[ICS] *05.06.12* Litening Rom v3.6 [Fast as Lightning]
pro.aggro
pro.aggro
Ikone
3.413
Welcome to the Lite'ning ROM
Features
-Fast and stable SGS II ICS 4.03 ROM
*Based on original Firmware
*Siyah kernel
*Blue themed
*Call Recording
*Battery percentage
*Overscroll glow
*Better optimised apk's, framework for more speed and free mem.
*Customizable 14 statusbar by lidroid
*Camera silent
*Large APN list
*Fast GPS lock
*Memory tweak
*Kernel tweaks
*SD card read tweak
*Zipaligned.
*Deodexed.
*Root + Busybox
Changelog
05.06.2012 (Lite'ning Rom v3.6)
Based on original XWLPG
Modem XXLPX
CSC NEELP4
LitePro kernel v3.2
jkay integrated
changed bootsound
removed Lite'ning Rom bootanimation
Added Touchwiz + TouchwizUX - Note: Calendar widget generate FC with TouchwizUX
Added SGS3 sounds
StatusBar Transparent
Lite'ning Rom v3.4
Based on original XWLPF
Modem XXLPX
CSC XILP6
Tweaked to gain more speed
LitePro kernel v3.2
Added ICS dialer with BigPic
Added SGS3 sounds
Added no CRT effect (you can download CRT effect from the LRToolbox)
Lite'ning Rom v3.2
Based on original XWLPD
Modem XXLPW
CSC XENLP5
LitePro kernel v3.2
Added Original Touchwiz + TouchwizUX
Added SGS3 sound
Added vlingo
Removed Polaris Office (you can download Polaris Office from the LRToolbox)
Lite'ning Rom v3.1
Modem XXLPW
CSC XENLP5
LitePro kernel v3
Added ICS dialer
Added CRT effect
Lite'ning Rom v3.0
Based on original DXLP9
Modem DXLP9
CSC OLBLP9
Added more languages
Kernel LitePro kernel v3
Added LRToolbox v1.8
Added ICS dialer
Added CRT effect
Fixed home button back
Fixed text bug
Fixed the toggle issue
Lite'ning Rom v2.9
Modem DXLP9
CSC OLBLP9
Kernel LitePro kernel v1
Fixed text bug
Lite'ning Rom v2.8
Based on original XWLP9
XXLPS Modem
CSC KPNLP1
Stock kernel (after flashing choose the desired kernel with the LRToolbox)
Added new LRToolbox v1.7
Removed "Swipe to unlock" Text from Lockscreen
Lite'ning Rom v2.7
Based on original XWLP7
XXLPS Modem
Added Siyah Kernel v3.0.1
Added LRToolbox v1.6
Removed Swype (you can download it from here)
Lite'ning Rom
2.6
Based on original XWLP4
XXLPS Modem
Added Siyah Kernel v3.0rc2
Added Kies Air
Added Fix for Kies
Removed ExTweaks (download available on the Market)
Removed CRT effect (this will be available at the LRToolbox)
Removed Swype
Lite'ning Rom 2.5
Based on original XWLP3
Added Siyah kernel v3.0b7
Added ExTweaks
Added fix for Kies
Added bln-lights
Lite'ning Rom 2.4
Added fix for Kies
Added BLN-lights
Installations Guide
Siehe Post #2
Downloads
[URL=http://d-h.st/m5u]LiteningROM_v3.6_Fix.rar - 285.49 MB[/URL]
Passwort:
pro.aggro@android-hilfe.de
Happy flashing
Quelle:
Lite'ning Rom Board
Reaktionen: Geistlos70, Chris1582, GC79IT und 12 andere
Installations Guide
Step 1. Backup der bisherigen ROM erstellen (Nandroid Backup).
Step 2. Reboot in die ClockworkMod Recovery.
*** [Siehe unten]
Step 3. Wipe User Data/Factory Reset" [Muss nicht unbedingt gemacht werden]
Step 4. Wipe cache partition.
Step 5. "Advanced > Wipe Dalvik cache".
Step 6. Odin v1.85 [siehe Anhang] auf dem Computer installieren und die Lite'ning Rom RAR-Datei entpacken.
