![MistaBreed](/data/avatars/s/196/196490.jpg,q1569149551.pagespeed.ce.fNrBLY6zij.jpg)
MistaBreed
id.goPLAY schrieb:CyanogenMod 10 (JB 4.1.2) für Elf II, Aurora II, Crystal & Fire
Features
- UbiFS (like stock roms)
- Bluetooth USB dongle Unterstützung
- USB GPS Unterstützung (cp210x and pl2303)
- Xbox 360 gamepad Unterstützung (xpad)
- PS3 USB gamepad Unterstützung (hid-sony)
- Generic/Chinese (Pantherlord/GreenAsia) gamepads Unterstützung (hid-pl and hid-gaff)
- OpenVPN Unterstützung (tun)
- Veno Regelalgorithmus
Installationsanweisungen
Vor dem Flashen der CM10 ROMs, "wipe media partition" mit Stock Recovery ausführen und dann die Anleitung befolgen:
- Extract and Copy CWM to external SD card
- Copy CM10, GAPPS and A2-compatibility.zip to the internal/external SD card
- Reboot the tablet in CWM recovery mode (Hold Power and Volume -)
- Select Wipe Data/Factory reset and confirm the delete
- Choose Install zip from SD card and select choose zip from SD card, now select CM10 ROM first
- Next select GAPPS.zip
- Lastly select A2-compatibility.zip (You can then apply any patches if available)
- Reboot the tablet
Download
Compatibility zip (Updated 2012-11-10)
- ELF-II v1.4
- Aurora-II v2.5 (if you have troubles you can always use v1.3.1 as fallback)
- Crystal v1.5 (like Aurora's users, if you have troubles use v1.0 as fallback)
- Fire TM v1.2 - CWM v5.5.0.4
- Fire QM v1.3 - CWM v5.5.0.4
Changelog 2012-11-10
- Added reboot to recovery (you must have flashed CWM to the NAND or it will boot to stock recovery)
- Aurora-II / Elf-II: new compatibility zip (fixes stuck g sensor for people that had problems)
- Other minor stuff
- Updated upstream sources
Changelog 2012-11-03
- Fixed Netflix 2.x compatibility
- Potential fix for the few games that were still having a choppy/stuttering audio
- Aurora-II / Elf-II: fixed unresponsive WiFi when the screen was turned off
- Other minor stuff
Changelog 2012-10-28
- Updated compatibility zips for Elf, Aurora and Crystal
- Re-inserted missing file that broke wifi
- Increased amplayer buffer; flash videos using latest apk work decently and in hw mode. Sometimes you may not hear audio but toggling fullscreen mode will fix it.
- Other minor stuff
Wo kann ich denn die GApps von der 28.10.2012er Version herbekommen?
Hat die noch wer?
Danke schonmal für eure Mühe...
