[APK] Zooper Widget (Free/Pro/Skins) | Beschreibung, Tips, Tricks, Fragen zur Technik
  • 3.177 Antworten
SavanTorian
SavanTorian
Ehrenmitglied
6.490
Werte Fangemeinde,
zu UCCW und den bisherigen HomescreenTuning Apps würde ich gerne Zooper hinzufügen. Es ist, wie UCCW eine Customizing App, die keinerlei Wünsche offenlässt... Ich möchte dafür nicht werben, habe aber schon selber gebastelt und bin auch sehr zufrieden. :)
Minimal, classy, extremely customizable and battery friendly "do it yourself" Widget with almost limitless possibilities!If you like the software and want to support the development please rate it! If you have issues or requests send me an email or use the forum at http://zooper.org/wp/forums/
KNOWN ISSUES
- GALAXY S2 http://zooper.org/wp/archives/1457
- GALAXY S4 http://zooper.org/wp/archives/3503
FREE FEATURES
- Sample templates included, no need to download anything else
- Some custom fonts already included, additional can be added on sdcard/fonts
- Create your templates easily, no functional limit, tons of variables and controls
- WYSIWYG editor with layers like Photoshop / Gimp
- Build your style and change everything, color, text, shapes, position and more
- Completely customizable date and time (day of the year, week number, number to text...)
- Date calculations (countdown, time to or from any date, calendar event or system attribute)
- Full Math expressions supported (like Star Trek stardate)
- Battery info (remaining time, percentage, temperature, voltage)
- World clock (multiple timezones on the same widget)
- Weather for current or multiple locations on the same widget
- Up to 5 days forecast from multiple providers (Open Weather Map, YR.NO)
- Calendar info with free customization
- System info, like uptime, next alarm, SD card space
- WiFi network name, cell operator, signal strenght, connection type
- Network traffic data stats for current day, week, month and more
- Sunrise, Sunset and Astrological Nautical or Civil twilight
- Moon Rise, Set and Illumination percentage
- Series for days, months and more
- Completely dynamical and customizable TTF and PNG iconsets
- Static Bitmaps (PNG with alpha and JPG)
- Progress Bars customizable with any numeric variable as min/max and value
- Tasker integration (see website)
- Jelly Bean lock screen support
PRO ONLY
- No Ads
- Widget on tap action / config lock (and "module" click action)
- Load and Save templates on SD card
- Buzz launcher support
BATTERY
Zooper Widget has been built from ground up with battery in mind, nothing will be done while your phone sleeps, no weather will be updated if you have no weather information on screen, no location will be updated if you do not ask to.
MEMORY
Zooper Widget does not use much memory when it's running, even with 10 widgets on your screen it won't grow more than 10 megabytes. During configuration however RAM usage can grow even to 25mb, this is normal and the space will be released some time after config is closed. If you're using Bitmaps, off course, due to heavy caching, usage will be higher.
WEBSITE: http://zooper.org/wp/android/zw/
SUPPORT: http://zooper.org/wp/forums/
TRANSLATIONS: http://www.getlocalization.com/zooperwidget/
PERMISSIONS: http://zooper.org/wp/android/zw/permissions
TASKER: http://zooper.org/wp/android/zw/tasker
ICONSETS: http://zooper.org/wp/android/zw/iconsets
BETA (PRO): http://goo.gl/DXoig
SIMILAR TOOLS
- Advanced Clock Widget
- Minimalistic Text
- Beautiful Widgets
- SiMi Clock Widget
- TypoClock
- Clockr
- BattStatt
- Ultimate custom clock (UCCW)
- Make Your Clock Widget
- Dashclock
- Buzz Custom Widget
SUPPORTED LANGUAGES: English, Chinese (Traditional), Czech, Danish, Dutch, French, German, Greek, Italian, Norwegian, Polish, Portuguese (Brazil), Russian, Slovak, Spanish, Japanese, Hebrew, Bulgarian, Korean
OtSe8q271IcJ3Ixw8F61dpQajP4I1yj_9v-RSKebjilmelHFsj1MUKcQlC1jN7Mx6iM
A8MSKwKPQDZxPmFF6qB57c-nBS2m2eB9peH_nvMadMf44A_-sO4382fct7K7Mg3vvQE
2-_5I1stiLhwvXtmtbWqHsf36S6cBz5ZGEKsa_SaARCRynKgqa_M3d6gUT-PtiW-lr4
Man findet alles auf Playstore oder auf Zooper.org.
Übersetzungen
G+ Gallery
XDA Themes
usw...