Step 7. USB Debugging-Mode aktivieren: Einstellungen >> Entwickler-Optionen >> USB Debugging.
Step 8. Reboot in den Download-Mode >> Telefon ausschalten, dann gleichzeitig "Volume Down + Home + Power" drücken. Mit "Volume Up" bestätigen.
Step 9. Odin starten.
Step 10. Telefon über das USB Kabel mit dem PC verbinden.
Step 11. Ein paar Sekunden warten, der Odin Bildschirm wird dann anzeigen, dass das Gerät verbunden ist... "Added!!".
* Vergewissern, dass nur die Haken bei "Auto reboot" und "F. Reset Time" aktiviert sind.
* "PDA" Button drücken, und die md5 Datei auswählen.
* "Start" drücken. Odin flasht dann die Lite'ning Rom, danach wird automatisch ein Reboot gemacht.
Wenn die Anweisungen nicht genau gefolgt werden kann es sein, dass das man wieder in der Recovery landet. Dann das Backup aus Schritt #1 einspielen und den Vorgang wiederholen.
Step 12. Fertig! Das Telefon ist jetzt gerootet und die Lite'ning Rom installiert!
Wer von GB kommt und auf ICS wechselt oder einfach ein komplett sauberes System haben möchte, dem empfehle ich das Fullwipe Script zu benutzen!
Das Script benötigt Root und eine externe SD Card.
Wer keinen Rootzugriff oder eine externe SD Card hat, der kann das Telefon auch manuell formatieren.
  • Das Script aus dem Anhang runterladen und die Zip-Datei auf die externe SD Card kopieren.
  • In die Recovery booten (Volume Up + Power).
Achtung: Es wird alles ausser der externen SD formatiert! Wichtige Dateien (Fotos etc.) die auf der internen SD gespeichert sind ggf. vorher sichern!
  • Den Menüpunkt "Install Zip from SD Card" öffnen.
  • Fullwipe.Script.v1.2.mit.SDCard.zip auswählen und ausführen.
  • In der Recovery "Shut down" oder "Reboot in Download Mode" wählen. [variiert je nach Kernel]
  • Mit Hilfe des Jigs oder der Tastenkombination das Telefon in den Download-Modus bringen und die Rom nach der oben genannten Anleitung flashen. [Schritt entfällt, wenn man in der Recovery "Reboot in Download Mode" wählen kann]
Der manuelle Weg des Fullwipe:
  • das Handy mittels Power-Taste oder Software-Menü der ROM ausschalten
  • die Lautstärke-Taste nach oben drücken, dann den Home-Button und dann die Power-Taste drücken und warten bis das CWM-Recovery erscheint
  • zum Eintrag wipe data/factory reset durchklicken und ausführen lassen
  • zum Eintrag wipe cache partition klicken und ausführen lassen
  • zum Eintrag advanced Menü klicken, dann dort zum Eintrag wipe dalvik cache klicken und ausführen lassen
  • zum Eintrag mount and storage Menü klicken, dann dort zum Eintrag format system klicken und ausführen lassen
  • zum Eintrag mount and storage Menü klicken, dann dort zum Eintrag format emmc klicken und ausführen lassen (nur bei Sammy-ROMs)
  • zum Eintrag mount and storage Menü klicken, dann dort zum Eintrag format sdcard klicken und ausführen lassen (nur bei AOSP/AOKP-ROMs)
  • nach dem Fullwipe ohne Reboot neue ROM installieren
  • falls keine externe SD-Karte vorhanden ist, sollte man nach dem Fullwipe zum Eintrag mount and storage Menü klicken, dann dort zum Eintrag mount USB storage klicken und seine ROM auf die interne SD-Karte kopieren
Quelle:
Fullwipe Script
Was immer ihr hier auch macht, ihr macht es auf eigene Verantwortung und für mögliche Schäden übernehme ich keinerlei Haftung.
  • Odin3_v1.85.zip
Reaktionen: Geistlos70, GC79IT, Sadist und 10 andere
Platzhalter.
Platzhalter..
Platzhalter...
Gibt doch schon nen lite'ning ics thread oder?warum der zweite?
