![LouCipher](/data/avatars/s/65/65467.jpg,q1569149551.pagespeed.ce.czNCLVoC3c.jpg)
LouCipher
Ehrenmitglied
- 1.991
Original-Thread von Slatedroid.com
Verwenden auf eigene Gefahr.
Downloads:
sun4i crane scheint der Codename für "allwinner's A10" zu sein.
Außer dass es sich um die Original-Firmware handelt, konnte ich nichts in Erfahrung bringen
sun4i_crane_nov...c-a3-201-10.zip
USB-Treiber
USB-Treiber2
Übersetzung folgt
If Device not found error appear while installing the FullMarket Script.
Power-ON your Tablet > Go to System Settings > Developers Option.
Enable USB Debuging & Stay Awake. Connect Tablet to PC.
Open Device Manager and right-Click Android Device.
Install driver manually and Choose Downloaded Driver location.
1. Check the current baseband/firmware installed. Go to Menu > Settings > About Device.
Turn-On Tablet, go to System Settings > Developers Option.
Turn-ON USB Debugging & Stay Awake.
2. Connect the Tablet to PC and double-click DPInst to install the required USB Driver for your OS.
3. After installation, disconnect your Tablet to PC and Turn it OFF.
4. Extract the Livesuit Pack into a folder on your PC. Place the Firmware .img file inside the Livesuit Pack folder and double-click Livesuit.exe:
1st pop-up window click YES.
2nd pop-up window click FORMAT.
3rd pop-up window click NEXT.
4th pop-up window click YES.
5th pop-up window locate your selected FW image file and click OPEN.
6th pop-up window click FINISH.
5. On your Tablet, press and hold the Menu Button (-Volume Button) and connect the Tablet to PC.
6. As soon as you connect the USB Cable to PC, rapidly press the Power button 5 times without releasing the Menu Button (-Volume Button).
7th pop-up window click: (YES = Upgrade/Downgrade) (NO = Re-Flash to same Firmware)
8th pop-up window click: (YES = Upgrade/Downgrade)
7. You can now release the Menu button (-Volume Button) and wait for the upgrading to get finished.
9th pop-up window click FINISH or OK.
After Finishing Firmware Upgrading:
1. Disconnect the tablet to PC and Power-ON your Tablet.
2. Go to System Settings scroll down upto bottom and locate the [A] icon to change the Language.
3. Touch the very 1st option and choose English (US).
4. Go to System Settings > Developers Option > Turn-ON USB Debugging & Stay Awake.
5. Go to System Settings > Display >Sleep and set it to 2mins above.
6. Go To Settings > Sound and set Vibrate to Never and Disable Vibrate on Touch.
7. Reboot your Tablet.
IF Firmware Upgrading Fails, just press Power button for 30seconds and do the Firmware Upgrading again.
Downloads:
USB-Treiber
USB-Treiber2
Übersetzung folgt
