrieben muss ich erstmal Stock Recovery draufmachen, was ist das und wo bekomme ich es, Android markt? Habe alle anderen benötigen Dateien bereits auf dem PC gespeichert und war auch schon im Installationsmodus nur hat mir eben die Option Install from SD card gefehlt vermutlich weil ich das Stock recovery nicht drauf hab :angry:
Das Tablet is jetzt im Auslieferungszustand
Bin dankbar für alle Tipps, und sorry falls in das Forum nicht durchsucht habe wahrscheinlich steht es schon drin aber ich gehöre zu den ungeduldigen bei denen alles schnell gehen muss :D
THX und Gruß
Der ursprüngliche Beitrag von 18:57 Uhr wurde um 20:15 Uhr ergänzt:
Problem hat sich gelöst habs alleine hinbekommen
@hellobello Schon mal einen Stick mit mehreren Partitionen an ein "automount"endes Gerät angehängt? Den kann das System nicht ordentlich wieder unmounten (nur die "letzte" Partition, der Rest bleibt eingehängt, muss man zu Fuß im Terminal aushängen).
Da ist mir StickMount viel lieber.
Mit meinem Flambe habe ich den Ärger. Leider steckt diese Funktionalität in der initramdisk, an die ich bisher noch nicht rankomme.
Bei mir ging der GApps20121011.zip nich, er sagte immer install aborted.
Ich dachte, da wäre die ZIP defekt runtergeladen, aber selbst nach 2 mal neu runterladen hat es immernoch nich gefunzt.
Allerdings hab ich hier eine funktionierende GApps20121011.zip gefunden:
Goo.im Downloads - Downloading gapps-jb-20121011-signed.zip.
Nu sagt er Install completed, aber mein GMail is immernoch nich da, weiss jemand, wie ich das wiederbekommen kann?
Danke!
Danke!
Instaliere GMail via PlayStore (in Gapps ist GMail nicht dabai, wie aucg Maps, Youtube usw.) Alles was dir fehlt findest du auf Google Play Store
Der ursprüngliche Beitrag von 10:09 Uhr wurde um 10:12 Uhr ergänzt:
Updated 1st post
Rom Build 31-10-2012
1st post updated
2012-11-03
* Fixed Netflix 2.x compatibility
* Potential fix for the few games that were still having a choppy/stuttering audio
* Aurora-II / Elf-II: fixed unresponsive WiFi when the screen was turned off
* Other minor stuff
Download Rom (2012-11-03)
Reaktionen: AsusFreak
Habe mein nagelneues Crystal gleich auf CM10 vom 3.11. umgestellt.
Bislang konnte ich noch keinen Fehler feststellen.
Stabil, flüssig, keine App-Hänger.
Ich komme vom Odys Xelio und hatte dort kernel-bedingt Probleme mit Christian Troy's CM10 - 2-Sekunden-Hänger beim Beenden der Apps. Hier tritt das gar nicht auf - super!
@Asus das ist das gleiche
Schade Bluetooth audio hat noch Hänger
Achja die Display Sperre Ausrichtung funktioniert man das bei Display Ausrichtung anhackt
Da ist definitiv das stabilste und fluessigste ROM von allem.
Habe auch NFS Most Wanted zum laufen gebracht und zwar lagfrei.
Laeuft super! :thumbup:
THX und Gruß
Mein Aurora 2 sollte morgen kommen. Kannst du mir bitte nochmal kurz schreiben, wie es klappt? Ich habe das auf meinem Tornado nämlich nicht hinbekommen :/
steve8x8
dajo77
dajo77