Send Form Hell
Da pro.aggro das RoM von beginn an nutzt, der alte TE ein anderes Handy hat und somit den Thread nicht mehr führen möchte haben wir uns entschlossen einen neuen Thread zu erstellen welcher von pro.aggro geführt wird.
Mfg
Reaktionen: Flipper92, Dr.Franz und Shaitan
Ok danke!
Send Form Hell
Gute Entscheidung.
Dann auf ein neues..
Seit dem update auf 2.7 habe ich das Problem mit der Aktivierung GPS/Mobiles Netzwerk und der Beleuchtungseinstellung.
Im Lite'ning Forum gibt es auch einige Klagen darüber.
Egal ob über die Quick Settings Bar oder direkt unter den Einstellungen des SGS2.
Heute habe ich nochmal diverse Siyah getestet. (mit Cleaning Script dazwischen). Kein Erfolg.
Ich bin jetzt erstmal mit dem Stock Kernel aus der Toolbox unterwegs. Damit läuft es fast zufriedenstellend. Nur, bei GPS/Mobiles Netzwerk in der Quick Settings Bar, muss ich die beiden Buttons abwechselnd drücken um die Einstellungen zu ändern. Aber im Menü des SGS2 klappt es mit den Änderungen.
Da ich heute ein weiteres SGS2 auf 2.7 (von Stock 2.3.4) geflasht habe und damit gleiche Problem dort besteht, bin ich erstmal ratlos.
Fuer mich ist die Lite'ning Rom etwas Neues, noch nie geflasht.
Was hat sie was andere nicht haben, bzw. wo kann man etwas ueber diese ROM nach nachlesen?
Gab es nicht auch noch einen anderen Litening ICS Thread?
Ein Post über dir.
Pro.Aggro schrieb:
Der md5 Dismatch ist aber eine Kernelsache ;)
Also ich habe wie gesagt jetzt eine andere ROM, immernoch Siyah und backup klappt wieder. Eben getestet.
Reaktionen: tobihoby
ich hab seit gestern ein komisches Phänomen bei meinem SII (ICS 2.6).
Wenn sich das Display sperrt(30 Sek) dauert es ca. 15 Sek dann geht es wieder an und piept. Es erscheint nicht der Lockscreen sondern ne Art Schnellstart Bildschirm mit Uhrzeit Wetter etc.
Hab heute schon einen Full Wipe gemacht und die 2.7 installiert und neu eingerichtet... selbes phänomen.
Wisst ihr vielleicht weiter?
Viele Grüße
Bullet
Warum hast du dann wieder die 2.6 geflasht wenn du damit Probleme hattest und nicht die neue 2.7?
Lies dir den Beitrag doch mal durch.
Ich hab eh die 2.7 geflasht.
Habe heute tagsüber mein SII weiter beobachtet, immer noch das gleiche.
Das Display fängt an zu leuchten, dann ein paar piepser und dann geht es wieder aus.
Was mir auch noch aufgefallen ist das oben in der Statusleite ein Lenkrad angezeigt wird(2 Sek).
Durch dieses Phänomen wird der Akku regelrecht ausgesaugt.
Hoff mir kann jemand helfen.
Viele Grüße
Bulletman
Also ich weiß nicht.
Generell ist die ROM ja ein toller Ansatz, aber auf meinem SGS2 werden viele Einstellungen ganz einfach nicht übernommen. Das geht von GPS über die Quickbar in der Statusleiste bis hin zum simplen Ändern der Bildschirmsperre.
Bin ich da wirklich der einzige? ;)
@Snake3: Ups sorry..
Meine ersten Roms waren alle Lite'nings :-D
Also was ich gefunden hab:
- die alten Ruckler kamen wieder.. Man schiebt nach rechts und das Bild hüpft nach links oder stottert und bleibt beim eigenen Bild..
- Ich hatte Probleme mit der Akkulaufzeit (mit Internet = 0,25-1% pro Minute :scared: )
- Die GlowOf Animation fehlt noch :-(
Aber ne andere Frage, ist es möglich den Lancher einzel zu bekommen??
Denn ich finde die Einstellungen in der Statusleiste so genial..
Gruß Flipper
Simuur95
Kjetal
Kjetal
dawkon13
udokalina
U
Kjetal
Kjetal
