Chainfire 3D problem
  • 6 Antworten
superbg
Hallo, installiert i Chainfire 3D auf meinem A211 und dann versucht, die Treiber zu installieren. Nach der Installation von ihnen, Tablet neu gestartet, und stecken auf Acer-Logo manchmal vibriert und Wiederholungen (es heißt loop-Boot). Irgendwelche Vorschläge?
Sorry for bad German i used Google Translator.
English:
Please use english, but dont use Google-Translater. Most Developers can understand english, but no one can understand the crap of Google-Translate...
Chainfire 3D is for Froyo and Gingerbread, neither for ICS nor for JB:
See here:
https://play.google.com/store/apps/details?id=eu.chainfire.cf3d&hl=de
Playstore schrieb:
!! For Froyo and Gingerbread ONLY. NOT COMPATIBLE with Honeycomb/Ice Cream Sandwich/Jelly Bean !!
Do you have a CWM Backup or can you reinstall a (Custom)ROM?
Deutsch:
Chainfire 3D ist für Froyo und Gingerbread, weder für ICS noch für JB:
Sieh hier:
Hast Du ein CWM Backup oder kannst Du ein (Custom)ROM installieren?
Kind regards/Grüsse
Uwe
No i dont have CWM backup but i can reboot in cwm recovery i was with stock rom when i installed CF3D. I downloaded lighting barebone but i cant understand how to flash it. I read in xda (i think) that if i flash new ROM it may fix. I'm looking at your kernel now (Kiwi++) if i flash it will i fix it?
EDIT: First i posted it in English but my post was deleted. And I received a message to post new topics in German(and to use Google Translate if I dont know German)
English:
I dont think flashing an alternativ Kernel might fix it, because i think that the problem is caused by writing additional, incompatilbe drivers into /system/...
Therefore only flashing something like a CustomROM or the original StockROM will help, as those ROM remove anything from the /system partition before the install their own stuff.
Flashing my kernel will only add things to the existing /system partition and not remove anything (like incompatible drivers).
What is your problem in flashing LB-ROM? Maybe I can help with that.
Deutsch:
Ich glaube nicht, dass einen alternativen Kernel zu flashen das Problem lösst, denn ich denke das Problem wurde durch installation incompatibler Treiber nach /system verursacht.
Daher ist die einzige Lösung, ein CustomROM oder das original StockROM zu installieren, denn diese ROM löschen alles aus der /system Partition bevor sie ihre eigenen Dateien installieren.
Meinen Kernel zu flashfügt nur Dateien zur existierenden /system Partition aber löscht nichts (wie z.B inkompatible Treiber).
Was ist Dein Problem, LB-ROM zu flashen? Vielleicht kann ich helfen?
regards / Grüsse Uwe
English:
After downloading the LB-ROM zip, you must copy it onto your external SD-Card (as your tablet does not boot, you must remove the SD-Card from tablet and use an adapter for your PC to copy it from PC to SD-Card.
In CWM, you must choose:
  • Install zip from SD
  • Select zip from external SD
  • LightningBareboneROM1.74.zip
To the download: There seems be an issue with the Download-Server.
I hope, this will be fixed soon.
Deutsch:
Nach dem downloaden der LB-ROM zip, muss die auf die external SD-Card kopiert werden (da Dein tablet nicht bootet,musst Du die SD-Karte aus dem Tablet rausnehmen und einen Adapter für Deinen PC nehmen, um vom PC auf die SD-Karte zu kopieren.
Im CWM auswählen:
Zum Download: Das scheint ein Problem mit dem Server zu sein, hoffe es ist bald gefixt...
Thanks, it worked.
But with LB Rom i think the acer ring doesn't work.
EDIT: Fixed acer ring by downloading its app from Google play and then just edited it from the settings
fischony
  • fischony
fischony
fischony
  • mikki2
Ladylike871
Ladylike871
  • shinzon
shinzon