Advanced Topics
Wer Lust hat, kann sich zum testen und einarbeiten, auch in der Community umschauen. :)
Einige werden es schon kennen, hier mal mein Screenshot mit Zooper. (etwas erweitert, sgs III).. Es ist auch möglich, komplette Homescreens, Lockscreen etc zu bauen.
*.zw Dateien gerne auf Anfrage.
Gruss, ST
Der Thread kann zukünftig auch für Anfragen, Tricks, Problemchen, Gestaltung etc. pp verwendet werden. Zusammen mit Rattar sollte das eine gute Gemeinschaft bilden :)
Ein weitere Thread gibt's für Zooper Skins von Rashiel, Fragen dazu auch hier :)
Reaktionen: Steveria, Wolkenseestern, Sky und 4 andere
Ich sehe keine Vorschaubilder mehr der gespeicherten Templates.....
hat das Problem noch jemand?
Das habe ich auch Ronny, aber auch, daß die gespeicherten Widgets nicht mehr geladen werden .... auch nach reboot nicht und auch nicht, wenn ich einen Teil entferne oder hinzufüge ...
Ist mit mehreren Roms so
Dort steht immer nur inn kleiner Schrift: "lade zw..."
Weiß jemand Rat??
Nutze v2.32
Bei mir funktioniert alles, bin jedoch im Beta Programm und habe die Version 2.39 bzw genauer 2.39003b
Reaktionen: Radagast
Hmmm, danke ... mir wird auch kein Update angezeigt im Store ... war eh merkwürdig beim Kauf .... wurde nicht geladen, auch ne Stunde nach Kauf nicht, Emails über Kauf waren da, Umtausch nicht möglich und nach mehreren Stunden dann wurde der Download vollzogen ...
Werde mal deinstallieren und erneut ziehen (mal sehen, ob es mir als gekauft angezeigt wird :thumbsup:
Wenn du die Pro hast, dann tritt mal der Zooper Widget Awesome Beta Testers Community bei, dann kannst die Beta laden. Wie aber der Name es sagt: beta, können also auch Probleme auftauchen.
Bei mir ist alles original......Version 2.38
Ist aber nun schon seid 2 versionen so .also auch nach dem letzten update hab ich dieses Problem das mir einfach keine Vorschaubilder angezeigt werden.
Nach speichern eines neuen Templates wird auch gar kein vorschaubild mit gespeichert.
Ich habe noch mal nachgeschaut, ihr habt recht. Wenn ich was neu speichere, werden dazu keine Vorschaubilder erstellt. Bei den alten sind sie noch erhalten.
bringt es in der beta community zur sprache, dafür isses ja da! :)
Die V.2.38 ist keine betaversion...
und ich zumindest kann leider kein englisch,sonst hätte ich das schon längst im Zooper forum getan;)
du kannst mit allen versionen schreiben, wenns bugs hat, rein damit. ;) ... heisst einfach nur beta auf g+
ich habe mal einen kleinen mediaplayer nach einer vorlage von dylon smith (*credits fly out to trinidad and tobago, carribean sea* :) ) aus dem g+ board zu zooper etwas umgebaut.
das ganze wird mit media utilities aus dem playstore gehandelt, was doch recht praktisch ist... ich hab das ganze etwas verfeinert, ein paar ontaps zusätzlich rein und an meine bedürfnisse angepasst.
auf einem single screen ohne was, kommt das vllt ganz gut zur geltung.. :D
wems gefällt, kann dylon oder mich ja fragen.. dann häng ichs *.zw an...
ST
edit: player version 2
  • player neu 2.zip
  • player neu 2.zwapk.zip
Reaktionen: Radagast und fraz14
die app zooper möchte aber viele rechte
Ich habe jetzt mal ins Forum gepostet,aber scheinbar weiss auch der Enwickler keine Lösung für das Problem.
Denn nach dem neusten Update auf 2.40 besteht das Problem weitherhin
Keine Vorschaubilder bei neuen Templates!
Vorschaubilder werden nach wie vor nicht angezeigt und nicht gespeichert!
Topic: Thumbnails of stored templates | ZooperLog
bei manchen templates habe ich vorschaubilder, bei anderen nicht. woran das liegt, weiss ich allerdings nicht. scheint ein bug zu sein.
Moin, wie kann ich bei ner Uhr aus Fortschrittsleisten noch klein daneben die Zahlen 1-12 machen? Muss ich da jede Zahl einzeln einfügen und positionieren oder geht das auch einfacher?
so wie in dem Bild die Zahlen 1-23
widget öffnen, darstellung (layout/edit), "+" (oben rechts), text oder rich text und zahlen/text adden... muss man dann halt in die position schieben, drehen, andere fonts, wie auch immer. da muss man (leider ) jede zahl einzeln positionieren...
